Corian Countertop - Kitchens & Baths - Contractor Talk
Corian Countertop
Old 12-04-2006, 09:41 PM   #1
my own boss
supercrew's Avatar
Trade: carpenter
Rewards Points: 75
Corian Countertop
last wednesday, the 7th?..i started this corian(sp) countertop, it was around 65 degrees, forcasted to drop in the teens by friday morning, so i got it all glued up wed. evening thinking i was gonna finish it thurs. a.m. the storm hit early so this top sat in below freezing since friday afternoon.
dim. 1/2" x 8'L x (center 36") 30"W w/3"radii x (one end w/8" radii) 24"W and the other 24" end square. sorry, best discription i got with no picture.
so i make my profile on the top and precede to build the faces down to 3 layers. i got the high speed gluegun, im making sure i got glue squirtin out the sides everywhere, every thing was positioned and clamped within 2 minutes and i waited 60 minutes before i removed the clamps and moved it for the first run.
monday a.m. 17 degrees, i show up and turn the heat on, a little bullet kerosene, i take all the clamps off , and with a guy on each end, holding towards the center of the front, we slowly start to stand it . halfway up it sounded like it broke in half.
the face of my 36 x 30 has a seperation line between the top and the middle layer. i have one inside radius that seemed to also have"broken".
i have several questions on this material so all responses are welcomed.
1.glue
2.clamps
3.working temperatures
im worried that even if i cut the face back, is it possible the the bond has cracked through out and i will always have some "seperation lines" in the face?
i only work off drawings
supercrew is offline
add corbels to an EXISTING granite tile countertop jkrause Remodeling 4 06-28-2007 04:50 AM
Best substrate for p-lam countertop C.C.R. General Discussion 4 03-28-2007 08:37 PM
My first concrete countertop 6stringmason Masonry 20 10-05-2006 07:22 PM
Adhesive gun for Corian type countertops gtcway Tools & Equipment 0 08-28-2006 09:52 PM
Stain on granite countertop gtcway Remodeling 10 02-19-2006 01:28 AM
