Adding Insulating Behind Shower Wall - Kitchens & Baths - Contractor Talk
Old 08-31-2017, 11:59 AM   #1
christoronto's Avatar
Trade: general contractor
Rewards Points: 4
Hi, building a new shower that has one wall (no plumbing) on an exterior wall. Client says original construction from outside is double brick, vapour barrier/slats, and drywall. I framed for a 3" wall in front of the old drywall to add insulation, but now I'm not sure how to handle it. Do I need to remove old drywall or let it stay? From the outside in, should it go double-brick, vapour-barrier, unfaced insulation, then shower wall? She wants Kerdi membrane on CBU so I don't want to create a "moisture sandwich" and Kerdi says no vapour barrier behind CBU. Or is it okay to leave the drywall and just add some insulation between the old drywall and the CBU? Any advice would be appreciated.
christoronto is offline
Old 08-31-2017, 09:52 PM   #2
Tom M's Avatar
Rewards Points: 11,140
Re: Adding Insulating Behind Shower Wall
unfaced, Roxul or foam board safest. Just no plastic, foil or kraft facing
Tom M is online now
Old 09-01-2017, 04:39 PM   #3
Rewards Points: 4
Thanks, Tom. Just took a peek and it's actually brick with tar paper, then foil backed drywall. Would you remove the old drywall?
Old 09-01-2017, 05:04 PM   #4
Tom M's Avatar
I would
Tom M is online now
Old 09-01-2017, 05:20 PM   #5
MarkJames's Avatar
Rewards Points: 18,873
MarkJames is offline
Old 09-01-2017, 05:21 PM   #6
MarkJames's Avatar
You shouldn't be getting moisture from the back of the shower wall, so it shouldn't really matter. It would be a dry sandwich.
Difficult to find shower leak CharlieM Tiling 36 07-18-2015 11:56 PM
Silicone for wall and Shower tile???? sergeant4743 Tiling 23 11-23-2014 11:51 PM
wall mounted shower seat GO Remodeling Tiling 5 09-09-2013 05:37 PM
Marble Wall / Floor Grout Maintenance ? We Fix Houses Tiling 4 08-14-2012 12:00 PM
Strange shower leak - need help JSMHDM Plumbing 13 12-06-2010 05:38 AM
