Pot Filler - Kitchens & Baths - Contractor Talk
Pot Filler
Old 09-25-2012, 08:47 PM   #1
11678's Avatar
Rewards Points: 250
Pot Filler
Pot fillers are put at stoves to fill big pots as not to have to carry it from the sink, right.
Now what do you do with the hot water after you're done cooking ?
Pot drains in stove top, could be the next hot item !
11678 is offline
Old 09-25-2012, 09:46 PM   #2
Eaglei's Avatar
Trade: carpenter & Masonry
Rewards Points: 1,510
Re: Pot Filler
Use it again , its boiled .
Eaglei is offline
Old 09-25-2012, 10:05 PM   #3
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,074
Re: Pot Filler
If nothing sticks to Teflon how does it stick to the pan?
Inner10 is offline
Old 09-26-2012, 05:48 AM   #4
11678's Avatar
Rewards Points: 250
Re: Pot Filler
11678 is offline
The Following User Says Thank You to 11678 For This Useful Post:
Eaglei (09-26-2012)
Old 09-26-2012, 09:39 AM   #5
Eaglei's Avatar
Re: Pot Filler
To much pot .
Eaglei is offline
Old 09-26-2012, 10:25 AM   #6
Thom
thom's Avatar
Rewards Points: 4,748
Re: Pot Filler
Apparently Teflon doesn't stick to pans, at least not very well. Look at a used teflon pan, the teflon is gone, you ate it all.
Patriotism is being loyal to your country all the time and your government when it deserves it. Mark Twain
thom is offline
Old 09-26-2012, 10:45 AM   #7
Inner10's Avatar
Re: Pot Filler
Originally Posted by 11678 View Post
He asked one of those rhetorical kitchen questions so I thought I'd steer the thread in that direction.
"If I only have a pot filler on the stove where do I empty the pot?"
"when cheese gets it's picture taken what does it say?"
Inner10 is offline
Old 09-26-2012, 12:32 PM   #8
TimelessQuality's Avatar
Trade: GC/Remodeling
Rewards Points: 1,730
Re: Pot Filler
In your belly
-Steve
TimelessQuality is offline
Old 09-26-2012, 12:39 PM   #9
11678's Avatar
Rewards Points: 250
Re: Pot Filler
Actually mine wasn't rhetorical.
What do you do with that big pot of water ?
11678 is offline
Old 09-26-2012, 12:41 PM   #10
Inner10's Avatar
Re: Pot Filler
You carry it to the sink.
Depending on your fixtures it can be a pain to wrestle a stock pot under your faucet so you end up holing it on an angle to get it partially full then topping it up with a measuring cup....Well at least that's what happens at my house...
Inner10 is offline
Old 09-26-2012, 01:38 PM   #11
Can I get an Amen?
Aaron Berk's Avatar
Trade: Custom Woodworks
Rewards Points: 1,060
Re: Pot Filler
Dumping a pot of water into a drain on my cook top sounds ludicrous.
And Teflon isn't going into this guys belly.
I cook with cast iron or stainless
Aaron Berk is offline
Old 09-26-2012, 02:10 PM   #12
Re: Pot Filler
Pot sucker?
-Steve
Old 09-26-2012, 05:55 PM   #13
Eaglei's Avatar
Re: Pot Filler
11678 Im with you on that one , doesnt make sense !!! . Should have some kind of drain in the wall next to the water supply that you can siphon out the water . Like a reverse pot filler .
Eaglei is offline
auto box filler icerock drywall Drywall 6 09-06-2012 02:52 PM
"shall" is uncool. It's time to use "will" or "must" and cut out the filler words Electric_Light Business 15 09-05-2012 04:50 PM
wood grain filler Metro M & L Flooring 6 11-11-2011 09:49 PM
filler for cedar siding gregferd Painting & Finish Work 1 10-01-2009 09:29 AM
Hardwood Wood Filler/ Rec agboett Flooring 3 03-19-2009 08:45 AM
