Where Do You Clean Up? - Tiling - Contractor Talk
Old 05-11-2012, 11:37 PM   #1
Hair Splitter
TNTRenovate's Avatar
Trade: General
Rewards Points: 1,268
Question
I was washing some buckets from a recent tile job. Some had grout in them, some grout water, others had mortar and the tray for the tile saw.
I am curious as to where everyone washes their crap out. I usually scrape all of the solid debris from the buckets and tray and then rinse them out in a discrete location in the yard or in a wash out tub in the laundry or basement. Any where that I do it, I feel like I am doing something wrong.
What are your thoughts? Where do you do your washing business?
Tried & True on Facebook
Tried & True Website
TNTRenovate is offline
Old 05-12-2012, 01:18 AM   #2
Scooter
Chasing Dreams's Avatar
Rewards Points: 250
Re: Where Do You Clean Up?
Buckets get caped off for the ride back to the shop. At the shop we will dump off any solids in the dumpster. Any grout water gets poured in our gravel parking lot away from the building. We never wash out down the sink.... Can cause problems down the road. I don't really like doing a "wash out" at a customers house unless we have made prior arrangements with them. Much like yourself I feel like I'm doing something I shouldn't tell my mother about.
The only two things I want to hear.....Wow, you're really expensive! I hope your not to busy.
Chasing Dreams is offline
Old 05-12-2012, 01:21 AM   #3
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
Never dump a waste bucket down a drain.
That said, try working in the basement of a high rise building in the Loop
I get to dump UNDER State St, that great street....
Angus
angus242 is offline
Old 05-12-2012, 07:01 AM   #4
hdavis's Avatar
Rewards Points: 2,186
cement based product cleanup water is done off site unless I have an agreement where I can dump it.
hdavis is online now
Old 05-12-2012, 07:17 AM   #5
DManchester's Avatar
I'm with you Rob,
I do pretty much exactly what you do. Although lately I've been letting all the grout, thinset, or cement based stuff harden, then bang it out of the bucket with a hammer once it dries. I would like to have a portable "wash station" but don't know how much of a PITA that would be.
DManchester is offline
Old 05-12-2012, 07:17 AM   #6
iDAHOchris's Avatar
Trade: dRYWALL SPECIALIST
Rewards Points: 256
If we have a bunch of muddy water we will dig a hole and dump it in there. Gypsum is great for soil
iDAHOchris is offline
Old 05-12-2012, 09:24 AM   #7
Hair Splitter
Trade: General
I was thinking the same thing. It's just a PITA to lug buckets of crap around.
Like I said, I get all of the solids out of the bucket. The only thing that gets dumped is slightly soiled water. Mostly just cloudy water.
I was thinking of an bucket insert that would filter the water out when you pulled it out of the bucket. The filter could then go right into the garbage or be made to reuse. But reusing just poses the same problem, you have to clean it out somewhere.
Old 05-12-2012, 09:30 AM   #8
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
If there's no where to get ride of solids then they stay in the gorilla tubs to set up then I just hit them with a hammer to break all the solids up but if theres dirty water then I just use the hose and rinse out in the yard and then rinse down the grass to stop it going white/gray. Also rinse my grout cleaning bucket out in the yard also.
www.bcconstructionllc.com
BCConstruction is offline
The Following User Says Thank You to BCConstruction For This Useful Post:
TNTRenovate (05-12-2012)
Old 05-12-2012, 11:14 AM   #9
There is this,
The Sludgebuster
+ YouTube Video
It's kinda expensive, but will get a lot of use. Just leave it on the site until you are done. Maybe even upsell it as a wastewater treatment , or just use it to promote your cleanup practices. Or, I'm sure you could create a similar system using a series of 5 gallon buckets. Just don't know about the chemical additives to "clean" the wastewater.
Dave Manchester
Stonecaststudios.com
The Following 2 Users Say Thank You to DManchester For This Useful Post:
DavidC (05-14-2012), Rio (05-13-2012)
Old 05-12-2012, 05:23 PM   #10
charimon's Avatar
Trade: Tile and Tool junkie
Rewards Points: 1,168
for the most part I switched to Rubbermaid Roughtotes. the 18 gal is as heavy as i want to mess with loaded with tearout. You can mix 2 bags of mortar and roll it around on a mini dolly. They are soft and flexible enough that you can let your mortar dry and flex it out the next day and use it again. Even better you can load mortar with your trowell no more digging with a margin. The dark green ones are the most durable and will last for 6-8 months. I have 8 of them that I use for trash, tools, mortar,grout, whatever. I use the lids under toilets as they keep everythign clean and the last bit of water dosnt drip all over the floor, you can also set the lid on a mini dolly and roll the toilet with out the spill or wax. 5 gal buckets are just silly once you use rough totes.
"The key is to allow only the complexity that the customer is willing to pay for."
charimon is offline
The Following 2 Users Say Thank You to charimon For This Useful Post:
alboston (05-23-2012)
Old 05-12-2012, 06:31 PM   #11
KAP's Avatar
Trade: Custom
Rewards Points: 40,208
Solids in one bucket... spray/cap... rinse the others...
KAP is offline
Old 05-12-2012, 07:46 PM   #12
davitk's Avatar
Trade: Perfessional Contracter
Rewards Points: 502
I ask the customer at the start of the job, where they want the wash out. Typically I suggest a place close to the curb, sometimes they request a special place like by the lot line where it'll drain into the neighbors yard.
davitk is offline
Old 05-12-2012, 07:55 PM   #13
Trade: Construction
I don't know what's in thinset, grout, drywall mud, cement etc etc as the patch of grass where I wash stuff out all the time at my own house is nicer than any other part in my back yard.
Old 05-12-2012, 09:00 PM   #14
katoman's Avatar
Trade: carpenter
Rewards Points: 2,000
The neighbors yard ?
katoman is offline
Old 05-13-2012, 11:12 AM   #15
Groutface
Groutface's Avatar
Trade: flooring installer
Rewards Points: 524
All leftovers,grout ,mortar,drypack,whatever,get put in a tote,and dumped at the shop bin. Nearest sewer drain gets the grout water and other wastewater.. Then washed with clean bucket of water to not piss off neighbors.
Groutface is offline
Old 05-13-2012, 04:13 PM   #16
Want to play a game?
CrpntrFrk's Avatar
Trade: I do that too!
Rewards Points: 4,196
Lots of hills around here so it is not uncommon to have a retaining wall at the job-site. Behind that wall is the best place for us.
The video DManchester posted looks cool. But I am getting sick of hearing that every f**king thing causes cancer.
CrpntrFrk is offline
The Following 2 Users Say Thank You to CrpntrFrk For This Useful Post:
Groutface (05-13-2012), TNTRenovate (05-13-2012)
Old 05-13-2012, 07:20 PM   #17
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Yeah, concrete sludge is a lot different than thinset or grout residue.
Angus
angus242 is offline
Old 05-13-2012, 08:13 PM   #18
tileman2000's Avatar
Trade: tile contractor
Rewards Points: 528
I ask the customer first. If noone's around to ask, I look for areas where it wouldn't be noticeable. Under decks,gravel driveways or nearby woods usually.
Michael
Miller Tile on Facebook
tileman2000 is offline
The Following User Says Thank You to tileman2000 For This Useful Post:
Old 05-14-2012, 07:52 AM   #19
King of Caulk
asbestos's Avatar
Trade: Rot warrior
Rewards Points: 170
I dump plaster and thinset in the client's washing machine, concrete goes in the neighbor's driveway, but I don't get much repeat business so you may not want to listen to me
I am the Sultan, The Sultan of sealants
asbestos is offline
The Following 3 Users Say Thank You to asbestos For This Useful Post:
DManchester (05-14-2012), Ethos (05-14-2012), TNTRenovate (05-14-2012)
Old 05-14-2012, 08:58 AM   #20
Wearer of Hats
Ethos's Avatar
Trade: Kitchen and Bath Remodel
Rewards Points: 294
I typical scoop out as much as I can by hand into the trash can I bring along with me, then give it a good brushing / spraying out in the side yard, preferably somewhere with gravel / mud / mulch where I won't be hurting any grass as mortar is fairly basic. I try to dilute it as much as possible and spread it over as big of an area as possible if I have no other choice by on the grass. Haven't had any issues thus far.
Ben - Ethos Kitchen and Bath
http://www.kcethos.com
Ethos is offline
How can we clean these logs? Tinstaafl Decks & Fencing 60 02-14-2012 01:50 AM
framing around drain stack clean A&J Construction 4 12-26-2011 04:59 PM
Clean out pancake compressor tank bb71 Tools & Equipment 6 02-21-2010 02:51 PM
