Apartment Condos - Kitchens & Baths - Contractor Talk
Apartment Condos
Old 05-21-2012, 02:30 PM   #1
sbcontracting's Avatar
Trade: General Contracting
Rewards Points: 562
Apartment Condos
I'm about to look at a job in a condo - bathroom is on 4th or 5th floor, concrete.
They want to change the layout. How possible is this? Specifically:
--Convert bathtub to bath/shower combo. Appears there is a double wall for the plumbing, shouldnt be a problem.
--Remove a shower, and convert to storage. Not sure on how condo rules apply to changing plumbing. My guess is you can't mess w/ structural/fixed elements like concrete walls, floors, firewalls, etc. But not sure about a shower drain - can it be capped?
I was in a condo not so long ago where they plugged a drain for a washing machine - but the shower in this case is in the floor.
Ideas? Just want to be prepared for the estimate.
Ottawa General Contractor
http://www.springer-boyd.com
sbcontracting is offline
Old 05-30-2012, 11:59 AM   #2
JohnFRWhipple's Avatar
Trade: Linear shower drain installations & waterproofing
Rewards Points: 2,000
Re: Apartment Condos
Steve a lot of my projects here in Vancouver are in high rise condo's. You will need to consider the installation of fire blocking in all your repair work and work in brass, copper, steel or cast iron fixtures.
Quick Drain USA has a side outlet linear drain that can work magic in revamping an entire condo. Give me a call and I'll tell you more about it.
JW
JohnFRWhipple is offline
Old 05-30-2012, 08:36 PM   #3
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 890
does that double wall have a vent stack or drain from upper floors?
sunkist is offline
Old 05-31-2012, 12:04 PM   #4
Rewards Points: 562
It's funny how apartments or condo's require a designer or architect for approval of a permit. Because a designer or architect was probably the one responsible for doing the initial design which is a little strange.
I would just want to plug the shower drain and remove it, if anything. The double wall likely is a common wall with vent/drain for units. The ceiling is also a foot lower to accommodate the bathroom for the unit one floor above.
Old 05-31-2012, 05:04 PM   #5
General Contractor
greg24k's Avatar
Rewards Points: 8,666
Here they also have condo associations, same goes for townhouses, you have to submit application to the board if you want to make changes to the unit, even if you replacing outside stairs, you have to get a letter of approval, because everything must meet theirs requirements.
Some associations also hire architects to review the proposed changes to the structure and if they turn it down, township will not issue permit without approval letter from the association.
I looked at addition a few months ago, they wanted convert the cathedral ceiling area into a 3d bedroom, like some of the models had and association turned them down, now they in a lawsuit.
greg24k is offline
Apartment Complex not paying for work done THATOKGIRLUKNOW Business 21 06-17-2013 06:34 PM
New-Build Apartment Karndean Man Construction 4 02-11-2012 07:22 PM
Historic apartment remodel suggestions HistoryIsGood Historical Restoration 22 11-17-2010 05:11 PM
apartment maintenance boman47k General Discussion 12 04-22-2010 03:35 PM
Common Attic (condo's) Fire Barrier zab General Discussion 8 03-03-2010 08:17 PM
