Bathroom Moisture Issue!! - Kitchens & Baths - Contractor Talk
Old 03-20-2015, 08:56 PM   #1
jay@ECC's Avatar
Trade: Remodelers
Rewards Points: 8
I recently had a client call me on a bathroom moisture problem..I revisited the site to unfortunately see a moisture buildup like I've never seen...condensation was literally running down the walls and ceiling!! Fan was sized accordingly to square footage and working from both ends??
Any advice??
jay@ECC is offline
Old 03-20-2015, 09:08 PM   #2
EricBrancard's Avatar
Trade: GC/Remodeling
Rewards Points: 986
Re: Bathroom Moisture Issue!!
Any advice??
Not enough make up air for the fan to work effectively.
EricBrancard is offline
The Following 5 Users Say Thank You to EricBrancard For This Useful Post:
griz (03-20-2015), hdavis (03-20-2015), j_sims (03-21-2015), rselectric1 (03-20-2015), slowsol (03-20-2015)
Old 03-20-2015, 09:36 PM   #3
hdavis's Avatar
Rewards Points: 1,186
Also, vent restricted or blocked.
I've also seen this from people swabbing the floor, shower, etc, and once from someone setting up drying racks for clothes....
hdavis is online now
Old 03-20-2015, 09:39 PM   #4
Fire up the BBQ
griz's Avatar
Rewards Points: 1,974
Any advice??
But is it sized for volume & conditions.
Plus what Eric said.
griz is online now
Old 03-20-2015, 10:40 PM   #5
mski's Avatar
Trade: home improvements
Rewards Points: 502
In wintertime it happens in our one bathroom when my 6 year old takes a shower.
The exterior wall is rock-lathe plaster on furring strips over masonry block. No insulation.
There is a fan and it's sized accordingly and vented through the roof.
The exterior wall is cold and the warm moisture bath air condensates to where the moisture runs down the wall. Only happens to the exterior wall section.
The bath was remodeled when we bought the house. One thing I do notice there is very limited gap from the door bottom to the threshold.
I believe cutting the bottom of the door to increase the gap to about an 1" to get more make-up air should help.
It should be about the same concept of having supply ducts for HVAC in a room but the return in the hallway ceiling. Door bottoms are cut for air flow back to the return.
mski is offline
The Following User Says Thank You to mski For This Useful Post:
hdavis (03-20-2015)
Old 03-20-2015, 10:50 PM   #6
CO762's Avatar
Trade: Organic Mold Farmer
Rewards Points: 4,534
This happens in every steam bath I've been in.
NY Times...."Prison Population Growing Although Crime Rate Drops..."
CO762 is offline
Old 03-21-2015, 09:28 AM   #7
jay@ECC's Avatar
Trade: Remodelers
Rewards Points: 8
I have plenty of make up air..and yes vented through the roof...I think I'm going to just put a really high cfm unit in and hope for the best...the picture window and skylight are probably not helping with this cold winter either!!
jay@ECC is offline
Moisture issues denco5 Sandblasting 6 09-09-2012 06:05 PM
Handicapped ADA Bathroom Commercial SUPPLY - online ?? KYTravis General Discussion 5 12-09-2010 09:14 AM
Clothing Closet in Bathroom - Concerned? EricAnderson Kitchens & Baths 2 06-22-2010 10:36 PM
condensation issue altonarch New Member Introductions 3 11-23-2008 10:51 PM
redguard on densGuard trap moisture? wopachop Tiling 14 11-20-2008 02:09 PM
