Installing Grab Bars In Fiberglass Tub - Page 2 - Kitchens & Baths - Contractor Talk
Old 11-10-2012, 11:21 PM   #21
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
Re: Installing Grab Bars In Fiberglass Tub
The nicer Sterlings have stirophome filler to study things up.
ohiohomedoctor is offline
Old 11-11-2012, 12:45 AM   #22
J M J's Avatar
Trade: general contractor
Rewards Points: 25
just use suction cup grab bars
J M J is offline
Old 11-11-2012, 12:01 PM   #23
Talking Head
EthanB's Avatar
Rewards Points: 384
Originally Posted by slowsol View Post
Sterling Tub surrounds generally have a couple inches between the fiberglass and the wall studs. At least everyone I've ever installed.
A couple inches is common, he said 'several' which is 4-5" in my mind.
Planer.....
EthanB is offline
Old 11-16-2012, 09:00 PM   #24
MAULEMALL's Avatar
Trade: GENERAL CONSTRUCTION
Rewards Points: 98
Why has no one asked if it need be ADA compliant and what would happen to him should it fail and not be ADA compliant...
If you can't do it right at least have a good lawyer on retainer..
MAULEMALL is offline
Old 11-23-2012, 09:27 AM   #25
shelf guy's Avatar
Trade: Custom Closets and Shower Doors
Rewards Points: 150
Ok well the job is done, there ended up being NO BLOCKING, despite the assurances of the builder. So I used these:
http://www.activeforever.com/p-2199-...l-anchors.aspx
Which are ADA approved for use in FG showers, they installed easy and seemed substantial.
shelf guy is offline
The Following 2 Users Say Thank You to shelf guy For This Useful Post:
dkillianjr (11-23-2012), MAULEMALL (11-23-2012)
Old 11-23-2012, 01:09 PM   #26
MAULEMALL's Avatar
Rewards Points: 98
Nice
Old 09-22-2015, 01:42 AM   #27
Preventec47's Avatar
Rewards Points: 54
the link is not working for me but I am assuming you are referring to
the Moen SecureMount Wall Anchors - Pair SKU: A16206
They are elegantly spreading the load over a large surface area.
The same could be done by gluing a round piece of 3/4" marine plywood
say for instance as big as a pie plate and then screwing into the plywood to mount the grab bar. Or you could glue ( epoxy most likely) a big thick piece of fiberglass to do the same thing.
Preventec47 is offline
Fiberglass Shower Replacement - Harrisburg, PA Tech Dawg Remodeling Picture Post 43 02-18-2012 10:40 AM
Pool Finish - Fiberglass cesinstructor Pool Construction & Enclosures 0 06-27-2011 07:13 PM
staining a fiberglass door Traditions2 Painting & Finish Work 11 01-28-2009 02:11 PM
