Porcelain Enamel: Mark/Blemish Removal - Kitchens & Baths - Contractor Talk
Old 04-22-2016, 07:56 PM   #1
TheInchYouBurn's Avatar
Rewards Points: 4
Red face
Greetings gentlemen,
Seeking simple advice (whichever way you look at it)...Unfortunately I am responsible for a cast iron, porcelain enamel tub that was not covered before an insulating crew came in. Insulator, applying cellulose to external walls, without notice or care drug his spray/vacuum hoses or whatever equipment across this uncovered tub leaving what appear to be metal blemishes/streaks down the length and inside the tub. I thought at first they may be the result of a plastic vacuum hose, leaving scuff marks like rubber soles on a gym floor...however, these marks appear to have become part of the enamel itself. There's no scratch to match the streaks, no perceived difference in surface. Everything is smooth, but there are black/metallic lines and spots down the length and on the inside of this thing.
Assuming the hose end/opening was metal (or plastic), is anyone more qualified familiar with a remedy, substance, or procedure that may be able to eliminate these blemishes? Otherwise I anticipate one of you will be by...
TheInchYouBurn is offline
Old 04-22-2016, 08:05 PM   #2
dsconstructs's Avatar
Trade: Remodel Contractor
Rewards Points: 878
Re: Porcelain Enamel: Mark/Blemish Removal
Have you tried pumice?
dsconstructs is offline
Old 04-22-2016, 08:07 PM   #3
MarkJames's Avatar
Rewards Points: 19,651
You might get lucky. It could be metal residue that will clean up with tilex or scubbing bubbles or something. Just to compare, when removing old caulk, straight razor blades can leave grey "scrape" marks on enamel, but it cleans right up with detergent. Hope so. Give it a try.
MarkJames is offline
Old 04-22-2016, 08:46 PM   #4
nickko's Avatar
Trade: remodeling-cabinet maker
Rewards Points: 855
Bar keepers friend works great for metal marks on porcelain. I've used it many times to remove metal marks.
Nicko
"Quality work for those who know the difference"
nickko is offline
Old 04-22-2016, 08:46 PM   #5
Rewards Points: 4
Thanks or the replies.
Against the recommendation of manufacturer I tried (in a VERY small radius) "Magic Eraser". Nothing. Obviously, I'm afraid of anything abrasive. Google produced DIY advice suggesting baking soda. No difference. Manufacturer recommends a few different products which aren't stocked at closest building supply store so I haven't tried, but sounds as if some sort of detergent or cleaner is necessary/the only shot?
Dry Pack for laying porcelain tile on exterior patio Kyong Tiling 9 07-31-2019 11:37 AM
Concrete footing removal 18withtools Demolition 19 01-29-2013 07:34 PM
Sealer removal advice over exposed aggregate and stamped? oktex56 Concrete & Paving 10 01-14-2013 03:57 PM
coating removal bassinhunter Pool Construction & Enclosures 0 03-10-2012 12:28 PM
Porcelain Tile Specifications AustinReDevelop Tiling 4 01-13-2011 11:10 PM
