Obstinate Tub/Shower Stain - Kitchens & Baths - Contractor Talk
Old 07-11-2019, 08:23 PM   #1
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 4,584
Don't know what this is but have scrubbed with household cleaners, denatured alcohol, nail polish remover and acetone all with zero effect. Ideas?
Lacking an answer, maybe I'll shop grey splash guards...if it will cover.
But you don't see too many finishes this shade of grey.
Obstinate Tub/Shower Stain-shower-stain-7.11.19.jpg
artinall is offline
Old 07-11-2019, 08:25 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 2,350
Re: Obstinate Tub/Shower Stain
porcelain or gel-coat?
looks like a stain coming through the finish.
griz is offline
TNTRenovate (07-19-2019)
Old 07-11-2019, 08:39 PM   #3
Idothat's Avatar
Trade: Home improvement of all types
Rewards Points: 2,280
Looks like a rust stain , try something like CLR . Might have to leave it on the surface for a while .https://www.amazon.com/CLR-Calcium-R...49103251&psc=1
Idothat is online now
The Following 2 Users Say Thank You to Idothat For This Useful Post:
artinall (07-11-2019), Fouthgeneration (07-19-2019)
Old 07-11-2019, 08:40 PM   #4
artinall's Avatar
Porcelain.
A winning combination given the matching shorty toilet that's only a lifetime off.
artinall is offline
Old 07-11-2019, 08:43 PM   #5
Fire up the BBQ
griz's Avatar
try a polishing compound.
go EASY.....
you can also try toothpaste and/or baking soda.
GO EASY.....
griz is offline
Old 07-11-2019, 08:48 PM   #6
artinall's Avatar
Looks really seated in there. The three dark spots seem raised ever-so-slightly.
Could something be propping from down under?
Actually the stain is goes wider that most splash guards I've seen...
artinall is offline
Old 07-12-2019, 12:25 PM   #7
VinylHanger's Avatar
Rewards Points: 10,328
You know... you can't always polish a...
VinylHanger is online now
The Following 2 Users Say Thank You to VinylHanger For This Useful Post:
avenge (07-12-2019), griz (07-12-2019)
Old 07-12-2019, 03:06 PM   #8
hdavis's Avatar
Rewards Points: 3,138
I'd go with oxalic acid. Or a sledge, either will do.
hdavis is online now
Old 07-12-2019, 05:29 PM   #9
artinall's Avatar
I was thinking of a running head start down the hallway spearing a breaker bar. I'll find what's ever supporting it through the side.
artinall is offline
Old 07-12-2019, 09:08 PM   #10
EricBrancard's Avatar
Trade: Builder/Renovator
Rewards Points: 744
Try Barkeepers Friend.
EricBrancard is online now
The Following User Says Thank You to EricBrancard For This Useful Post:
artinall (07-13-2019)
Old 07-12-2019, 09:12 PM   #11
KAP's Avatar
Trade: Custom
Rewards Points: 34,148
Use a new blade on that first to scrape... you can also try some ceramic glass top compound for the rest...
KAP is offline
The Following User Says Thank You to KAP For This Useful Post:
Old 07-17-2019, 06:02 PM   #12
KAP's Avatar
Trade: Custom
So how'd it all work out?
KAP is offline
Old 07-17-2019, 06:19 PM   #13
artinall's Avatar
We're still together. Got sidetracked by other destruction in the unit.
Will try razor, baking soda, clr tomorrow since this is what I already have.
Others to follow...
Thanks much for asking KAP.
artinall is offline
The Following User Says Thank You to artinall For This Useful Post:
KAP (07-17-2019)
Old 07-18-2019, 07:09 PM   #14
artinall's Avatar
Tried working those three which made no change.
- To resume in the week or so ahead.
artinall is offline
KAP (07-18-2019)
Old 07-19-2019, 08:48 PM   #15
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 8,341
CLR, vinegar, or an Oxy-cleaner, Hydrogen Peroxide?
might need several hours with damp "plaster" soaked with the reducing agent to soak into the porcelain that is stained. or surround with putty dam and "drown" with liquid agents.....
Strong acids will destroy porcelain.
don't ask how I know....
Fouthgeneration is online now
Old 07-19-2019, 09:08 PM   #16
rrk's Avatar
Rewards Points: 1,650
CLR will also destroy marble, removes all of the color
rrk is online now
Old 07-19-2019, 09:54 PM   #17
Rewards Points: 744
Seriously. Try barkeepers friend. You can get it anywhere and it think it’s less than $3. It’s removed things from all types of surfaces that I thought would never come out. If that doesn’t do the trick, it’s prob there to stay.
Old 07-20-2019, 05:57 AM   #18
artinall's Avatar
Will try when I have the chance.
Tried clr.
The stain seems in there, so it may not come out. Buying bottles may not matter.
Have oxy on deck for something else and will give that a test. Then probably barkeepers...
artinall is offline
Fouthgeneration (07-20-2019)
Old 07-20-2019, 10:38 AM   #19
A2Zcontracting's Avatar
Trade: General Building
Rewards Points: 68
x2 for barkeepers friend. That stuff has worked miracles for me and the price is right. If its a true porcelain dont be afraid to get some waterproof 220 sandpaper and use a little elbow grease. Its amazing what that combo can do on discolored porcelain. Ive even gottten stains off the inside of toilets after a rusty auger has been run down it and bleach, crl, ect wouldnt do anything.
Sent from my LM-Q710.FG using Tapatalk
A2Zcontracting is online now
Old 07-20-2019, 07:03 PM   #20
Trade: Masonry
RE: sandpaper, start easy, 1000, 800,600, 400,320 then the 220
A blind man can see 220 scratches on glass type finishes, IMHO
Stainless steel wool??? maybe not?
