Measuring Counter Tops - Kitchens & Baths - Contractor Talk
Old 10-31-2015, 10:45 PM   #1
nwksremodeler's Avatar
Trade: a little bit of everything, roofing, windows, doors, kitchen & bath remodels
Rewards Points: 244
What tools (assuming electronic/laser) do counter top shops use to take measurements onsite, then replicate in the shop. I had a friend who got tops at HD and said they used something to record positions (curves and bows in the wall and corner points) and then the new tops were almost a perfect fit when installed.
nwksremodeler is offline
Old 10-31-2015, 10:55 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 46
Re: Measuring Counter Tops
Counter top guys I used for my Soapstone tops did this.
They set up a box at the end of the bar top and plotted points.
Went back to the shop and the data was inputted in to a CNC machine.
Tops arrived and looked like a scribe fit off the truck.
Seems to be what the pro guys are using now days.
griz is online now
Old 10-31-2015, 11:22 PM   #3
Xtrememtnbiker's Avatar
Trade: General Remodeling
Rewards Points: 340
Our guys come in with a laser connected to a tablet that's all set on a tripod.
They plot a variety of points and it completes the lines. They have to use their eyes and straight edges to determine where to shoot the laser.
Then back to the shop where the CAD guy turns it into readable info for the CNC and it cuts it. A pretty sweet operation.
Now if we can just get them to start attaching the sinks... last two jobs the sinks just about fell out. Growing pains can be hard.
Xtrememtnbiker is offline
Old 11-01-2015, 03:53 AM   #4
Peter_C's Avatar
Trade: Home Beautification
Rewards Points: 412
Out of 1/8" PVC sheet cut approximately 3" wide strips, to build templates. Once set in place you just squirt some solvent between the pieces, wait a couple of minutes and you have perfect physical templates. The PVC snaps very easily after a slice with a knife. Once a square is built, it is strong in the dimensions where it needs to be.
I have seen guys build them out of wood, but it won't be as strong, and they are at high risk of the staples or other fasteners allowing movement.
Otherwise a pencil and some paper with a tape measure take care of the rest. Lots of pictures help too.
Peter_C is offline
Old 11-01-2015, 10:12 AM   #5
Easyfier of Complexitries
digiconsoo's Avatar
Trade: Framing Components
Rewards Points: 1,552
By far the two most common:
http://www.laserproductsus.com/produ...ser-templator/
http://blog.prodim-systems.com/
I have used the above, and they work well - the proliner I liked better - but the Disto3D is my favorite because it is geared to so much more than just the countertop industry:
http://www.leica-geosystems.us/en/Le...isto_94606.htm
Originally Posted by hdavis View Post
It's probably better you write about something where you aren't functionally ignorant, you're just embarrassing yourself.
Originally Posted by tipitop View Post
Trump is lucky he didn't mess with me.
http://www.digiconsoo.com
digiconsoo is offline
Old 11-01-2015, 01:54 PM   #6
Peter_C's Avatar
Rewards Points: 412
Very cool. I knew they could map caves in 3D, but didn't know they were able to get measurements accurate enough to do counter tops etc.
Even though I was one of the early adopters of laser measuring, I guess I am far behind the times now. (Note: I don't do counter tops for a living.)
Peter_C is offline
Old 11-01-2015, 02:29 PM   #7
pro
country_huck's Avatar
Trade: Capenter/ Remodeler
Rewards Points: 768
One granite shop I use uses the fancy laser system and the guy I use the most use 1/4" Luan cut into 3"wide strips that are then hot glued together.
To be honest I can't tell the difference in finial product and they both take about just as long to template.
country_huck is offline
The Following 2 Users Say Thank You to country_huck For This Useful Post:
Doctor Handyman (11-01-2015), philcav7 (02-12-2016)
Old 11-01-2015, 02:36 PM   #8
tjbnwi's Avatar
Rewards Points: 60
I use drywall shim and hot glue for my templates, quick, easy and very accurate.
tjbnwi is online now
Old 11-01-2015, 04:57 PM   #9
digiconsoo's Avatar
That's absolutely true. It takes about the same amount of site time.
The advantage with the laser is that the information is instantly stored as a .dxf file that is ready to feed into a CNC machine. Most fabricators around here email the file back to the shop from the job site as soon as they're done.
No transporting of templates, which sometimes get unwieldy on large kitchens, or damaged in transport.
Physical templates would still need to be digitized at the shop, adding another step and opportunity for error.
If a shop is not using CNC equipment, probably not a significant advantage to the digital templating.
Old 11-01-2015, 05:08 PM   #10
dsconstructs's Avatar
Trade: Remodel Contractor
Rewards Points: 836
Another advantage to the laser system is that they are able to take their measurements with existing tops in place, for jobs that aren't replacing cabinetry.
It's nice to be able to plan the removal of old tops a day before installation without having that extended down time for the client's kitchen waiting on fabrication.
dsconstructs is offline
Old 11-01-2015, 07:39 PM   #11
Rewards Points: 244
What do some of these laser systems cost?
Old 11-05-2015, 09:44 AM   #12
digiconsoo's Avatar
You can find them used for about 4500-7500, some of them.
New, 10K on up
Leica is the most expensive, because it's worth it.
Google is your friend!
counter tops / coffee table Hirdlerconcrete Masonry 8 11-26-2012 09:20 AM
Solid Surface counter tops. Greg TN rider Kitchens & Baths 11 11-21-2011 09:21 AM
Anybody got any tips on concrete counter tops? nickangel Kitchens & Baths 1 05-30-2011 06:49 PM
Concrete Counter tops CharlesD Kitchens & Baths 19 07-07-2010 09:14 AM
Refinishing or Stain Removal for Marble counter tops Joemimosh Kitchens & Baths 2 02-11-2010 05:02 PM
