How To Remove Mineral Deposits From Corian? - Kitchens & Baths - Contractor Talk
Old 03-21-2015, 07:25 PM   #1
jranaudo's Avatar
Trade: tile
Rewards Points: 14
ok guys, my customer has asked me for some help. Corian bathroom sink. One section about 5" x3" has pretty thick mineral deposits from hard water. How do I go about removing it?
I tried vinegar but its just too thick.
I tried scraping with a hand tool and while it works I do end up scratching the service so I stopped after a bit.
I was thinking about using some kind of sanding. It's a bit tricky because it's in the curved part of the sink.
Any suggestion on how to do this? I can post a picture if needed.
jranaudo is offline
Old 03-21-2015, 10:35 PM   #2
mtmtnman's Avatar
Trade: REO Svs, Remodeling, Landscaping & Snowplowing
Rewards Points: 1,146
Re: How To Remove Mineral Deposits From Corian?
Pummice stones work on Porcelain. Not sure on Corian...........
mtmtnman is offline
Old 03-21-2015, 10:48 PM   #3
hdavis's Avatar
Rewards Points: 1,640
I've never seen it too thick for vinegar. Cover it with paper towels, pour the vinegar over the paper towels, come back the next day. Don't get the vinegar on any fixture - some of them have finishes that will be attacked by vinegar. Use a white pad (plastic shower safe) to scrub.
Repeat if necessary.
If you sand Corian, you're going to be hiring a qualified Corian finisher to clean up your mess...
hdavis is online now
Old 03-21-2015, 11:04 PM   #4
KAP's Avatar
Trade: Custom
Rewards Points: 40,124
Sanding... but if you haven't done it before, you are better of getting a Corian certified guy to do it and watch him...
KAP is offline
The Following User Says Thank You to KAP For This Useful Post:
hdavis (03-22-2015)
Old 03-21-2015, 11:29 PM   #5
m1911's Avatar
Trade: finish carpenter
Rewards Points: 15,632
Clr
Originally Posted by tipitop View Post
That guy in video have mental issues plus eat hole turtle from some reason
m1911 is offline
Old 03-21-2015, 11:36 PM   #6
jranaudo's Avatar
Trade: tile
Rewards Points: 14
Thanks folks!
jranaudo is offline
Old 03-22-2015, 05:31 AM   #7
Dave in Pa's Avatar
Trade: restoration/remodeling
Rewards Points: 1,272
get a Scotch-brite pad, rub with it. If you can find the purple color ones anywhere. If needed, use some 220 sandpaper, then the pad to return to the proper finish. Do the entire top, as needed to bring to a consistent finish, be careful near the splash area for the silicon.
Dave in Pa is offline
to remove or not to remove Friend Roofing 21 02-12-2013 11:32 PM
[Leaking Roof] how do I remove old mastic/elastomeric coating? plasticslug Roofing 1 01-26-2013 06:24 PM
