Wet Saw Blades - Tiling - Contractor Talk
Wet Saw Blades
Old 10-13-2012, 05:33 AM   #1
lifestooshort81's Avatar
Trade: Home Remodeler
Rewards Points: 75
Wet Saw Blades
Hi folks,
I was looking at saw blades (wet saws) and noticed some continuous rim blades have slits in them. Not to be confused with a turbo blade; I don't mean serrations. Other cont. rim blades are a solid piece of metal. What is the purpose of this? I know it's for balance but why would a cont rim blade have one. Doesn't it defeat the purpose of being continuous?
Thanks
-Al C."Jack of All Trades" Stage 1 LLC Home Remodeling.
sometimes too inquisitive for my own good...
lifestooshort81 is offline
Old 10-13-2012, 05:50 AM   #2
Remodeler
TAHomeRepairs's Avatar
Rewards Points: 574
Re: Wet Saw Blades
Good question...I've often wondered this as well. Maybe the tile gurus will have some answers for us.
TAHomeRepairs is offline
Old 10-13-2012, 06:53 AM   #3
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
Re: Wet Saw Blades
My guess would be to reduce vibration.
ohiohomedoctor is offline
Old 10-13-2012, 07:29 PM   #4
MIKE ANTONETTI's Avatar
Trade: FLOORING CONTRACTOR
Rewards Points: 3,514
Re: Wet Saw Blades
They do that so you will buy it instead of the one that is not cut, they(manufacturers) tell you all sorts of stuff. You can't tell the quality by looking at the diamonds.
As in wood blades it is said to reduce vibration as OHD says, It may run cooler and help to prevent warping.
Everyone should have 10 different diamond blades in their toolbox
MIKE ANTONETTI is offline
Old 10-13-2012, 08:13 PM   #5
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
Re: Wet Saw Blades
Why 10? I have 3 and 90% of the time, I only use one of them.
Angus
angus242 is offline
The Following 3 Users Say Thank You to angus242 For This Useful Post:
Floormasta78 (11-24-2012), I Mester (11-26-2012), PrecisionFloors (11-25-2012)
Old 10-13-2012, 08:20 PM   #6
Re: Wet Saw Blades
I have been using the same diamond blade for years..
The Following User Says Thank You to ohiohomedoctor For This Useful Post:
Old 10-13-2012, 08:40 PM   #7
Re: Wet Saw Blades
I'm sorry I was replying from a manufacturers point of view, let me restate that, a ceo's point of view. I was being sarcastic, I know I have a problem with that.
Porcelain, glass, soft marble, worm drive blade , tile saw blade, 4" grinder blade, bullnose blade, 7" grinder blade, and on and on!
Old 11-24-2012, 12:43 AM   #8
sogno/inc's Avatar
Trade: flooring
Re: Wet Saw Blades
Originally Posted by lifestooshort81
Hi folks,
Thanks
They put slits in them to reduce vibration and to reduce chipping the enshrined of tile and those blade are tipically for porcelain tiles
Hope this quote helps for future purchases
sogno/inc is offline
Old 11-24-2012, 07:24 AM   #9
Orlando Car
Floormasta78's Avatar
Trade: certified floor covering installer.
Rewards Points: 1,154
Re: Wet Saw Blades
My blade is so old and I've used it so many years, you'd think a Hardwood blade is what I'm using..
http://www.facebook.com/#!/certifiedfloorcovering
Certified Floor Covering
Serving All California
( 510 ) 760 - 6810
Floormasta78 is offline
The Following User Says Thank You to Floormasta78 For This Useful Post:
Groutface (11-25-2012)
Old 11-26-2012, 01:20 PM   #10
Tool Guy To The Stars!
Sprung831's Avatar
Trade: Tile Tools
Rewards Points: 103
Re: Wet Saw Blades
Typically you will find music slots, or J slots, or the like on a thinner kerf blade. Take the T3 Razor for example. Being as thin as it is, if it were a true continuous rim, it could overheat and warp much easier. Adding the slots cools the blade better and also absorbs some vibration, which we need with porcelain get harder and more dense.
Sprung831 is offline
The Following User Says Thank You to Sprung831 For This Useful Post:
TAHomeRepairs (11-26-2012)
Old 11-26-2012, 05:51 PM   #11
Re: Wet Saw Blades
Continuous -they're talking about continually round versus the large gaps in between, I used to scare unfamiliar customers putting finger on continuous blade while saw was running and it won't cut you due to nothing hard pressed against it, try to do that with a segmented blade and blood will appear. I am assuming, refuse to prove.
Old 11-26-2012, 05:53 PM   #12
Sprung831's Avatar
Trade: Tile Tools
Rewards Points: 103
Re: Wet Saw Blades
Mike, I would post the picture I have proving that blood does appear, but I'd rather not re-live it
Old 11-26-2012, 06:00 PM   #13
Re: Wet Saw Blades
I See your a diamond blade vendor with street credentials, I like it, no pics is just fine
Old 11-26-2012, 06:24 PM   #14
Sprung831's Avatar
Trade: Tile Tools
Rewards Points: 103
Re: Wet Saw Blades
Like I've said in previous posts, I actually USE the tools I sell...though I will admit, sometimes improperly. But, if we used everything properly, there would be no reason to push a product to its limits.
Old 11-26-2012, 06:34 PM   #15
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Re: Wet Saw Blades
Sissies....
+ YouTube Video
Angus
angus242 is offline
The Following User Says Thank You to angus242 For This Useful Post:
Floormasta78 (11-26-2012)
Old 11-26-2012, 06:51 PM   #16
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Re: Wet Saw Blades
And that's an RTC Razor blade!
Angus
angus242 is offline
Old 11-26-2012, 07:07 PM   #17
Orlando Car
Re: Wet Saw Blades
This is where the buck stops.. I don't care of brands, thin, thick , red , blue blood, no blood..
Any blade is good when used by the right people with the right skills.
Lately in all the jobs I've posted here and on my Facebook page, all I've used is my Ishii cutter and grinder with my awesome cyclone blade
( 510 ) 760 - 6810
Old 11-26-2012, 09:47 PM   #18
Sprung831's Avatar
Trade: Tile Tools
Rewards Points: 103
Re: Wet Saw Blades
Orlando, this is where I tell you you are wrong. "any blade is a good blade..." is completely false. I've got blades in my showroom, that I don't care how good one is, or the skills they possess, you ain't cuttin s**t but doo-rock with them, lol. And that cyclone is similar to the RTC Stealth Fighter. I Am testing that cyclone against it, and I have to say, it's a pretty damn good blade.
Floormasta78 (11-27-2012)
Old 11-26-2012, 10:03 PM   #19
CO762's Avatar
Trade: Organic Mold Farmer
Rewards Points: 4,534
Re: Wet Saw Blades
Ya ever test yours against an alpha porcellana?
CO762 is offline
Old 11-26-2012, 10:06 PM   #20
Re: Wet Saw Blades
Any good tips on glass blades? So many variables on diamond blades, all of which you can't look at and tell the quality, for grinding(7") there's diff configurations etc( t, double row, turbo, and prices range say on a 4" from 5$ to 75 or more.
I just bought 3 - 7" double row dewalt grinder blades at a consignment shop for 15$(all 3), I stopped using them couple years ago because they coated over for paint and drywall compound cleanup along walls,they're 95$ each, I'll find somewhere to use them.
Diamond blades..the good the bad and the ugly.... CanCritter Masonry 10 08-04-2016 01:32 PM
multimaster blades Joe Black Tools & Equipment 33 10-14-2012 10:17 AM
3-1/4" makita planer blades Calidecks Tools & Equipment 1 04-20-2012 10:12 AM
Longest lasting blades for hardwoods NEhardwoodfloor Tools & Equipment 17 02-11-2011 08:45 PM
