Tub Flange Address For Waterproof Board Install - Tiling - Contractor Talk
Old 02-17-2019, 01:21 PM   #1
gowings's Avatar
Trade: Remodel and Repairs
Rewards Points: 1,013
Wondering if you tilers are still bringing the waterproof board to just off the tub sill over the flange or maybe you devised a better method to alleviate strapping walls to bypass it. I wish they just made a Wedi, Schlutter or Prova board etc. that was revealed on the back side to drop over the flange. Like a 1 inch high x 1/4 deep rabbit. Man that would make things easier.
gowings is offline
Old 02-17-2019, 01:50 PM   #2
tjbnwi's Avatar
Rewards Points: 4,616
Re: Tub Flange Address For Waterproof Board Install
I rabbit cut the Kerdi board. Drop it to 1/4" from the tub deck. Tape the tub, fill the gap with Kerdi fix. Same way I do over fiberglass shower stalls.
tjbnwi is offline
Old 02-17-2019, 01:54 PM   #3
FloorsByAlex's Avatar
Trade: Flooring
Rewards Points: 140
I suppose you could modify the bottom row of boards that slip over the flange. Kerdi and goboard are just foam with a skin, easy enough to mod with a utility knife.
Sent from my LG-LS993 using Tapatalk
FloorsByAlex is offline
Old 02-17-2019, 02:26 PM   #4
90%-er
onmywayup's Avatar
Rewards Points: 2,450
Sure hope I haven't been screwing this up for fifteen years..... But I always set the backer board right on top of the flange, building out the wall a tiny bit if needed to make sure that the front of the board sticks out past the flange a half inch or so, then we tile right down to the top of the tub itself.
Then I usually caulk the tile-to-tub seam with color matched grout caulk.
onmywayup is offline
Old 02-17-2019, 02:34 PM   #5
Stunt Carpenter's Avatar
Rewards Points: 2,882
Same thing I do. Not much work to make the rabbit.
https://builddaley.com/
Stunt Carpenter is online now
Old 02-17-2019, 02:53 PM   #6
MarkJames's Avatar
Rewards Points: 19,363
I shmoo the gap with kerdifix or sikaflex.
MarkJames is offline
Old 02-17-2019, 05:56 PM   #7
diplomat
Golden view's Avatar
Rewards Points: 1,550
Do you waterproof?
Golden view is offline
Old 02-17-2019, 06:34 PM   #8
gowings's Avatar
Thank God
Someone does what I have a done few times. Its a little weak after the rabbit but I leave it a 1/4 off the bottom sill of the tub and fill that void in with waterproof caulk that I use for the joints. I just don't understand why the Kerdi fix is so much more expensive than the other competitors. That kerdi runs 25 bucks a tube at the wholesalers
With the newer style tubs these days the top sill of the tub is getting narrower so any depth I can save is a bonus for aesthetics.
gowings is offline
Old 02-17-2019, 06:35 PM   #9
rrk's Avatar
Rewards Points: 5,318
I staple kerdi band on the studs overlapping the tub lip and use kerdifix to adhere it to the tub lip then Durock ultralight board down to the lip. Very fast to install
rrk is offline
MarkJames (02-17-2019)
Old 02-17-2019, 07:05 PM   #10
90%-er
onmywayup's Avatar
Originally Posted by Golden view View Post
Do you waterproof?
Yeah. We tape and skim coat all the backer board seams, then hit it all with Red Gard. Sometimes two coats.
The Following User Says Thank You to onmywayup For This Useful Post:
Golden view (02-17-2019)
The war of plywood VS particle board Jimmy Cabinet Kitchens & Baths 47 09-18-2012 07:52 AM
Google Places - Address not in Service Area allcityexterior Marketing & Sales 4 06-17-2012 02:54 PM
Hidfast Gun redwood Decks & Fencing 28 06-08-2012 06:43 PM
achieving a paintable fireplace surround with cement board ajmackenzie Painting & Finish Work 17 01-23-2012 03:30 PM
Plywood vs particle board CarrPainting Roofing 27 07-14-2010 11:14 AM
