Kitchen Sink Repair / Replacement Options - Kitchens & Baths - Contractor Talk
Old 04-30-2013, 09:14 AM   #1
CharlieM's Avatar
Trade: Residential remodeling
Rewards Points: 41
I have a client who needs their kitchen sink replaced or repaired. Ive contacted Elkay and American Standard and neither company makes a sink in the correct size. The existing sink is an American Standard. The existing sink is porcelain over steel. The client would prefer stainless steel. Elkay is currently pricing a custom sized stainless steel sink. I would like to have some options if there are any. The refinishing company we use does not recommend refinishing kitchen sinks due to the abuse they endure. This sink measures 27 left to right, 17 front to back, 9 deep and has a left rear drain. This sink is under mounted on granite. These are inside (not flange) dimensions. Any suggestions are greatly appreciated.
Thanks,
Charlie
CharlieM is offline
Old 04-30-2013, 09:35 AM   #2
Remodeler
TAHomeRepairs's Avatar
Rewards Points: 574
Re: Kitchen Sink Repair / Replacement Options
Is it drop-in or undermount? Do you have the room to get larger if needed or are you limited by space/customer constraints?
You could try Franke
Brain fart , I see you said undermount
TAHomeRepairs is offline
Old 04-30-2013, 09:52 AM   #3
ejsmgmt's Avatar
Trade: Construction
Rewards Points: 47
I would ask these companies for the actual dimension of the sink if you find anything close. I did something bad once(cut the wrong size in a countertop) and no one had the size that i needed listed. I went to my supplier with a taper measure and found the size that i needed which was different than what it said on the box.
ejsmgmt is offline
Old 04-30-2013, 09:56 AM   #4
Remodeler
Rewards Points: 574
I just checked a few different suppliers , that's a pretty oddball size for sho, good luck
Old 05-05-2013, 08:54 PM   #5
CharlieM's Avatar
Rewards Points: 41
We've sent a sketch to Elkay to price a custom sized sink. We'll see what they come back with.
Thanks for the responses
CharlieM is offline
The Following User Says Thank You to CharlieM For This Useful Post:
TAHomeRepairs (05-06-2013)
Old 05-06-2013, 06:36 AM   #6
General Contractor
greg24k's Avatar
Rewards Points: 8,786
Thanks,
Charlie
Check out Franke sinks, you might find what you looking for but be ready to pay, they're not cheap. Here is a link for a sink that size.
I hope it helps, good luck
greg24k is online now
Old 06-11-2013, 06:41 PM   #7
EZAccCleve's Avatar
Trade: Kitchen & Bathroom Remodeling
I know it's not as popular as American Standard..but have you tried Hansgrohe? One place to get them, if that helps...http://www.ibathtile.com/bathrooms-k...Hansgrohe.html
EZAccCleve is offline
Old 06-12-2013, 12:08 AM   #8
CarpenterSFO's Avatar
Rewards Points: 2,044
So what did you get? It's been a while..
- Bob
CarpenterSFO is offline
Old 11-03-2013, 06:57 PM   #9
Kowboy
Kowboy's Avatar
Trade: Countertops
Rewards Points: 8,942
CharlieM:
I disagree with your refinishing company. A palm sander and assorted sandpaper grits, red and gray Scotchbrite pads, and a stainless steel sink will look like new in less than an hour. I've done it.
Kowboy is offline
Old 11-03-2013, 07:05 PM   #10
tyb525's Avatar
Trade: Remodeling and Carpentry
Originally Posted by Kowboy View Post
CharlieM:
Existing sink is porcelain coated steel.
I work for a GC, and I do woodworking as a hobby. I also cut most of my own lumber for that with a Woodmizer LT10 sawmill.
Dull tools cause accidents. Sharpen your tools before they get dull!
tyb525 is offline
Old 04-17-2014, 12:29 PM   #11
GraniteShop's Avatar
Trade: Stone Fabricator
Rewards Points: 8
Most likely a Americast "Silhouette" style sink from American Standard. I don't know if they still make them, but you can likely find a replacement on the interweb. There is no equivalent undermount that will fit that shape that I know of.
GraniteShop is offline
Old 12-06-2014, 11:16 PM   #12
CopperSmith's Avatar
Trade: Custom Copper Gutters, Leaf Protection, Seamless
Rewards Points: 93
You should consider a copper sink!
Browse the Collection.
www.WorldCopperSmith.com
CopperSmith is offline
Exterior wall covering options? bob_cntrctr Construction 8 02-25-2013 08:05 AM
Kitchen Remodel SK Remodeling Carpentry Picture Post 3 08-12-2012 01:37 PM
Options for Stair nosing in kitchen? sbcontracting Tiling 5 10-02-2011 11:22 AM
Google Seminars For Success... Ivinni Marketing & Sales 193 02-07-2009 08:22 PM
