What Tile Project Are You Working On? - Page 164 - Tiling - Contractor Talk
Old 04-11-2015, 12:10 AM   #3261
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
Re: What Tile Project Are You Working On?
Originally Posted by TNTSERVICES View Post
Didn't you admit that the water management sucked? The truth may have hurt but it isn't me that's hurtin'
No, I thought I said your opinion sucked. But that's OK. I wasn't trying to hurt your feeling.
Angus
angus242 is offline
Old 04-11-2015, 12:24 AM   #3262
Hair Splitter
TNTRenovate's Avatar
Trade: General
Rewards Points: 1,268
I give. You win. I'm tired of this game.
Tried & True on Facebook
Tried & True Website
TNTRenovate is offline
Old 04-11-2015, 12:36 AM   #3263
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
OK guys, I just wanted to let everyone know, this was all a joke. Me and Rob were not really going at it. It was a staged joke and it has obviously ran its course.
I apologize for taking it this far and running this thread so far off topic.
I trust Rob and his abilities. I would work with him whenever the chance arose. I have talked to some of you off the forum and know I have said that about him many times.
I started by trying to bust his jewels some but it carried to a larger joke wanting to see when someone would tell us to knock it off. I received my PM about this and we're done.
Angus
angus242 is offline
Old 04-11-2015, 03:23 AM   #3264
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,160
Ohhh...you guys.. lol! :sly:
overanalyze is offline
Old 04-11-2015, 09:44 AM   #3265
Jspence's Avatar
Trade: Flooring
Rewards Points: 125
I just wish I had enough time in my day to stage a tile saw showdown. I enjoyed every minute of it though
Jspence is offline
The Following User Says Thank You to Jspence For This Useful Post:
charimon (04-11-2015)
Old 04-11-2015, 10:17 AM   #3266
Unger.const's Avatar
Rewards Points: 3,022
Started with a dark old fiberglass tub. Then relocated shower valve to the back wall. Shower head in same spot. Warm wire heated floor and shower floor. This was the first time I used the ditra heat membrain. The glass door and panel are on order so curtain for temporary.
What tile project are you working on?-1428765047071.jpg   What tile project are you working on?-1428765126039.jpg   What tile project are you working on?-1428765165504.jpg
Unger.const is offline
The Following 2 Users Say Thank You to Unger.const For This Useful Post:
BlueRidgeGreen (04-11-2015), overanalyze (04-11-2015)
Old 04-11-2015, 10:30 AM   #3267
Set the ditra, left for the night and came back to a buckle near the seam. Was pretty puzzled at first thought maybe I put the sheets to close together or something. For some reason there was a delaminated layer in the plywood about a couple layers down. Water from the thinset went down and swelled the layers up. Ugh
What tile project are you working on?-1428765614384.jpg   What tile project are you working on?-1428765744551.jpg
Old 04-11-2015, 11:45 AM   #3268
Hair Splitter
Trade: General
Why move the valve? Seems like you'll turn on the shower and get hit in the face with the stream.
Old 04-11-2015, 02:18 PM   #3269
Tile Contractor
HS345's Avatar
Trade: Ceramic and Natural Stone Tile Contractor
Rewards Points: 886
Lol, good one.
Greg
HS345 is offline
Old 04-11-2015, 03:37 PM   #3270
Where the toilet is now there will be a solid glass panel. So if the control was under the shower head then you would have to go into the shower reach clear to the far side. Turn it on and run before the water comes out and hope you guessed at the correct temperature or else suffer reaching in with either cold water still or scolding. After the door is installed. Just open the swinging door on the left hand side. Turn the water on and stay out of harms way.
Old 04-11-2015, 05:57 PM   #3271
Hair Splitter
Trade: General
I guess I don't see the new location as out of harms way, but I can understand the reasoning.
As for the temperature selection that's why I love a temp valve.
Old 04-11-2015, 07:26 PM   #3272
Where the toilet is now there will be a solid glass panel. So if the control was under the shower head then you would have to go into the shower reach clear to the far side. Turn it on and run before the water comes out and hope you guessed at the correct temperature or else suffer reaching in with either cold water still or scolding. After the door is installed. Just open the swinging door on the RIGHT hand side. Turn the water on and stay out of harms way.
I corrected it. Swing door on right hand side.
Old 04-11-2015, 10:39 PM   #3273
diplomat
Golden view's Avatar
Rewards Points: 694
Around here they might allow it this way but not under the shower head if there's fixed glass there. Shower heads tend to spray the water down at a pretty steep angle and hit the floor not much more than 3 feet away. You might get your foot wet.
Golden view is online now
Old 04-11-2015, 10:45 PM   #3274
Hair Splitter
Trade: General
It was a tub (60") and looks like the valve is setback in the middle which would be less than 3'. You are not out of "harms way".
Installing a diverter is a much better solution.
Old 04-16-2015, 11:40 PM   #3275
Xtrememtnbiker's Avatar
Trade: General Remodeling
Rewards Points: 340
Build your own niche. Perfect fit to your grout joints every time!
Angus, the way you tiled around the border on this shower, how did you space around it? With blocks as spacers or finish nails to hold the next row and than patch the holes? Or some entirely different option?
Thanks
Xtrememtnbiker is offline
The Following User Says Thank You to Xtrememtnbiker For This Useful Post:
TNTRenovate (04-17-2015)
Old 04-17-2015, 04:51 AM   #3276
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Cut strips of Ditra to pad out border. Used cut pieces of spare tile to set row above border. Removed spacer tile and set 2nd layer of Ditra to pad boarder.
Angus
angus242 is offline
The Following 2 Users Say Thank You to angus242 For This Useful Post:
TNTRenovate (04-17-2015), Xtrememtnbiker (04-17-2015)
Old 04-17-2015, 10:43 AM   #3277
Philament's Avatar
Trade: Whatever the customer wants
Rewards Points: 2,230
Dare I ask what type of thinset you use between the ditra and Aqua D? And what kind of thinset over the ditra for the mosaic? ...that schluter confuses me.
Philament is offline
Old 04-17-2015, 01:52 PM   #3278
jb4211's Avatar
Rewards Points: 2,306
Schluter recommends UNmodified between Ditra and tile.
And, between substraight and Ditra it's whatever is best for the substraight, often modified.
Jon
jb4211 is offline
Old 04-17-2015, 01:53 PM   #3279
TaylorMadeAB's Avatar
Trade: Renovations
Rewards Points: 1,686
Some thinset manufactures will pick up Schluter's warranty if you use their product. Specifically Ardex, when using their modified.
TaylorMadeAB is offline
Old 04-17-2015, 02:00 PM   #3280
Jspence's Avatar
Trade: Flooring
Rewards Points: 125
I know you've answered this before but where you finding the best deal on your rls system ??
Jspence is offline
Blasting Pool Tile sa1245 Sandblasting 5 06-29-2015 08:56 PM
Porcelain Tile over Hydroban/Densarmor? ApgarNJ Tiling 46 02-10-2011 10:39 PM
Saw these guys working out in front of the project yesterday wallmaxx Off Topic (Non Trade) 1 03-15-2009 06:54 AM
information on fixing a bad tile job bford General Discussion 4 09-30-2008 06:44 AM
