Cast Iron Tub Removal - Kitchens & Baths - Contractor Talk
Old 11-04-2012, 06:45 PM   #1
FHBGA's Avatar
I've got to remove a cast iron tub tomorrow so that I can start building another tile shower. My plumber told me to just beat it apart with a sledge hammer but that seems to be a lot of work? Has anyone found any tricks in getting these big heavy mothers out?
FHBGA is offline
Old 11-04-2012, 06:47 PM   #2
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
Re: Cast Iron Tub Removal
If it's on a 2nd floor, be careful. All the beating can upset the ceiling below.
Otherwise, yes. A sledge can handle a cast iron tub demolition.
Angus
angus242 is offline
Old 11-04-2012, 06:49 PM   #3
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
Wear glasses.
ohiohomedoctor is offline
Old 11-04-2012, 06:52 PM   #4
rselectric1's Avatar
Rewards Points: 888
This is about the only operation on an inside remodel where I feel it's acceptable to use a sledge. As Angus said, be mindful of the floor. Also remember to take any wall hangings off the other side of the wall.
rselectric1 is online now
Old 11-04-2012, 06:54 PM   #5
A-1 Interiors's Avatar
Trade: Home Improvement
Rewards Points: 298
I just did one about 3 weeks ago and yeah it was a bit of work (i broke it up with sledge )
I started making good progress when i hit it with the beveled edge of the hammer head but its loud and alot of shock waves , If you break it up ask h/o to remove pics or mirrors nearby
A-1 Interiors is offline
Old 11-04-2012, 06:56 PM   #6
You could put rubber pads under the feet to reduce harmful vibration.
Old 11-04-2012, 07:28 PM   #7
Future Post Deleter...
rex's Avatar
Trade: Nothing
Rewards Points: 1,092
Be a man and carry it out.
rex is offline
The Following 2 Users Say Thank You to rex For This Useful Post:
Tech Dawg (11-11-2012), TNTRenovate (11-04-2012)
Old 11-04-2012, 08:05 PM   #8
donerightwyo's Avatar
Trade: custom builder
Rewards Points: 122
I bought a guy a new floor when I was 19 cause I thought I was a man.
I start on the front and break the apron off right down the middle where the shower door would sit. Then break whats left in half. Thirds are pretty doable. Somebody on here once said to cover with a drop cloth first. Seems like a good idea as the porcelain comes of like glass shards.
I can't compete with hacks.
donerightwyo is offline
Old 11-04-2012, 08:18 PM   #9
r4r&r's Avatar
Trade: Contractor
Use hearing protection or you'll be screaming at people for the rest of the day. Also don't swing so that you are hitting pieces back toward yourself, my shin is still sore from the two hunks of marble from the tub I busted up over two weeks ago.
A sledge is perfectly acceptable for busting up pink cultured marble as well.
r4r&r is offline
Old 11-04-2012, 08:36 PM   #10
kambrooks's Avatar
Rewards Points: 572
When I can't smash it, I cut it up. Takes about the same amount of time, less energy, different kind of messy.
Diamond blade on a grinder thru porcelain and then a metal cutoff.
In half is okay if you have help.
Kameron Brooks
www.iFixHomeImprovement.com
kambrooks is offline
Old 11-04-2012, 09:33 PM   #11
Kitchen Customizer
ryanshull's Avatar
Trade: Interior Remodeling
Rewards Points: 310
BFH, not a 3lb sledge
ryanshull is offline
Old 11-04-2012, 09:41 PM   #12
Hair Splitter
TNTRenovate's Avatar
Trade: General
Rewards Points: 1,268
I used to beat them out, then I cut them out, and now I just friggin pull them out. They come out in about 30 minutes. Pull the drain. Lift it from the back, clear the plumbing stand it up right. Grab an applaiance dolly, strap it in and walk it down with two guys on the bottom.
No need to beat it to death and get all hot and bothered. No need to throw friggin' hot metal everywhere and breathe in all that crap.
I have one tomorrow. We are pulling the tub, the surround walls and replacing with a shower. We will have it demo'ed, plumbers in to do their thing, then set the pan by lunch. I should be able to have the walls rocked and maybe one coat of AD by the end of the day tomorrow.
Tried & True on Facebook
Tried & True Website
TNTRenovate is offline
Old 11-04-2012, 10:09 PM   #13
Chopsaw Chick's Avatar
Rewards Points: 589
I call my metal scrap guy and he makes it go away. You guys are working way too hard!
Chopsaw Chick is offline
The Following 2 Users Say Thank You to Chopsaw Chick For This Useful Post:
kambrooks (11-04-2012), TNTRenovate (11-04-2012)
Old 11-04-2012, 10:16 PM   #14
Hair Splitter
Trade: General
As long as he is insured and has his own WC.
Old 11-04-2012, 10:21 PM   #15
Chad McDade's Avatar
Trade: Carpenter/GC
Rewards Points: 350
I have to agree with pulling the tub out. Breaking a cast tub with a sledge makes a heck of a mess, it's loud, and all the beating is pretty rough on ceilings under the tub and on any walls around the tub.
__________________________________________________ ____________________________________________
“When the only tool you have is a hammer, you tend to see every problem as a nail.” - Abraham Maslow
Chad McDade is offline
Old 11-04-2012, 10:21 PM   #16
Metal scrap guys are funny. I have been using got junk for my special loads. I even got them to clean an entire jobsite and they billed me for the 1/4 load it ended up being. Dont tell me youll get the trash from anywhere.. : whistling
Old 11-04-2012, 10:29 PM   #17
FHBGA's Avatar
Its on a second floor so I am worried about the ceiling on the main floor. Below is the dining room. My only worries are the existing tile floor is staying. Prying the tub up off the floor is where I do not want to mess the tile up.
FHBGA is offline
Old 11-04-2012, 10:36 PM   #18
Hair Splitter
Trade: General
You don't need to pry the tub up at the tile. You just need to cut away any caulk and remove any grout between the tub and the tile.
Remove the surround walls and lift from the back. You may have to play with it a bit to get it loose but it will eventually break free.
Old 11-04-2012, 11:57 PM   #19
Rewards Points: 589
Okay, good point. My metal guy doesn't even have insurance for his truck (as required by law around here) much less contractor's liability insurance. Plus, presentation isn't an issue. I'm working exclusively on vacant properties that I own. So it's not an issue that the guy is missing both fingers and teeth - until the neighbor's call the cops on him and I have to explain to the local PD that he has my permission to be there! Okay, sorry, it seemed like a good suggestion at the time!
The Following User Says Thank You to Chopsaw Chick For This Useful Post:
TNTRenovate (11-05-2012)
Old 11-05-2012, 12:02 AM   #20
Hair Splitter
Trade: General
But think about this. If you own the property, then it is your HO policy that has to cover if he gets injured while pulling one of your tubs. He could end up owning one of your houses and then some. Just be careful.
Cutting into existing cast iron waste pipe. Plumberman860 Plumbing 64 09-28-2014 12:28 PM
replacing cast iron hw radiators w/ hot water baseboards nycphotography Plumbing 15 08-24-2012 08:14 PM
Cast iron tub removal? dkillianjr Remodeling 72 02-14-2012 11:11 PM
ABS to cast iron? pzeiler Plumbing 9 06-09-2010 09:57 AM
Cast iron shower pans?? ruskent Remodeling 18 11-24-2009 08:29 PM
