Installing Grab Bars In Fiberglass Tub - Kitchens & Baths - Contractor Talk
Old 11-04-2012, 04:56 PM   #1
shelf guy's Avatar
Trade: Custom Closets and Shower Doors
Rewards Points: 150
Cutting out the other side and installing blocking is not an option.
I looked online and saw various anchors, what do you guys recommend?
shelf guy is offline
Old 11-04-2012, 04:58 PM   #2
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
Re: Installing Grab Bars In Fiberglass Tub
Why is doing it right not an option?
ohiohomedoctor is offline
The Following User Says Thank You to ohiohomedoctor For This Useful Post:
Tech Dawg (11-04-2012)
Old 11-04-2012, 05:01 PM   #3
Chief Reporter of Spam
Tech Dawg's Avatar
Trade: Kitchen and Bathroom Remodeling
Rewards Points: 1,282
Sounds like you're out of luck. Normally the walls are too thin to install one with toggle bolts etc... without it cracking in a short period of time.
Todd
Alone Eagle Remodeling, LLC
Tech Dawg is offline
Old 11-04-2012, 05:02 PM   #4
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
Unless the fiberglass is 1/2" thick I wouldn't risk it. Dropping a bar of soap onto most fiberglass tubs can crack them they are so thin. Let alone support someone's weight.
www.bcconstructionllc.com
BCConstruction is offline
Old 11-04-2012, 05:06 PM   #5
Superior Firepower
skyhook's Avatar
Trade: GC HVAC/R Lic. since 1985
Rewards Points: 3,880
Lightbulb
super glue and duct tape. heavy on the tape.
skyhook is offline
Old 11-04-2012, 05:11 PM   #6
Epoxy screen anchors with maximum expanding expoxy. : laughing:
I cant see a situation where grab bars are necessary for transfer and opening the other side isnt an option.
Old 11-04-2012, 05:12 PM   #7
dkillianjr's Avatar
Rewards Points: 2,464
This may not be the ideal solution, but if they really need the grab bars.
If the tub wall has a big enough flat spot, can you cut a rectangle out from the front side, fill in blocking. Then maybe get a piece of solid surface material to match the tub and cover the whole and mount the bar to that.
Thats all I got, hopefully I don't end up over in the you may be a hack thread for this
dkillianjr is offline
The Following 2 Users Say Thank You to dkillianjr For This Useful Post:
skyhook (11-04-2012), Tech Dawg (11-04-2012)
Old 11-04-2012, 05:14 PM   #8
What a hack..
The Following 2 Users Say Thank You to ohiohomedoctor For This Useful Post:
dkillianjr (11-04-2012), J M J (11-11-2012)
Old 11-04-2012, 05:17 PM   #9
dkillianjr's Avatar
Originally Posted by ohiohomedoctor View Post
What a hack..
Dammit I knew it!!
The Following User Says Thank You to dkillianjr For This Useful Post:
ohiohomedoctor (11-04-2012)
Old 11-05-2012, 10:02 PM   #10
shelf guy's Avatar
Rewards Points: 150
Adding blocking is not an option because they are exterior walls with brick.
Ends up there is supposedly blocking in there. I guess we'll see
And when I asked about "Anchors" I was referring to something that goes in between the FG and the stud.
Old 11-05-2012, 10:55 PM   #11
Builderbob 72's Avatar
Trade: Builder/Remodeler
Rewards Points: 101
Tapcons....loooonnngggggg Tapcons!
Seriously, I had that situation on a new home that had some ADA upgrades added, grab bars in the FG tub/shower unit included. I cut a hole in the side walls, added the necessary blocking and had a manufacturer approved repair tech repair the cut. Even with the faux 6x6 pattern, you could barely see the patch.
Builderbob 72 is offline
Old 11-05-2012, 11:22 PM   #12
Why not use screws in the studs?
Old 11-06-2012, 07:55 AM   #13
go dart's Avatar
Trade: remodeling/specializing in kitchen & baths
Rewards Points: 578
I wonder if the OP is faced with adding grab bars to a Sterling shower. Very good showers but 1x4's should be glued to the b side before install as they stand off the wall a considerable distance. With no acess to the back side (outside wall?) I'd sell them a new shower.
go dart is offline
Old 11-06-2012, 08:13 AM   #14
Snobnd's Avatar
Trade: Remodeling 30+ yrs
Rewards Points: 4,572
Can you cut out the sheetrock above the shower and slide the backer down to your grab bar bolts?
The Following User Says Thank You to Snobnd For This Useful Post: Leo
Snobnd is online now
Old 11-06-2012, 09:05 AM   #15
Drywall & Painting Pro
Sir Mixalot's Avatar
Rewards Points: 8,469
Where's MacGyver when need ya him?
-Paul
TextureMaster.com
Checkout my YouTube Channel with 70,000 Subscribers and over 11,000,000
My Latest Video: https://youtu.be/E23Y-fw4KCM
YouTube Channel: https://www.youtube.com/paulpeck
Twitter Facebook Instagram YouTube
Sir Mixalot is offline
The Following User Says Thank You to Sir Mixalot For This Useful Post:
Tech Dawg (11-06-2012)
Old 11-06-2012, 09:18 AM   #16
Snobnd's Avatar
Im right here....
Old 11-07-2012, 08:45 AM   #17
shelf guy's Avatar
Rewards Points: 150
This. Its not a Sterling but there is a space of several inches between the FG and the stud.
Check this thing out:
http://www.adaptiveaccess.com/solidmount.php
Old 11-07-2012, 08:51 AM   #18
Talking Head
EthanB's Avatar
Rewards Points: 388
Several inches? What is the surround attached to?
I'd try to cut out a piece of the drywall and slide some blocking in there as well, for what it's worth.
Planer.....
EthanB is offline
Old 11-10-2012, 05:57 PM   #19
goneelkn's Avatar
Trade: home remodel/repair
Rewards Points: 26
If it's not a "couple inches", i've used these.
http://www.grabbarspecialists.com/pr...-Mount&cat=822
goneelkn is offline
Old 11-10-2012, 07:34 PM   #20
slowsol's Avatar
Rewards Points: 2,248
Sterling Tub surrounds generally have a couple inches between the fiberglass and the wall studs. At least everyone I've ever installed.
-John
slowsol is offline
Fiberglass Shower Replacement - Harrisburg, PA Tech Dawg Remodeling Picture Post 43 02-18-2012 10:40 AM
Pool Finish - Fiberglass cesinstructor Pool Construction & Enclosures 0 06-27-2011 07:13 PM
staining a fiberglass door Traditions2 Painting & Finish Work 11 01-28-2009 02:11 PM
