Installing Technique - Kitchens & Baths - Contractor Talk
Old 02-21-2014, 11:36 PM   #1
Tom M's Avatar
Rewards Points: 11,164
Thumbs down
I'm doing full over lay doors with 1x fascia & crown, so the fascia protrudes even with the doors then the crown.
So... I have a 25" refrigerator panel to provide a nice counter top return finish on the over hang. Now the cabinet over the fridge is 24" , would you slide your upper cabinet out flush to the panel or tuck it back so the door ends up flush with the panel?
The fascia bumps out to the doors projection anyway so no harm either way. The gain by tucking allows direct wall attachments to the wall rather than a built up cleat.
Tom M is offline
Old 02-22-2014, 12:45 AM   #2
bconley's Avatar
Trade: Kitchen and bath design+remodel
Re: Installing Technique
You don't say whether they are frameless or face frame cabs but i would install it flush with the front of the door, just like a full overlay filler on a frameless job
bconley is offline
The Following 2 Users Say Thank You to bconley For This Useful Post:
MarkJames (02-22-2014), Tom M (02-22-2014)
Old 02-22-2014, 08:28 AM   #3
Tom M's Avatar
I was leaning that way, good. They are frameless.
Tom M is offline
Old 02-22-2014, 09:21 AM   #4
General Contractor
greg24k's Avatar
Rewards Points: 8,652
Yes, definitely Tom, like others said, pack the back out and make it flush. We do this all the time with 30" Ref panels.
greg24k is offline
Old 02-22-2014, 09:29 AM   #5
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 9,495
Depends on what the other end of cabinets do. If there are applied panels to the end of the run cabinets and they stick out and the door is flush with them, that's what you do. Otherwise do it the flush way.
This cabinet should have had 1 3/8" overly hinges to cover the panels so it looks like the rest of the cabinets.. Doubt it does though.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline
Old 02-22-2014, 12:26 PM   #6
Tom M's Avatar
Thanks again.
Btw these are Hanson cabinets, never heard of them prior. Although the supplier raved about them, I'm not m pressed. It's a mid grade.
Tom M is offline
Old 02-22-2014, 04:32 PM   #7
BThomas's Avatar
Rewards Points: 153
I like to run the ref cab up past the flanking cabinets when there is a fascia above as it gives me something to fasten to. But if doing this - than the cabinet would be flush to the panel not the cabinet door. If the panel is only as tall as the top of the wall cabinet it can go either way as you still need to block it for the fascia.
Is there a tall cabinet on the other side say a pantry or oven cabinet? Does that need to be packed out?
BThomas is offline
Old 02-22-2014, 05:27 PM   #8
Tom M's Avatar
The panel goes as tall the upper cabinet and there is nothing but filler on the end. Since the fascia extends out 3/4" to the front edge of the door, the panel could go eitherway really . Whether or not the jog created by the panel adds character or not would be the issue. I don't think the hinge would bind.
Tom M is offline
Old 02-25-2014, 07:54 PM   #9
Tom M's Avatar
I ended up going flush with the door.
Installing technique-img_20140225_173815.jpg   Installing technique-img_20140225_173803.jpg
Tom M is offline
Old 02-28-2014, 10:31 AM   #10
rrk's Avatar
Rewards Points: 4,858
Hanson or Hanssem?
Hanssem is made in S.Plainfield, if so get more hinges. The ones they use dont last
rrk is offline
Old 03-02-2014, 02:45 PM   #11
Tom M's Avatar
Originally Posted by rrk View Post
Hanson or Hanssem?
Hanssem my bad
Tom M is offline
Installing grab bars in fiberglass tub shelf guy Kitchens & Baths 26 09-22-2015 01:42 AM
Installing Brazillian Cherry MKnAs Dad Finish Carpentry 0 02-18-2013 10:03 PM
installing ice and water shield in winter manny123 Roofing 24 11-28-2012 06:31 PM
Barn Siding - Batten Nailing Technique artinall Windows, Siding and Doors 9 07-13-2012 05:03 AM
