What Tile Project Are You Working On? - Page 168 - Tiling - Contractor Talk
Old 04-26-2015, 09:10 AM   #3341
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
Re: What Tile Project Are You Working On?
Installed with just Kerdi-Fix and didn't allow a full cure either.
FYI, the small 17" Better Bench will only hold 100 lb.
Angus
angus242 is offline
The Following User Says Thank You to angus242 For This Useful Post:
overanalyze (04-26-2015)
Old 04-26-2015, 10:00 AM   #3342
If my PO asks,I set tile
Evan1968's Avatar
Trade: Commercial Tile Installs
Rewards Points: 1,160
Ahh yes..the BigRedShoe. AKA- Jadnashua.
He is Cheez Whiz. Cheez Whiz aint real cheese and he aint a real tile guy.
Thats all hes good for, just standing there.
Craig
Tile Installations Unlimited
"If you can't wow them with knowledge,baffle them with bullcrap."
Evan1968 is offline
Old 04-26-2015, 10:56 AM   #3343
The Remodeler
Splinter's Avatar
Trade: Home Remodeler
Rewards Points: 240
So I should quit buying betterbenches? I put one in almost every shower I build lately. At $50 or more per bench it adds up. The local homers is stocking 2" 2x8 panels for around $80 now. I could get a buttload of benches out of that.
Splinter is offline
Old 04-26-2015, 11:03 AM   #3344
Xtrememtnbiker's Avatar
Trade: General Remodeling
Yep. You can get 8 benches out of a 2'x8' piece. It's very easy to create a custom sized bench that fits the tile design. With the better bench we kept wishing it was a hair smaller.
All you do is run a good squigly bead of Kerdi fix on the bench and stick it to the wall. You will need to Kerdi band the front of it because it's exposed foam. Material cost is much less and the time is faster.
Xtrememtnbiker is offline
Old 04-26-2015, 01:11 PM   #3345
Knight-Builder's Avatar
Trade: Builder
Rewards Points: 526
Originally Posted by overanalyze View Post
Will the 8mm wheel that comes with the Rubi Speed 26 be ok for glass or should I get the 6mm?
In my experience, both the 8mm and the 6mm wheels work well for glass. But then again tile grade glass isn't hard to score. Remember, with the rubi wheels, the bigger the wheel, the harder material that can be scored.
Knight-Builder is offline
The Following User Says Thank You to Knight-Builder For This Useful Post:
Old 04-27-2015, 07:32 PM   #3346
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,686
Started a tile shower reno today. Used my Bosch 11264evs in demo mode a lot! I had to demo the existing tile shower. That bad boy worked like a champ!
It is sad really, this shower had major grout failure. I think the guy that installed this shower used construction adhesive/mastic?!
Underneath was a percectly done AquaD waterproofing job. Not a drop of water damage behind the walls…which is good news for the client. They used the fabric in the corners, great coverage...just the wrong adhesive for the tiles...that and regular grout I believe is why this failed prematurely.
What tile project are you working on?-1430180954848.jpg   What tile project are you working on?-1430180972798.jpg   What tile project are you working on?-1430180991172.jpg
overanalyze is offline
BlueRidgeGreen (04-27-2015)
Old 04-27-2015, 10:02 PM   #3347
TaylorMadeAB's Avatar
Trade: Renovations
What tile project are you working on?-imageuploadedbycontractortalk1430190087.559029.jpg
I just pulled up this tile from a foyer. It really reinforces how important back-buttering is. I was pulling up 3 full tiles up at a time!
TaylorMadeAB is offline
Old 04-27-2015, 10:07 PM   #3348
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
...and proepr mixture to thinset and actually setting the tile, not just placing it.
Angus
angus242 is offline
The Following 2 Users Say Thank You to angus242 For This Useful Post:
TaylorMadeAB (04-27-2015), TNTRenovate (04-27-2015)
Old 04-27-2015, 10:51 PM   #3349
Trade: Renovations
150 ft2 of 8x8 tile set like that, on 3/4 plywood! And there were only 3 cracked tiles. I was amazed that it had held up that long. (20 years)
Old 04-29-2015, 08:44 PM   #3350
charimon's Avatar
Trade: Tile and Tool junkie
Rewards Points: 1,168
It looks like his layout and cuts were nice. I find floor to ceiling diagonal installs to be one of the more technically difficult.
charimon is offline
Old 04-29-2015, 10:06 PM   #3351
Always Learning
Yeah the corners lined up pretty well too. It's like he ran 26 miles of a marthon and quit...
Old 04-29-2015, 10:08 PM   #3352
Always Learning
Got the Kerdi done today. I like the system. Going to flood test tomorrow.
charimon (04-30-2015)
Old 04-29-2015, 10:09 PM   #3353
Was it your first time using it?
Old 04-29-2015, 10:10 PM   #3354
Always Learning
As a total system, yes. I liked the floor and curb. Although I found the curb to tall and cut it down. Creasing the fabric prior to installation helped a ton to keep corners sharp.
Old 04-29-2015, 10:19 PM   #3355
At the class I was told the curb is that tall because there are a couple places in the states that require the 6" curb so they make them all that high. I cut them down a couple inches.
Yeah, creasing helps a lot. On the outside corners where they want to pucker up a bit, you can rub them back and forth between your hands quickly the opposite way of the pucker and it helps them lay down better.
It's a good system for sure. I like the pan especially because the whole mud bed thing was hard for me to do when I only did it about twice a year. Never got good at it.
Old 04-29-2015, 10:27 PM   #3356
Always Learning
I am signed up for the 2 day class in June. Looking forward to it. I won't say it is the end all solution for all showers, but I like it so far for me. I am the same as you...I didn't have the confidence to do a regular mud bed well.
My tile guy I use when we are slammed prefers to do a mud bed and then Kerdi everything. He is good at that. I helped him do a shower before and it was amazing to watch him do the bed. Definitely a skill.
Xtrememtnbiker (04-29-2015)
Old 04-29-2015, 10:40 PM   #3357
I figure when I need to take a grinder to my mud bed I'm doing something wrong...
The Following User Says Thank You to Xtrememtnbiker For This Useful Post:
overanalyze (04-29-2015)
Old 04-29-2015, 11:08 PM   #3358
tjbnwi's Avatar
Rewards Points: 84
I believe code is, top of curb 2" above drain in most areas.
tjbnwi is online now
Old 04-30-2015, 12:05 AM   #3359
Trade: Renovations
I'm doing the first course next week. Pretty excited about it. Even just getting all the samples is going to be nice.
Old 04-30-2015, 08:00 AM   #3360
Trade: Builder
Rewards Points: 526
Up here, it's the norm for all the fancy trowels and such used during the demos to be handed out at the end too!
Blasting Pool Tile sa1245 Sandblasting 5 06-29-2015 08:56 PM
Porcelain Tile over Hydroban/Densarmor? ApgarNJ Tiling 46 02-10-2011 10:39 PM
Saw these guys working out in front of the project yesterday wallmaxx Off Topic (Non Trade) 1 03-15-2009 06:54 AM
information on fixing a bad tile job bford General Discussion 4 09-30-2008 06:44 AM
