1st Backsplash Attempt - Kitchens & Baths - Contractor Talk
Old 01-29-2013, 10:18 AM   #1
carpenter123's Avatar
Trade: carpenter
Rewards Points: 41
im going to be installing my first backsplash in my kitchen. does anyone have any tips and tricks that they can share with me. also, can I put the tile directly over the drywall ?? its a tumbled marble 3x6 tile and ill be using thin set not mastic.
carpenter123 is offline
Old 01-29-2013, 10:31 AM   #2
Official CT Greeter!
CScalf's Avatar
Trade: General Construction
Rewards Points: 748
Re: 1st Backsplash Attempt
Just sayin'
"Your problem does not constitute an emergency on my part"
CScalf is offline
The Following User Says Thank You to CScalf For This Useful Post:
Old 01-29-2013, 03:53 PM   #3
GO Remodeling's Avatar
Rewards Points: 96
My usual starting point is the stove center line. I like equal cuts going up to the range hood. Or, start on the center line of the sink window. That will give you equal cuts on either side of the window.
To visualize the installation, you can do a dry run by picking your starting point and spacing a piece of tile + a grout joint across the countertop. Do this vertically to check how the tile hits electrical boxes,etc and how it finishes into the bottom of the cabinets.
More info would help.
GO Remodeling is offline
Old 01-29-2013, 04:00 PM   #4
Hair Splitter
TNTRenovate's Avatar
Trade: General
Rewards Points: 1,268
You can use thinset on drywall, just prime before you apply. I agree with Olzo, however keep in mind the big picture. If centering on something leaves a sliver at the end or in the corner just use your best judgement on how to adjust. Whether it's off setting the center of the stove or window or hanging over the edge a bit more, make sure that it works for your kitchen layout.
Tried & True on Facebook
Tried & True Website
TNTRenovate is offline
Old 01-29-2013, 07:51 PM   #5
Railman's Avatar
Trade: Railing
Rewards Points: 929
Be sure to use a grout matching caulk at the top to splash joint line.
Railman is offline
Old 01-29-2013, 08:06 PM   #6
kambrooks's Avatar
Rewards Points: 572
Originally Posted by CScalf
Just sayin'
Do you lay in wait with that lol?
Kameron Brooks
www.iFixHomeImprovement.com
kambrooks is offline
Backsplash question dkillianjr Tiling 25 01-18-2013 02:29 PM
Backsplash repairs Garrett Kitchens & Baths 15 01-17-2012 09:51 PM
Some install questions on $ 27. sq ft tile backsplash SKC Tiling 12 03-20-2011 08:44 AM
How much per SQ FT for a backsplash in Atlanta GA scottstirrup Kitchens & Baths 17 09-01-2009 05:10 AM
Copper backsplash ModernStyle General Discussion 11 03-15-2009 07:31 PM
