Backlighting Onyx In A Shower - Kitchens & Baths - Contractor Talk
Old 11-16-2011, 12:16 PM   #1
monica2's Avatar
I have a project whereby the owner would like to backlight an entire wall in a stand-up spa/shower. I have consulted a few 'experts' and am not satisfied that solutions offered are best in terms of uniformity of light dispersement, maintenence/access, intensity, (would potentially like to control intensity of illumination--will rheostat work with LED's for example...).
I live in Evergreen, CO.
Any input is appreciated! Thanks.
Monica
monica2 is offline
Old 11-16-2011, 03:17 PM   #2
TxElectrician's Avatar
Trade: Electrical
Rewards Points: 410
Re: Backlighting Onyx In A Shower
I have no experience in this, but here is a good discussion on the matter
http://www.contractortalk.com/f5/bac...tertops-24752/ Hope that helps.
TxElectrician is offline
The Following User Says Thank You to TxElectrician For This Useful Post:
pkp4911 (11-18-2011)
Old 11-19-2011, 11:23 AM   #3
JohnFRWhipple's Avatar
Trade: Linear shower drain installations & waterproofing
Rewards Points: 2,000
Backlighting Stone in a Shower Stall
There are not many examples of back lit stone in showers and pulling it off in the field must be tricky.
First and foremost does this project have city inspections and permits pulled?
How will you attache the the stone?
I have found that you need to keep a light source at least 2" - 4" away from the back side to remove hot spots. We have been working with laminated glass as a diffuser and tying this into our shower builds with Kerdi Fix or Liquid waterproofing as a way of tying in the white lami glass to the shower's waterproofing.
Can you post a drawing of the space and perhaps a solution will come to light - sort of speak.
We are doing a new project in China Town that is tying in commercial grade windows into a steam shower. The process is difficult and we still have not found all the solutions. So far we have got the linear drain installed and all the walls and the ceiling waterproofed.
The next step will be setting the glass panel in and ensuring that it is sealed to the showers waterproofing. This will also be a steam unit and extra care is being taken.
Here is a fine example of even light on an ACO linear drain installation. Something like this would be a great light source for your project I would think.
JohnFRWhipple is offline
Old 11-19-2011, 11:35 AM   #4
Back Lit Stone in Bathrooms
Here is a killer bathroom I found on Houzz.com
Is this the look your after?
The picture was taken by Elad Gonen & Zeev Beech of www.segev-photography.com. Perhaps you could email them and track down the builder for ideas??? The Architect on this project was Linenberg Rozen Architects: their contact information can be found here ---> www.r-l-arch.com
Old 11-19-2011, 11:53 AM   #5
Choosing your light source for back lit stone
Nu World LED light panels look like a good option. Here is a little information on them;
Nu World LED light panels may be mounted to the wall, ceiling or floor by several means. Mounting clips and fasteners such as “mirror clips” or other similar hardware may be used to secure the LED panel. Be careful not to apply too much pressure on the acrylic panel as it may crack or break under stress.
Nu World LED panels are designed with unique heat sinks which dissipate the heat generated by the LEDs. This allows the panel to be directly mounted to walls by drilling holes at locations on the panel that are away from the sides where the LED lights and heat sinks are located. A minimum distance of 2” from the edges of the panel is recommended.
* Source
Notice the talk about the heat build up. Regardless of the type of the light source you choose I would think you need to address the heat that will build up in the assembly. When I designed my side lit feature in Yaletown we left 1/2" spaces top and bottom for air flow. In a shower project this of course will need to be done in the lighting cabinet. So then the question is how you supply heat to escape and also stop the light as well from shining out of the cabinet.
Can't wait to see your project come together. This job of yours and building a glass block wall all lit with LED's are on my two "Wish List" projects and I pitch them to all my clients. So far no takers.
This feature was built with White Lami glass and T5 bulbs but gives little light.
The light feature next to the mirror used a double LED strip and where very bright.
We are building a LED side lit niche shelf in West Vancouver right now but that pales in comparsion to a back lit Onyx shower.
* Source
Old 03-05-2012, 08:44 PM   #6
briandegravegc's Avatar
I realize that this an older post but I did exactly this for a client back in 08.
It's still holding strong.
The slab was 3' x 5' and was affixed to the same.size sheet of plexiglass.
It was quite involved so I would advise anyone looking to price this out to not cut yourself short.
Here is a link to the series of pics.
http://s381.photobucket.com/albums/o...onyx%20shower/
If anyone else needs any advice, let me know. Is be happy to help. Since I have already spent all the time researching the technical aspects, you can jump right in with less time upfront. I think I've handled factors such as expansion and contraction, moisture sealing, etc.
Hope things worked out for you Monica. Sorry I missed your post at the time you needed it.
Brian
briandegravegc is offline
Old 11-07-2012, 11:09 PM   #7
tblocks's Avatar
Trade: General Contractor SF Bay Area
Hi Brian,
Awesome information in your photobucket! Thanks. Did your building department care that you'd never have access to the lights again ....or did you have a plan for that?
Thanks,
Todd
tblocks is offline
Old 09-09-2015, 05:43 PM   #8
Johnpietracupa's Avatar
Trade: Custom Lighting fabricator
Rewards Points: 73
Forwarded on from the boss:
Hey John
I know its very late but thanks for the mention
Cheers
Mathew Barlett
Nu World Distribution Inc
http://www.nu-wo.com/
John P
Custom Stone Guy
Reseller and installer for Nu World Custom Lighting
Johnpietracupa is offline
Custom shower base - granite Charles_cz Tiling 16 01-08-2015 09:34 PM
Strange shower leak - need help JSMHDM Plumbing 13 12-06-2010 05:38 AM
tub spout to shower wand lshomesolutions Plumbing 1 06-08-2010 08:42 PM
