How To Flange - Kitchens & Baths - Contractor Talk
How To Flange
Old 11-11-2006, 08:03 PM   #1
troyamuso's Avatar
Rewards Points: 25
How To Flange
I'm tiling a bathroom floor. I'm putting 1/4" hardi backer down first. Does the rim of the toilet flange drain have to sit on top of the tile or do I screw it into the HB sub floor and tile up to the edge of it. If I tile up to the edge of it does that leave the flange to flush with the floor to get a good seal with the toilet?
troyamuso is offline
Old 11-11-2006, 10:04 PM   #2
Mike Finley's Avatar
Trade: Bathroom Remodeling
Rewards Points: 2,000
Re: How To Flange
1/4 to 1/2 above or below the finished floor can be dealt with simply by the size of the wax ring you buy.Ideally the flange should be flush with finished floor. Almost always we end up with the flange 1/4 below finish level.
Mike Finley is offline
Old 11-11-2006, 11:56 PM   #3
troyamuso's Avatar
Rewards Points: 25
Re: How To Flange
That helps, thanks Mike.
Old 11-12-2006, 12:25 AM   #4
cmwacasey's Avatar
Rewards Points: 150
Re: How To Flange
I would like to see the flange above the tile.tileing to the flange is done all the time
cmwacasey is offline
Toilet and the Flange troyamuso Kitchens & Baths 22 04-02-2007 12:50 AM
Toilet flange C.C.R. Plumbing 11 01-06-2007 02:48 PM
New help with this toilet flange Mike Finley Plumbing 2 06-16-2006 08:27 AM
closet flange Vermonster Plumbing 3 02-15-2006 08:43 AM
Set-Rite - Toilet Flange Spacer System The Inspector Plumbing 24 10-13-2005 09:38 PM
