Drilling Granite Counter Tops? - Page 2 - Kitchens & Baths - Contractor Talk
Old 04-29-2014, 10:26 PM   #21
CarpenterSFO's Avatar
Rewards Points: 2,044
Re: Drilling Granite Counter Tops?
Undermount sinks going in at the same time?
- Bob
CarpenterSFO is offline
Old 04-29-2014, 10:29 PM   #22
Fire up the BBQ
griz's Avatar
Rewards Points: 1,982
Check these guys out...
I couldn't imagine doing that many holes w/o a drill press.
http://www.powrgrip.com/cgi-bin/powr...ral_other.html
griz is online now
Old 04-29-2014, 10:38 PM   #23
Dirtywhiteboy's Avatar
Rewards Points: 14,692
I have no info on the sink, that's not us.
Dirtywhiteboy is offline
Old 04-29-2014, 10:41 PM   #24
That looks nice Griz but it looks like this yellow tan granite is the soft stuff and the goes through fast. Also not much room in back of the sink hole for the vac. cup.
Old 04-29-2014, 11:06 PM   #25
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,500
Those bits you posted Dirty will work perfect. A variable speed grinder will be best. Check the rpm max on those bits. Also they sell a rubber o ring that creates a damn around the bit. It seals to the top and then you can put water inside the ring to keep the bit cool. Something like this.
http://www.toolocity.com/water-conta...ll-bits-3.aspx
overanalyze is online now
Old 04-29-2014, 11:07 PM   #26
Champion Thread Derailer
Jeff G's Avatar
Trade: Home Renovations
Rewards Points: 380
Sounds like you may already be aware, but the darker the granite the harder it usually is. This would have an affect on how long your bit lasts. Keep us posted, if you will, about what works best!
Jeff G is offline
Old 04-29-2014, 11:12 PM   #27
thanks OverA that looks good, better than the puddy.
Yes I learned today that the darker the stone the harder. I one fab guy I talked to today called himself Rock He said the yellow and tan was soft. He was super nice and I'll need to stop by his shop with some beer for the help.
overanalyze (04-29-2014)
Old 04-29-2014, 11:53 PM   #28
They must not be undermount, else you'd be involved, if you're installing the counters. What type of high-rise? Hotel? Condos?
- Bob
Old 04-30-2014, 12:19 AM   #29
It's low income housing. They don't even get a dish washer
CarpenterSFO (04-30-2014)
Old 04-30-2014, 12:24 AM   #30
No undermount sinks then. It's funny how granite countertops have become a budget choice. Given that hawaii is closer to China it could be less expensive than here...
- Bob
Old 04-30-2014, 12:25 AM   #31
kiteman's Avatar
Rewards Points: 16
But they get granite! That means they can be on House Hunters.
An old framer once told me "For years I thought I was the best damn carpenter in California. Come to find out I'm just competent."
kiteman is offline
Old 04-30-2014, 05:52 AM   #32
rrk's Avatar
Rewards Points: 4,902
My guys do it wet or dry, after install or before. Bits last longer dry.
They either pack the inside of the bit with ice or use duct tape to make a dam and put water in the dam, small bucket goes in the cabinet to catch water. 2 minutes or less to drill
That rubber ring may not work with the lighter color granite due to the small fissures not sealing the suction.
Also since it is probably cheap granite more fissures are likely as well as softer granite.
rrk is online now
Old 04-30-2014, 06:47 AM   #33
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
Thick granite to boot.
Inner10 is offline
Old 04-30-2014, 09:32 AM   #34
Anti-wingnut's Avatar
Rewards Points: 3,430
Not really. The minerals making up granite and the like all have Moh hardnesses of five to seven, with the dark hornblende being on the low end, and the light quartz and dark olivine being on the upper end.
Building materials referred to as marble are quite soft in comparison to the basalt, "granite" and crystalline rocks typical of modern counter tops and flooring.
I have a degree, and attended grad school in geology.
Anti-wingnut is offline
The Following User Says Thank You to Anti-wingnut For This Useful Post:
BlueRidgeGreen (09-11-2014)
Old 04-30-2014, 10:48 AM   #35
Wood Craftsman
PrestigeR&D's Avatar
Rewards Points: 4,642
Lightbulb
Use plumbers putty , make a rope and use it to form a sealed circle around the hole your cutting , fill with water ....etc..etc..etc...
JMPOV,
B,
PrestigeR&D is offline
Old 04-30-2014, 08:08 PM   #36
rrk's Avatar
JMPOV,
Regular plumbers putty will stain the granite, especially lighter colors.
rrk is online now
The Following 4 Users Say Thank You to rrk For This Useful Post:
Dirtywhiteboy (04-30-2014), Doctor Handyman (05-01-2014), m1911 (05-01-2014), overanalyze (04-30-2014)
Old 05-01-2014, 01:11 AM   #37
No boat from China stops here. It must go to Long beach and get loaded on to a US registered ship then to Hawaii. It's called the Jones act.
CarpenterSFO (05-01-2014)
Old 05-01-2014, 01:14 AM   #38
It gets no sub plywood counter and doesn't need glue up bull nose to cover the ply edge. They just turn the edge and polish and it's good to go.
Old 05-01-2014, 01:18 AM   #39
m1911's Avatar
Trade: finish carpenter
Rewards Points: 15,632
do they have an open spot for the DW at least?
m1911 is offline
Old 05-01-2014, 02:00 AM   #40
This has not started yet but I don't see why they would. It's a high rise building.
Poor Granite Counter Install llenod Remodeling 14 12-19-2012 01:02 PM
Safely Removing Granite Counter & Backsplash ? Ever Done? plazaman General Discussion 16 11-28-2012 09:07 AM
Bad Granite Counter Installation - Help please! coveinspiration Kitchens & Baths 52 03-08-2012 06:28 PM
Bookcases and Granite Tops blackte Finish Carpentry 4 07-02-2010 06:49 PM
Drilling holes in granite zipicus Tools & Equipment 8 09-12-2009 09:57 PM
