Using Thin Set To Slope Shower Floor - Tiling - Contractor Talk
Old 12-08-2018, 09:36 AM   #1
nickko's Avatar
Trade: remodeling-cabinet maker
Rewards Points: 791
Hi
I have a shower coming up that is in a basement on a concrete floor I have to tear the existing shower out because of failure. I cant use a Schluter shower base because the shower is an odd shape and the drain is way off center. I was going to do a dry pack but the ceiling is low and i don't want to raise the floor three more inches.
I was thinking of cutting some screeds out of Azek or some other pvc and sticking them to the floor and us thin set to go from approx. 11/4 inch to a feather edge at the drain. And then using kerdi or red guard over that.
Will thin set work for this or is there a better product for doing a thin bed shower floor.
Thanks.........nicko
"Quality work for those who know the difference"
nickko is offline
Old 12-08-2018, 10:56 AM   #2
tjbnwi's Avatar
Rewards Points: 1,160
Re: Using Thin Set To Slope Shower Floor
Pictures sure would help.
Thin set will not work.
tjbnwi is online now
Old 12-08-2018, 12:00 PM   #3
Peter_C's Avatar
Trade: Home Beautification
Rewards Points: 412
Dry pack mud is what you want to use. If possible use a Schluter Kerdi drain and Kerdi over the floors and walls. There is a lot to getting a dry packed floor right. Better watch a ton of youtube videos before deciding if you want to attempt it.
Schluter does made an offset foam bottom drain kit.
Peter_C is offline
The Following User Says Thank You to Peter_C For This Useful Post:
MarkJames (12-08-2018)
Old 12-08-2018, 02:31 PM   #4
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 582
You can do a single layer dry pack, probably down to 1", so you're only raising the floor 1", not 3". Waterproof with kerdi over the drypack, and then tile over that.
Golden view is offline
The Following 2 Users Say Thank You to Golden view For This Useful Post:
SmallTownGuy (12-08-2018), Texas Wax (12-08-2018)
Old 12-08-2018, 04:03 PM   #5
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 16,773
FWIW, we have a basement shower with a finished height of only 82" (6'10") from drain plate to ceiling and it works fine. I'm 6'4" and it was odd at first, but I got used to it.
MarkJames is offline
Old 12-09-2018, 09:11 AM   #6
rblakes1's Avatar
Rewards Points: 3,536
I've never met a shower that I couldn't get a schluter pan to work with
rblakes1 is offline
Old 12-09-2018, 09:30 AM   #7
nickko's Avatar
Rewards Points: 791
https://www.youtube.com/watch?v=JJ3t2Nfx1pI
Thanks
I have done a few dry pack showers in the past so i know how to do them.
From where the drain is to the farthest wall is about five feet so at 11/4 thickness at the drain i would be approx. 21/2 inches of thickness at the wall. It is a low ceiling and i didn't want to raise the floor that high.
On Nobles,s web site they show a thin bed shower being done and they say to use a "high solids latex modified underlayment". I am not sure what they mean by that.
nicko
nickko is offline
Old 12-09-2018, 10:01 AM   #8
John the Builder
SmallTownGuy's Avatar
Rewards Points: 6,114
Originally Posted by nickko View Post
Thanks
nicko
https://www.carter-waters.com/patchc.../patch%20crete
Patchcrete is a two component polymer modified concrete repair, topping, and underlayment material. The Patchcrete liquid is a high solids content Acrylic Polymer. The Patchcrete Powder #1005 is a portland cement based mix with graded silica and special chemical additives. Polymer modified concrete gives improved bonding, improved chemical resistance, improved water resistance and improved tensile, compressive and flexural strengths.
SmallTownGuy is offline
The Following User Says Thank You to SmallTownGuy For This Useful Post:
Peter_C (12-09-2018)
Old 12-09-2018, 10:10 AM   #9
John the Builder
What I did was googled your quote: "high solids latex modified underlayment"
Should get you up to speed.\
https://www.google.com/search?q=high...hrome&ie=UTF-8
Old 12-09-2018, 10:45 AM   #10
tjbnwi's Avatar
Look into the new Schluter thin bases.
Old 12-09-2018, 03:29 PM   #11
nickko's Avatar
Rewards Points: 791
Thanks Smalltownguy
I did google it a few days ago and came up with the same thing you did but i didn't look into it much farther because i figured at 45 pounds per bag shipping would be expensive. I think I will call Noble on Monday and ask them what they used in there video for a thin bed shower. They used plastic screeds and screeded the mud across the plastic screeds. I have done about fifteen Schluter showers over the years and this is just a situation where the foam base is not going to work.
I have cut them to fit and i have added dry pack to them to make them work. If i wanted to move the drain i could use a 4x6 Schluter base but these people just got a new sewer line in and pressure tested and i don't want to cut the concrete floor up to move it.
thanks.....nicko
nickko is offline
The Following User Says Thank You to nickko For This Useful Post:
SmallTownGuy (12-09-2018)
Shower floor installation with brass drain? Pchow1970 Tiling 3 12-05-2015 10:16 AM
Can I install 1st floor header in the 2nd floor? TommyF Framing 14 07-10-2015 11:14 AM
Replacing shower floor tiles EverettJJ Flooring 17 10-06-2014 07:22 AM
When the thin blue line becomes black killzoneq2 Sandblasting 6 04-24-2013 04:33 PM
One piece shower floor katoman Tiling 27 11-30-2010 10:34 PM
