Wet Tents - Tiling - Contractor Talk
Wet Tents
Old 07-31-2010, 03:11 PM   #1
charlesmd's Avatar
Trade: Baths, basements, carpentry, int.remodeling
Rewards Points: 150
Wet Tents
Anyone got one? Are you satisfied with it? Im thinking about getting one.
charlesmd is offline
Old 07-31-2010, 03:20 PM   #2
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
Re: Wet Tents
I like the concept but don't have one. Currently, I've been able to set up in a HO's garage & use 6mil on the floor.
I asked this same question about 2-3 years ago here & no one used it. I think they are on the expensive side so if it would really help increase your productivity, it might be worth it.
I certainly don't think they are a bad idea.
Angus
angus242 is offline
Old 07-31-2010, 05:56 PM   #3
mikeswoods's Avatar
Trade: interior remodeling
Rewards Points: 2,664
Re: Wet Tents
A granite setter I knew some years back had a nice set up----
He had a stainless steel pan made a bit larger than his saw and stand--it had a piece of metal welded into each inside corner.
That corner clip held a pvc pipe frame and a curtain (like a shower curtain) ran around 3 sides.
I worked a couple of winter jobs with that set-up---small torpedo heater--warm hands no frozen pump lines---slick------Mike-----Wish I had a picture,very simple.
mikeswoods is offline
Old 07-31-2010, 06:11 PM   #4
opiethetileman's Avatar
Trade: DIYer apparently
Rewards Points: 1,000
Re: Wet Tents
yeah they work. But i think you can make one your self. I have some pictures I will try and dig up. When i do a saw inside I use a small kiddie pool and place the saw in that and then tent the unit. It works only if there is a vacant room where you can set up a work station
opiethetileman is offline
Old 07-31-2010, 08:07 PM   #5
charlesmd's Avatar
Rewards Points: 150
Re: Wet Tents
Kicker is I got an Imer/its not small, dont think a kidde pool is going to work. They offer two different sizes, think Im gonna buy the larger one but will wait till you posts some pics of the homemade version. Thanks.
Old 07-31-2010, 08:20 PM   #6
Tile Contractor
HS345's Avatar
Trade: Ceramic and Natural Stone Tile Contractor
Rewards Points: 886
Re: Wet Tents
Here's my home made "wet tent". 1" pvc glued strategically, plastic mortar tubs from Lowe's, cheap painter's plastic thrown away after each job, some spring clamps and blue tape hold the plastic in place. Zero water hits the floor, but I still use a thick rubber sheet under the whole setup to protect the floor and to mix thinset on.
Wet Tents-img00251_600x450.jpg   Wet Tents-img00258_600x450.jpg   Wet Tents-img00080_600x450.jpg
Greg
HS345 is offline
The Following 2 Users Say Thank You to HS345 For This Useful Post:
jarvis design (08-12-2010), mikeswoods (08-01-2010)
Cheap Tips On Surviving An Economic Slowdown Ed the Roofer Marketing & Sales 9 03-13-2011 09:27 PM
A few more pictures of my project pritch Construction Picture Post 4 10-03-2009 12:55 AM
