What Would Your Method Be? (SLC Linoleum) - Tiling - Contractor Talk
Old 05-02-2013, 09:49 PM   #1
ArtisanRemod's Avatar
Rewards Points: 582
My buddy's new to him house. Built in the 40's. Id like to leave the linoluem in place, as time and budget won't allow for an asbestos test/removal.
An engineer has said the house settled a long time ago and has not moved since, but the kitchen floor is noticeably out of level. I have not used Self Leveling compounds in a long time, and am wondering how I should proceed.
Any info appreciated.
ArtisanRemod is offline
Old 05-02-2013, 10:15 PM   #2
Chief Reporter of Spam
Tech Dawg's Avatar
Trade: Kitchen and Bathroom Remodeling
Rewards Points: 1,282
Re: What Would Your Method Be? (SLC Linoleum)
Check the Laticrete primer and 86 Latilevel. You can go over the vinyl as long as its not cushion backed. Set the tile with 254 Platinum
Todd
Alone Eagle Remodeling, LLC
Tech Dawg is offline
The Following User Says Thank You to Tech Dawg For This Useful Post:
ArtisanRemod (05-03-2013)
Old 05-02-2013, 10:22 PM   #3
astor's Avatar
Trade: FI
Rewards Points: 704
I would go 5 mm underlayment first, prime and then SLC. Pouring SLC directly to lino is kind of risky.
But I remember seen a Henry patch that goes over anything.
astor is offline
The Following User Says Thank You to astor For This Useful Post:
Old 05-02-2013, 10:35 PM   #4
Paul
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Rewards Points: 1,004
Slab or crawl?
Precision Floors
(772) 237-9900
PrecisionFloors is offline
Old 05-02-2013, 11:08 PM   #5
astor's Avatar
Trade: FI
Rewards Points: 704
Originally Posted by PrecisionFloors View Post
Slab or crawl?
Oopps. I assumed it is wooden subfloor, that is why I said underlayment and meant to be screwed or stapled.
Good catch Paul!
astor is offline
Old 05-03-2013, 07:31 AM   #6
Rewards Points: 582
House has a full basement.
Old 05-03-2013, 03:53 PM   #7
Paul
A recipe that has always worked for me is to prime with appropriate primer for non-porous substrates and then install diamond lathe with either staples or ring-shanks. Overlap the lathe at least an inch or so at all joints and leave 1/2 short on the perimeter.
I have always had excellent results with Ardex K15. I know the are cheaper SLCs on the market but personally I've had mixed results - some were ok, others a waste of time and money. I've never had an issue with K15 ever, provided it's mixed right with cold, clean water.
edit: Above advice obviously provided the substrate is up to snuff. SLC will not fix rotten subfloor or structural issues. I wouldn't install it over particle board anywhere in the sandwich either. Most SLC manufacturers call for solid wood or minimum 3/4" plywood as the subfloor.
Precision Floors
(772) 237-9900
The Following User Says Thank You to PrecisionFloors For This Useful Post:
Old 05-03-2013, 08:33 PM   #8
MIKE ANTONETTI's Avatar
Trade: FLOORING CONTRACTOR
Rewards Points: 3,514
That's some sweet advice, the wire lath is a mechanical bond, something you can look at physically and see it attached to the substrate. Primers are chemical in which you take for granted are going to work.
Schluter ditra, sheet, liquid over top?
MIKE ANTONETTI is offline
Old 05-03-2013, 09:30 PM   #9
CO762's Avatar
Trade: Organic Mold Farmer
Rewards Points: 4,534
Originally Posted by MIKE ANTONETTI View Post
Yup, the wire lath is a mechanical bond, something you can look at physically and see it attached to the substrate. Primers are chemical in which you take for granted are going to work.
When bonding one thing to another, there is always a mechanical and chemical bond.
CO762 is offline
Old 05-06-2013, 03:32 PM   #10
Hank B.'s Avatar
Trade: tile, floors
Rewards Points: 81
Imo, the best thing to do would be to mud that floor. What's that vinyl over? Hopefully not some thin particle board/luan type underlayment. That would make any method a no go. What's the subfloor/deflection?
Hank B. is offline
The Following User Says Thank You to Hank B. For This Useful Post:
charimon (05-06-2013)
Old 05-06-2013, 04:21 PM   #11
charimon's Avatar
Trade: Tile and Tool junkie
Rewards Points: 1,168
"The key is to allow only the complexity that the customer is willing to pay for."
charimon is offline
Old 05-06-2013, 05:44 PM   #12
Rewards Points: 582
I'm going to dig in a corner and see what's in there. I don't do many of these where the floor is so out of whack.
What is the most Accurate method to measure for siding? SidingWindows Windows, Siding and Doors 20 03-21-2010 09:06 PM
Blanke Unimat over Linoleum? JDPMG Flooring 4 11-30-2009 05:43 PM
What is the proper method of Advertising? Jmfocus Marketing & Sales 9 07-04-2009 12:07 PM
3-4-5 Method of Squaring renkom Framing 19 12-05-2008 02:07 AM
