What Tile Project Are You Working On? - Page 161 - Tiling - Contractor Talk
Old 04-09-2015, 07:54 AM   #3201
Jspence's Avatar
Trade: Flooring
Rewards Points: 125
Re: What Tile Project Are You Working On?
Because then you have a height difference in the other side
Jspence is offline
Old 04-09-2015, 08:43 AM   #3202
Hair Splitter
TNTRenovate's Avatar
Trade: General
Rewards Points: 1,268
? I'm not following. He wants to cut a 45 with his wet saw. The bar is in the way. Flip the piece and cut from the other side.
I guess I am missing something.
Tried & True on Facebook
Tried & True Website
TNTRenovate is offline
Old 04-09-2015, 09:55 AM   #3203
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
Originally Posted by jb4211 View Post
The first saw I used was a borrowed Ridgid. I couldn't figure out how to cut the piece because of the bar that hold the motor.
I have since bought the DeWalt. It has the same bar that would get in the way of mitering those long pieces.
I didn't think of asking the supplier to miter the ends and I could just cut to length.
I don't understand the statement above. So you're saying the curb is 2 pieces?
Does this mean you are wrapping the opening in granite so you need a miter like this
Angus
angus242 is offline
Old 04-09-2015, 11:04 AM   #3204
Xtrememtnbiker's Avatar
Trade: General Remodeling
Rewards Points: 348
I was picturing a curb like Angus posted. Figuring that if I had to cut a miter like that in my Dewalt I would add a spacer to the sliding table the height of the lip that you would normally set tile to.
Or if you didn't want to do the spacer, you have the piece sitting on the table but at a 45 away from you which would probably require two people.
Or have the supplier do it. That's the easy way.
Xtrememtnbiker is offline
Old 04-09-2015, 01:38 PM   #3205
Jspence's Avatar
Trade: Flooring
Rewards Points: 125
No I thought we were talking about the subway beveled tile when cut there is a high and low if matched up to a factory piece
Jspence is offline
Old 04-09-2015, 01:40 PM   #3206
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
What's the best way to miter a solid piece of stone for the top of a shower curb. The piece I had to cut was about 48" long x 5" wide. To big for the saw.
I only had to do it once so far, and I used a grinder. It's there a better way?
We were talking about this...
Angus
angus242 is offline
Old 04-09-2015, 01:54 PM   #3207
The Remodeler
Splinter's Avatar
Trade: Home Remodeler
Rewards Points: 240
That's what I asked you about earlier... I had a homeowner pay me to tear out two brand new, never used beveled subway showers because the previous guy butchered them. One of the things he did was butt the corners which leaves large gaps where the bevels drop away from the proud center.
It was my first time doing bevel subway, so I bought the Ridgid 7" wet saw just for it's tilting head. So much easier than trying to do all of them on my MK101.
I put a T3 Razor on it, and now I hardly ever pull out the MK... It's too damned heavy.
Splinter is offline
Old 04-09-2015, 04:42 PM   #3208
Jspence's Avatar
Trade: Flooring
Rewards Points: 125
My fault I use a miter wiz for long mitered edges works like a charm, to do 48" rips remove your slide table from wet saw lay down some wood to just above blade height run a cut into wood, now use wood as a table saw and run your tile thru.
Jspence is offline
Old 04-09-2015, 07:08 PM   #3209
jb4211's Avatar
Rewards Points: 2,306
Originally Posted by TNTSERVICES View Post
Why not flip the piece to the other side?
I'm trying to remember, but if memory serves me correctly, I would've had about 4' of material hanging off of the saw, and it would be upside down. I just didn't feel it would be stable enough to guarantee an accurate cut.
Jon
jb4211 is offline
Old 04-09-2015, 07:09 PM   #3210
jb4211's Avatar
Correct
Jon
jb4211 is offline
Old 04-09-2015, 07:12 PM   #3211
jb4211's Avatar
45 pointing away from you. I'm not sure if you could do it accurately with two people. Definitely couldn't do it alone. I think the weight would tip the saw.
Jon
jb4211 is offline
Old 04-09-2015, 07:16 PM   #3212
m1911's Avatar
Trade: finish carpenter
Rewards Points: 15,632
A scrap piece of plywood clamped to a saw horse for support is your friend.
Originally Posted by tipitop View Post
That guy in video have mental issues plus eat hole turtle from some reason
m1911 is offline
The Following User Says Thank You to m1911 For This Useful Post:
jb4211 (04-09-2015)
Old 04-09-2015, 07:16 PM   #3213
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Correct
Doesn't help you but this is when having a rail saw really pays off.
Angus
angus242 is offline
Old 04-09-2015, 07:21 PM   #3214
Rewards Points: 348
Jon, this may or may not be helpful to you, but here goes.
The way we've started handling the curbs is as soon as we let our supplier know we will be asking for a piece on a specific day to give them a bit of notice. Things vary depending on the job but the idea is that if day 1 goes well the old shower gets demo'd and we get our substrate installed, I can measure wall to wall, or in your case wall to corner and figure your overhang, and then give them a number.
We just recently started doing the granite so I think it's been 4 curbs that way. I subtract 1/4" from the measurement between my walls and use that dimension by 6" wide. The 6" wide is with a Schluter curb with tile on each side and I can usually figure 1/2" for tile and mortar and so 6" gives me a 1/4" over hang with a little ability to shift stuff around.
It's worked perfect every time so far. The way if fits into my tiling schedule is after layout is done, I attach a level board to the wall all the way around to lay my starter course off of which is the second course up from the floor (or higher if it's subway) and I can lay the rest of the shower while waiting for the curb.
I set the curb and cut the tile around the curb because I prefer the look of if that way vs the curb being inside the tile where the joint is concerned. It also needs to be that way for the outer drywall to curb transition (the way mine are done). And yet another benefit is the way it works out with the schedule that the curb can be cut day one and fits when it shows up on the job site.
Hope some of that is helpful...
The Following User Says Thank You to Xtrememtnbiker For This Useful Post:
jb4211 (04-09-2015)
Old 04-09-2015, 07:37 PM   #3215
jb4211's Avatar
I literally just bought the DeWalt.lol
Jon
jb4211 is offline
Old 04-09-2015, 07:39 PM   #3216
Rewards Points: 348
I looked at the Imer that Angus has but it was more money and we only do a few showers a year.
The Dewalt will treat you nicely.
Old 04-09-2015, 07:41 PM   #3217
jb4211's Avatar
While I'm at it, this may be a bad picture, but I'm being asked to tile around the window on the left in this picture.
The other picture is the backsplash design I'm using.
Any suggestions?
What tile project are you working on?-1428626422347.jpg   What tile project are you working on?-1428626456256.jpg
Jon
jb4211 is offline
Old 04-09-2015, 07:48 PM   #3218
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Sometimes you have to bite the bullet on tools. Don't always look at how few times you'll use it but rather how much you'll be able to accomplish with it.
I have quite a few tools that I use 1-2 a year but when I need them....priceless.
Angus
angus242 is offline
The Following 2 Users Say Thank You to angus242 For This Useful Post:
m1911 (04-09-2015), overanalyze (04-09-2015)
Old 04-09-2015, 07:53 PM   #3219
Rewards Points: 348
I agree. But you weren't around to tell me that the Imer was that much better of a saw and lots of guys like the Dewalt.
Old 04-09-2015, 08:50 PM   #3220
pro
country_huck's Avatar
Trade: Capenter/ Remodeler
Rewards Points: 768
Angus how is that imer of yours holding up?
I have been wanting to get rid of the old dewalt for awhile now. I need something with better capacity and a lot better accuracy.
Nathaniel Huckins (huck)
Facebook
country_huck is offline
Blasting Pool Tile sa1245 Sandblasting 5 06-29-2015 08:56 PM
Porcelain Tile over Hydroban/Densarmor? ApgarNJ Tiling 46 02-10-2011 10:39 PM
Saw these guys working out in front of the project yesterday wallmaxx Off Topic (Non Trade) 1 03-15-2009 06:54 AM
information on fixing a bad tile job bford General Discussion 4 09-30-2008 06:44 AM
