What Tile Project Are You Working On? - Page 205 - Tiling - Contractor Talk
Old 05-24-2019, 07:59 PM   #4081
Xtrememtnbiker's Avatar
Trade: General Remodeling
Rewards Points: 298
Re: What Tile Project Are You Working On?
We have hand set stones on the last 5 or so we have done. It works much better.
Xtrememtnbiker is offline
The Following 2 Users Say Thank You to Xtrememtnbiker For This Useful Post:
overanalyze (05-24-2019), TNTRenovate (05-25-2019)
Old 05-24-2019, 09:42 PM   #4082
Nick1001's Avatar
Rewards Points: 201
Yeah the sheets normally look like ****
Nick1001 is offline
Old 05-25-2019, 07:34 PM   #4083
Hair Splitter
TNTRenovate's Avatar
Trade: General
Rewards Points: 1,050
We have hand set stone for about three years now. Some sheets are actually pretty darn good as is, but we don't want to risk it.
Tried & True on Facebook
Tried & True Website
TNTRenovate is offline
The Following 2 Users Say Thank You to TNTRenovate For This Useful Post:
overanalyze (05-25-2019), Xtrememtnbiker (05-26-2019)
Old 05-26-2019, 01:03 AM   #4084
Rewards Points: 298
And to clarify, the last 5 jobs also means about the last 5 years...
Craig was the first one I saw post about it if I recall and now I'm in the same camp as you, don't want to risk it.
overanalyze (05-26-2019), TNTRenovate (05-26-2019)
Old 05-26-2019, 11:12 AM   #4085
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 702
Yeah a stone floor isn't very common for me to install. Last one I did was several years back and I didn't even think about sheet lines...it was a 3x3 shower. Looking back on pics of it, it turned out well.
overanalyze is offline
Old 05-26-2019, 04:02 PM   #4086
Hair Splitter
Trade: General
We do 3-4 a year. I have one coming up in a few weeks.
Old 05-26-2019, 04:37 PM   #4087
Texas Wax's Avatar
Rewards Points: 1,662
Originally Posted by overanalyze View Post
Cut of the day...and I set these individually because the sheet lines were awful.
Just finished one. Thought about doing individual setting Still recovering from a travertine 1x1 mosaic that I had to set in strips and individuals. Crap tile, from a crap store supplied by the, customer. This one spun each sheet for best fit / look. Set the 4x4 shower and had a moment of pause. The edges were flipping obvious, well too late now. Grouted and turned out well. Best I can tell the edges of the mats changed how those joints looked. Grout changed that.
...as the page loads, so go the days of our lives, at CT
Texas Wax is offline
The Following User Says Thank You to Texas Wax For This Useful Post:
Old 06-10-2019, 07:11 PM   #4088
Always Learning
Rewards Points: 702
Little accent niche and corner wrap on our current shower. Also some prep for tomorrow.
The Following 9 Users Say Thank You to overanalyze For This Useful Post:
AustinDB (06-11-2019), B.Johnson (06-13-2019), Dirtywhiteboy (06-10-2019), Idothat (06-10-2019), KAP (06-10-2019), SmallTownGuy (06-10-2019), Texas Wax (06-10-2019), Tom M (06-10-2019), Xtrememtnbiker (06-10-2019)
Old 06-11-2019, 02:41 PM   #4089
Hair Splitter
Trade: General
Hack!
The Following User Says Thank You to TNTRenovate For This Useful Post:
overanalyze (06-11-2019)
Old 06-11-2019, 07:28 PM   #4090
Always Learning
Rewards Points: 702
Hack!
I try...
Old 06-12-2019, 08:51 PM   #4091
Always Learning
Rewards Points: 702
Alright...here is something new I tried. Keeping with the theme of setting smaller sheet tiles on Kerdi...the upper tiles for the last bit of tile in this shower were thinner than the ones below. I decided to apply them to Kerdi like I had done for the other decorative mosaics. That's was fine but then I had a brain fart and forgot one thing... installing a 2'x5' slab like that wouldn't be easy because of handling and flexing.
My solution was a few steps. First I wanted to be able to attach suction cups to the "slab" to be able to move and install it. Also I wanted to add something to help keep the flexing of the panels to a minimum. I tried the clear, adhesive type carpet protection on the face of the tiles and that worked awesome! That alone wasn't enough to give a proper seal for the cups so I hot glued some 1/4" melamine to the film and that worked really well. Then wanting to stiffen the assembly a bit more for moving around a spot glued some 1/2 GoBoard scrap across the film. This worked really well too.
Next I cut them to size using the Makita tile saw with track adapter. Then I skimmed the wall and applied thinset to the back of the panels.
It was perfect. It took 2 of us to install the back wall but I was able to install the smaller side pieces solo.
It won't be something I do every install but it worked fantastic for this situation and probably saved me some headache and time vs skimming out the wall to accommodate the thinner tile.
Tomorrow I will peel the film and strips off once the thinset cured overnight.
The Following 3 Users Say Thank You to overanalyze For This Useful Post:
KAP (06-12-2019), rblakes1 (06-13-2019), Tom M (06-12-2019)
Old 06-12-2019, 09:06 PM   #4092
Tom M's Avatar
Rewards Points: 3,474
Glad it worked out.
All said and done was it faster or just easier to work on?
Tom M is offline
overanalyze (06-12-2019)
Old 06-12-2019, 09:16 PM   #4093
Always Learning
Rewards Points: 702
Originally Posted by Tom M View Post
Glad it worked out.
I say both...at least for me. Simply rolling out Kerdi on a flat surface and being able to lay down full tiles was quick. I was able to get them flat, with full coverage, and straight way quicker than installing them on a wall. I had the 3 sections applied to the Kerdi in less than an hour yesterday. Then today I had about 3-1/2 hours cutting them to size and setting them. That includes some head scratching time solving some of the issues. I am not a fast tile guy so I doubt I could have set them individually in that time especially when you consider I would have has to skim the wall to accommodate the thickness issue or applied Kerdi to the wall first before setting the tile.
The other benefit was cutting them as a panel vs individual pieces was much quicker and more precise with the track and Makita IMHO.
Not something for everyone or every install, but I will use the method again.
The Following 2 Users Say Thank You to overanalyze For This Useful Post:
Dirtywhiteboy (06-13-2019), Tom M (06-13-2019)
Old 06-13-2019, 07:55 PM   #4094
Always Learning
Rewards Points: 702
Grouted up! Those deco tiles sucked to grout with urethane!!
The Following 7 Users Say Thank You to overanalyze For This Useful Post:
AustinDB (06-13-2019), Dirtywhiteboy (06-20-2019), KAP (06-13-2019), rblakes1 (06-13-2019), SmallTownGuy (06-13-2019), Tom M (06-13-2019), Xtrememtnbiker (06-13-2019)
Old 06-13-2019, 08:01 PM   #4095
tjbnwi's Avatar
Rewards Points: 3,478
Very nice Andrew.
tjbnwi is offline
overanalyze (06-13-2019)
Old 06-20-2019, 05:52 PM   #4096
Always Learning
Rewards Points: 702
Little custom vent I did. Also client wanted to add a small corner toe shelf. Made the shelf at the shop and installed after I tiled. It worked really well! https://cloud.tapatalk.com/s/5d0c0e13...034800_858.mp4
Xtrememtnbiker (06-20-2019)
Old 06-20-2019, 07:52 PM   #4097
B.Johnson's Avatar
Trade: Builder
Rewards Points: 2,636
What adhesive did you use to stick the shelf to the wall?
Home Designer Series Software
B.Johnson is offline
Old 06-20-2019, 09:07 PM   #4098
Always Learning
Rewards Points: 702
Quad color clay...it was almost a perfect match to the color body of the porcelain.
B.Johnson (06-21-2019), Dirtywhiteboy (06-20-2019)
Blasting Pool Tile sa1245 Sandblasting 5 06-29-2015 08:56 PM
Porcelain Tile over Hydroban/Densarmor? ApgarNJ Tiling 46 02-10-2011 10:39 PM
Saw these guys working out in front of the project yesterday wallmaxx Off Topic (Non Trade) 1 03-15-2009 06:54 AM
information on fixing a bad tile job bford General Discussion 4 09-30-2008 06:44 AM
