Cupped Laminate Tops - Kitchens & Baths - Contractor Talk
Old 06-18-2015, 11:06 PM   #1
nwksremodeler's Avatar
Trade: a little bit of everything, roofing, windows, doors, kitchen & bath remodels
Rewards Points: 244
What I am dealing with is brand new tops that are particle board substrate and are excessively cupped. For instance i have a butt joint that I am currently working on that is cupped both length and width wise. Each side is about 6' long and when the joint is joined and the top secured to the wall brackets and cleats after having one person applying all his weight while securing this leaves the butt joint about a 1/4" higher than the rest of the top. I back beveled the butt joint on both sides to fit the laminate edge better. The shop that the tops came from suggested laying them on saw horses and adding weight to the ends and counter acting the cupping action 1-3 days for this. I figure if they are currently cup they would return after the weight is removed. I did try adding some home made brackets to help pull the butt joint down but got little results. Any other suggestions.
nwksremodeler is offline
Old 06-18-2015, 11:21 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 636
Re: Cupped Laminate Tops
Bad substrate or it got wet.
griz is offline
Old 06-19-2015, 01:07 AM   #3
mako1's Avatar
Rewards Points: 1,094
I place of your supplier giving suggestions to fix them they should be spending the time making new tops.
mako1 is offline
The Following User Says Thank You to mako1 For This Useful Post:
SmallTownGuy (06-19-2015)
Old 06-19-2015, 05:55 AM   #4
KAP's Avatar
Trade: Custom
Rewards Points: 36,912
New tops... particle board doesn't go back in time...
KAP is offline
Old 06-19-2015, 07:16 AM   #5
Rewards Points: 244
My thoughts exactly. I think they are coming up with other ideas since they have already spent a ton of time/money reworking cabinets that they built for this job. Thanks.
cutting and joining laminate counter tops nwksremodeler Kitchens & Baths 15 01-12-2014 10:54 PM
New guy with a question about laminate tops greenleafhs Finish Carpentry 8 09-23-2013 08:16 AM
Laminate to tile back splash nwksremodeler Kitchens & Baths 2 10-29-2012 01:10 PM
vapor barrier and laminate with pad attached bluebird5 Flooring 9 07-14-2012 07:28 PM
sealing seams in laminate tops AustinDB Kitchens & Baths 13 08-13-2011 12:13 PM
