Concealed Hinge For 3/8 Lipped Cabinet Doors - Kitchens & Baths - Contractor Talk
Old 10-17-2018, 04:31 PM   #1
RedMonte85's Avatar
Rewards Points: 28
I am looking for some concealed hinges for some 3/8" lipped cabinet doors going over a face frame. I called blum and they said model #71T7600N would work for my application. I will be blocking out the inside of the cabinets so that I can attach the hinge. Will this work for 1960's style cabinets with a lip? I tried using a soft close blum hinge and the lip of the door hits the cabinet face after opening about half way. Thanks for the help
RedMonte85 is offline
Old 10-17-2018, 08:20 PM   #2
tjbnwi's Avatar
Rewards Points: 116
Re: Concealed Hinge For 3/8 Lipped Cabinet Doors
I've never used it in your application, but have used them often. The hinge is the same one used on bifold doors used in 90 corner cabinets. Go to a local big box store and check out their operation on one of the displays.
You should be able to use 175H6030 mounting plates. They'll attach directly to the face frame.
Screen shot of installation on a lipped doors from Blums manual.
tjbnwi is online now
Old 10-17-2018, 11:29 PM   #3
RedMonte85's Avatar
Rewards Points: 28
Thanks, ill order a couple and give them a shot. Blum also suggested using the 173H7130 bracket. Whatever bracket I end up using wont be able to attach to the edge of the face frame like most cabinets because its partially inset 3/8"
Old 10-18-2018, 07:57 AM   #4
tjbnwi's Avatar
Rewards Points: 116
Blum makes face frame brackets with the holes offset to the rear of the face frame.
Old 10-18-2018, 09:43 AM   #5
RedMonte85's Avatar
Rewards Points: 28
Do you by any chance know the model number of those mounting plates you speak of?
Old 10-18-2018, 05:53 PM   #6
RedMonte85's Avatar
Rewards Points: 28
Also, would the Grass # F028138564217 work for me? Its a soft close hinge and opposed to the self closing type
Old 10-18-2018, 10:02 PM   #7
tjbnwi's Avatar
Rewards Points: 116
The 175L6630.22 has the offset holes.
I don't know about the Grass hinge. I do know you can add the 973A7000 Blumotion module to the Blum hinge.
Hinge Placement for Interior Doors Spencer Finish Carpentry 73 02-06-2015 08:16 AM
The Showcase Cabinet Kent Whitten Carpentry Picture Post 54 12-30-2012 02:30 PM
cabinet doors nobleremodel Finish Carpentry 31 12-18-2012 07:13 PM
While assembling cabinet doors? mattsk8 Finish Carpentry 13 06-12-2010 08:53 AM
Cabinet re-face (doors only) [email protected] Remodeling 12 01-14-2010 04:42 PM
