3'x3' Cultured Marble Shower Caulk Keeps Cracking - Kitchens & Baths - Contractor Talk
Old 11-12-2012, 11:42 AM   #1
Everend's Avatar
Trade: ET's Home Repair
Rewards Points: 170
I recaulked a shower for a customer a few months ago. The caulk cracked a few weeks later so I went back and did it over. They say it's cracked again. Obviously there is too much movement in the cultured marble wall panels for the caulk to handle. My next thought is to use a LARGE bead of silicone instead of caulk. Any ideas how we can solve this issue, short of pulling the cultured marble panels and rebuilding the shower walls?
Everend is offline
Old 11-12-2012, 12:10 PM   #2
dsconstructs's Avatar
Trade: Remodel Contractor
Rewards Points: 838
Re: 3'x3' Cultured Marble Shower Caulk Keeps Cracking
What caulk did you use? Sounds like something other than silicone.....and that would be the problem.
I always use the RTV silicone that my cultured products manufacturer stocks with no problems.
dsconstructs is offline
Old 11-12-2012, 12:52 PM   #3
Everend's Avatar
Rewards Points: 170
They wanted the colored caulk to match the marble the first time. I used LOCTITE 10 Oz. Almond Tub & Tile Latex Kitchen and Bathroom Caulk Lowes Item #: 40289 I really can't recall what I used the second time, I suspect it was white GE Silicone (I don't know if it was Silicone I or Silicone II).
So is the answer to use only, ever use silicone on cultured marble?
Everend is offline
Old 11-12-2012, 01:01 PM   #4
pro
country_huck's Avatar
Trade: Capenter/ Remodeler
Rewards Points: 768
You should ALWAYS use 100% silicone in wet areas.
Go to colorite.com and have them make you color matched 100% silicone caulking.
Nathaniel Huckins (huck)
Facebook
country_huck is offline
Old 11-12-2012, 01:04 PM   #5
Everend's Avatar
Rewards Points: 170
Ohh, cool option. Here's the corrected link http://colorriteinc.com/
Everend is offline
Old 11-12-2012, 01:15 PM   #6
pro
Rewards Points: 768
My bad trying to remember off the top of my head lol.
I get all my caulk for my tile projects from them, it's really painless. Never had an issue
Facebook
Old 11-12-2012, 04:54 PM   #7
goneelkn's Avatar
Trade: home remodel/repair
I have also used 100% sillicone caulk from the grout manufacturers. TEC and Laticrete. Lot's of color choices. Color Rite is good, but buying single tubes is crazy expensive.
Could also add a marble molding to the corners.
goneelkn is offline
Old 11-13-2012, 11:46 PM   #8
Everend's Avatar
Rewards Points: 170
That's a good idea, if the thick silicone bead doesn't hold.
thanks
Everend is offline
Old 11-13-2012, 11:53 PM   #9
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
I have been taping down both sides of my inside corners pre caulking. Lazer straight finishes. It takes time but there is a noticeable difference regaurdless of how good of a caulker you think you are, and believe Im the best.. : laughing:
ohiohomedoctor is offline
Barrier free shower Charles_cz Remodeling 62 09-18-2012 10:14 PM
Primer Cracking over Caulk go_hercules Painting & Finish Work 11 01-19-2011 08:39 PM
Cutting cultured marble kenvest Plumbing 16 11-23-2005 09:54 PM
