Ponywall Framing Options - Kitchens & Baths - Contractor Talk
Old 10-23-2017, 06:01 AM   #1
notahack's Avatar
Trade: general contractor
Rewards Points: 4
hey veteran home builders and re-modelers. im updating a small bathroom and despite the limited amount of space i have to work with, my customer insits on a ponywall as a division between the new shower build and the toilet. im doing the 'open concept' style and trying to save a few inches here n there, i suggested a glass shower partition. hell no, instead of a full lenth piece of gls (shower curb to ceiling), they want a ponywall and attached on top half of this wall, half a glass shower partItion. client is king though. can i frame this on top of shower pan curb using 2 by 3 's vs 2by4 and tile on shower side, backr and wainscoting on toilet side? pls help fellas. the existing partition wall that i demo-ed had a 2by2 bottom plate with 2by4 studs turned 90 dgrs so positioned flat and flush with both bottom and top plates. the tradesman before obviously had space concienetious on mind as well. thx,
notahack is offline
Old 10-23-2017, 07:18 PM   #2
Xtrememtnbiker's Avatar
Trade: General Remodeling
Rewards Points: 340
Re: Ponywall Framing Options
What are you using for your shower curb?
Xtrememtnbiker is offline
Old 10-23-2017, 07:34 PM   #3
Bull Trout's Avatar
Rewards Points: 132
I may not be envisioning this properly but it sounds like the pony wall could be a bit unstable
Bull Trout is offline
Old 10-23-2017, 07:51 PM   #4
Rewards Points: 340
We have done a lot of them but we use Schluter products for our shower so it's just a 2x4 framed wall the goes down to the subfloor.
The shower curb runs from the end of the half wall to the other wall unless it's curbless and then no curb anyway.
The Following User Says Thank You to Xtrememtnbiker For This Useful Post:
Bull Trout (10-23-2017)
Old 10-23-2017, 08:46 PM   #5
tjbnwi's Avatar
Rewards Points: 3,976
Bond 2 pieces of 1-1/2" Kerdi Board together.
tjbnwi is online now
Old 10-23-2017, 11:09 PM   #6
rblakes1's Avatar
Rewards Points: 3,920
If you're going to frame it with 2x, make sure you run your end stud down through the subfloor to a block between the joists
Sent from my SM-N910V using Tapatalk
rblakes1 is online now
Old 10-23-2017, 11:11 PM   #7
rblakes1's Avatar
I only got to use those a little at the training thing I went to last week, how sturdy are they once set?
Old 10-24-2017, 05:34 AM   #8
notahack's Avatar
Rewards Points: 4
(3) 2x4 treated nailed togeather, panliner , then wrapped with 1/4 in. hardibckr, thinset float, fibertape on joints, redgard membrane
notahack is offline
Old 10-24-2017, 07:42 AM   #9
Tom M's Avatar
Rewards Points: 11,138
Some go with threaded rod anchored down to the floor. It will help but with kneewalls leverage is going against you. If possible I make the wall wider like 2x6 and always run the top 2x on the wall into the intersecting wall for some extra anchors. Waterproof intersection well. One jarring hit........
Some corner shelves or bench maybe help the cause.
Another thing I recently did was bury a Steel deck post in the outer end of a kneewall. I found a 2" square shaft post that I centered between my wall studs. I pocket screwed a 3/4" x 14.5" plywood skin over the post and in between my studs. Very stiff.
Tom M is online now
Old 10-24-2017, 08:38 AM   #10
hdavis's Avatar
Rewards Points: 1,090
I read this as 3 questions. Can I frame this on the flat - yes. Can I frame this using 2X3s - yes. Both are allowed by code. I'd recommend gluing all joints, and all joints need to be tight. I'd also recommend glue when you skin it over, it will improve the stiffness.
The third question is how do I keep the pony wall from moving too easily? This is the same situation as installing a newell post - any of those will work.
hdavis is online now
Options when you run into asbestos cutback platinumLLC Flooring 12 02-20-2015 07:15 AM
Framing with steel article. Rich D. Decks & Fencing 6 02-02-2013 05:51 PM
Framing addition - Matching existing roof plane ncornilsen Framing 18 01-11-2013 12:47 PM
The joy of winter framing. C2projects Framing 3 01-10-2013 12:38 PM
Span/Deflection tables for non-traditional framing? BlueRidgeGreen Tiling 3 01-08-2013 08:30 AM
