Transition- Tile To Carpet - Tiling - Contractor Talk
Old 06-03-2016, 07:46 PM   #1
Construction Connoissuer
CCCo.'s Avatar
Trade: Construction Remodeling - Renovations Repairs
Location: Kirklin, IN "Proudly Serving Central Indiana Area"
Rewards Points: 1,320
Any recommendations on a transition strip, looking for what will look the best ??
I think they're all ugly imo
In the past I've been provide more often than not the aluminum L strip
It always looks out of place in a residential setting to me, reminds me of a commercial building.
Is there another option? Whats your standard "go to" ?
Here's what I'm looking at finishing off. All the hardware will be brushed nickel.
Here, I'm going to end up right at about 1/2" higher than the tack strip you can see in this picture.
James Crow - Crow Contracting Company, LLC - Central Indiana Remodeling Contractor
Facebook l Youtube l Merchant Circle
Home, Kitchen & Bath Remodeling - ~ - Facility Maintenance & Repair Solutions
Want to contact us? - Call ~ 765.279.8271
CCCo. is offline
Old 06-03-2016, 07:48 PM   #2
slowsol's Avatar
Rewards Points: 2,248
Re: Transition- Tile To Carpet
They shim and turn and tack it here 95% of the time.
-John
slowsol is offline
The Following 2 Users Say Thank You to slowsol For This Useful Post:
charimon (06-04-2016), overanalyze (06-04-2016)
Old 06-03-2016, 08:30 PM   #3
mikeswoods's Avatar
Trade: interior remodeling
Rewards Points: 2,664
Marble transitions are dandy for places like that---
however, I make most of mine using oak or cherry---a table saw and a router with a round over bit---stain and spray varnish---done and made to fit---can even be made to over lap the tile or carpet to hide the cuts.
mikeswoods is offline
The Following User Says Thank You to mikeswoods For This Useful Post:
TNTRenovate (06-06-2016)
Old 06-03-2016, 09:10 PM   #4
CCCo.'s Avatar
I'm not sure there's enough carpet to fold, good idea though.
CCCo. is offline
Old 06-03-2016, 09:13 PM   #5
CCCo.'s Avatar
Had thought of wood, but I would want it to be flush with the tile.
I'm not wanting to build it up any more than I have to, the old strip looked like a wheel chair ramp
CCCo. is offline
Old 06-03-2016, 11:43 PM   #6
Hack
asevereid's Avatar
What about the Schluter Reno T?
Or would that be too much of a toe stubber?
How to figure your pricing:
http://goo.gl/Il8c2
L+M+O+P/ Pricing, Estimating, And Success
Charging tree fiddy per lineal BOB
asevereid is online now
Old 06-04-2016, 01:54 AM   #7
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,014
Maybe use a beveled Schluter or marble transition if the carpet is short otherewise have the carpet stretched and tucked.
overanalyze is offline
Old 06-04-2016, 09:48 AM   #8
CO762's Avatar
Trade: Organic Mold Farmer
Rewards Points: 4,534
you just realized this?
NY Times...."Prison Population Growing Although Crime Rate Drops..."
CO762 is offline
Old 06-04-2016, 09:53 AM   #9
CCCo.'s Avatar
Yep
Its best to just dangle it over the end
But I thought an ugly piece of trim might be nice!
CCCo. is offline
The Following User Says Thank You to CCCo. For This Useful Post:
CO762 (06-04-2016)
Old 06-04-2016, 09:59 AM   #10
CCCo.'s Avatar
In all reality I thought maybe someone had an idea I've never heard of, or seen before.
And since, well most here, have seen or done it all- I thought maybe, just maybe I could get a little more educated information ??
CCCo. is offline
Old 06-04-2016, 10:01 AM   #11
CO762's Avatar
Originally Posted by CCCo. View Post
Yep
tell them to call a flooring guy as their carpeting needs to be replaced.
The recommendations given are standard and sometimes ya just wind up "there".
CO762 is offline
Old 06-05-2016, 06:17 PM   #12
Tile-guy's Avatar
Trade: Tile installations
Rewards Points: 116
Schluter has different colour tile to carpet transitions.
Tile-guy is offline
The Following User Says Thank You to Tile-guy For This Useful Post:
Old 06-06-2016, 12:49 PM   #13
gowings's Avatar
Trade: Remodel and Repairs
Rewards Points: 983
I usually run schluter on the tile edge. Pick your color. Then kick the carpet to the schluter. Carpet layer sometimes doubles the tack strip to get the carpet even with the tile.
gowings is offline
The Following 2 Users Say Thank You to gowings For This Useful Post:
CCCo. (06-06-2016), overanalyze (06-09-2016)
Old 06-06-2016, 05:05 PM   #14
avenge's Avatar
Looks to me like you could have carried the tile halfway into the doorway then you would have enough.
avenge is online now
Old 06-06-2016, 06:45 PM   #15
CCCo.'s Avatar
[QUOTE=gowings;4819954]I usually run schluter on the tile edge. Pick your color. Then kick the carpet to the schluter. Carpet layer sometimes doubles the tack strip to get the carpet even with the tile.[/QUOTE
Thats pretty typical to how I've done it in the past, sometimes it looks good, sometimes ehh
CCCo. is offline
Old 06-06-2016, 06:49 PM   #16
CCCo.'s Avatar
Not sure I like that, then the tile would show out in the hallway with the door shut.
That's not real attractive
CCCo. is offline
Old 06-06-2016, 07:22 PM   #17
Tile-guy's Avatar
Rewards Points: 116
Tile is always run halfway the door. That way when the door is closed you see neither the carpet or tile. The tile sits way too far back.
Tile-guy is offline
The Following 2 Users Say Thank You to Tile-guy For This Useful Post:
Philament (06-06-2016), TNTRenovate (06-07-2016)
Old 06-06-2016, 07:31 PM   #18
CCCo.'s Avatar
I always transition the changing floors under the door, where ever the door may be, that where I put the break. Right under the door is where this is too.
This is also where it had been prior because its right up to the original hallway tack strip.
Nothing wrong here, try again
Sometimes doors are located toward the interior, and sometimes its opposite but my transition always goes under the door.
CCCo. is offline
Old 06-06-2016, 07:37 PM   #19
Tile-guy's Avatar
Rewards Points: 116
Sorry but the pictures shows the tile not centred under the door. That's why I'm mentioning it. Maybe you where waiting to get an answer for a transition before continuing the tile work.
Tile-guy is offline
CCCo. (06-06-2016)
Old 06-06-2016, 07:55 PM   #20
CCCo.'s Avatar
Of course, I just stopped there until I decided my definitive game plan for tying the two together.
Surely you wouldn't think I was just going to stop 6-8" away!
CCCo. is offline
Hardwood to carpet transition CarpenterSFO Flooring 7 06-29-2013 12:03 PM
Carpet and Tile on Metal Floors GTHill Flooring 34 01-12-2013 08:57 PM
Curved transition from hardwood to tile wannaBelkhuntin Tiling 9 07-09-2012 08:49 PM
Need help painting carpet GibsonGuy Painting & Finish Work 4 02-20-2012 11:28 PM
going rate for tile and carpet removal oldglorydev Flooring 18 09-21-2008 01:26 PM
