Tiling Walls On A Tub - Page 2 - Tiling - Contractor Talk
Old 01-05-2011, 08:32 PM   #21
Tile Contractor
HS345's Avatar
Trade: Ceramic and Natural Stone Tile Contractor
Rewards Points: 886
Re: Tiling Walls On A Tub
Originally Posted by charlesmd View Post
If im understanding this correctly, I have to chime in. Tubs move, sink, swell all according to the weight of water, the occupants, and the floor structure. No way should there be anything other than a flexible connection between the walls and tub...Dont even think about adhering tile to the tub lip, it will pop....
I have installed literally hundreds of tub surrounds in this manner, I have never had a single callback for tiles popping. Apparently you are either mistaken, or thinset doesn't bond to fiberglass.
Greg
HS345 is offline
Old 01-05-2011, 08:44 PM   #22
charlesmd's Avatar
Trade: Baths, basements, carpentry, int.remodeling
Rewards Points: 150
Thinset will bond to fiberglass, thinset will draw on tile when tub deflects, tile "may pop"(can be a fracture that cant easily be seen) or ever be detected, it can happen. Im not knocking anyone here, im just saying it can happen.
charlesmd is offline
Old 01-05-2011, 09:30 PM   #23
Renaissance Man
superseal's Avatar
Rewards Points: 5,846
I like shimming out over the flange, then applying cbu to 1/4" above tub sill. I know, a lot of extra work and may not be suitable for all applications but I ain't sleeping right unless the back side of the cbu is in front of the flange, regardless of kerdi, hydroban or redgard applications.
superseal is offline
Old 01-05-2011, 09:41 PM   #24
It's Not a Toomaa!!
HandyHails's Avatar
Trade: Remodels
Rewards Points: 1,000
This generally entails shimming the whole length of the wall and not just the area by the tub. This is the exact reason I started grinding a notch in the Cement Board. Especially if it is a tub and floor only project, this keeps me from having to patch more than a few inches of the existing drywall.
Josh
hhicontracting.com
HandyHails is offline
Old 01-05-2011, 09:59 PM   #25
Renaissance Man
superseal's Avatar
Not if your using mudcaps or trim but yea, i know what cha mean...
got away with it here tho
The Following User Says Thank You to superseal For This Useful Post:
HandyHails (01-05-2011)
Old 01-05-2011, 10:11 PM   #26
It's Not a Toomaa!!
HandyHails's Avatar
Trade: Remodels
Its always a pain in the ass to wrangle the tub into the space you pulled the old one from. Seems like 9 times out of 10 times I'm just pulling the POS one piece fiberglass tubs and replacing w/ acrylic and tiling walls and floor. I've tried every way I can think of, but I can never get the new tub in without cutting another chunk of drywall out. Sucks really. Not to mention that I really can't do it myself and won't even try w/ a mud bed for the new tub. Come to think of it, I really HATE installing standard tubs.
Josh
hhicontracting.com
Bathroom Walls weeping... HELP hbl164 Painting & Finish Work 19 09-08-2016 11:40 AM
Vapor Barrier with concrete block walls? pzeiler Insulation 0 04-21-2010 11:40 PM
Dimensions for circular walls and their openings UpNorth Framing 10 04-14-2010 09:01 PM
lifting walls with a forklift [email protected]#e Framing 26 03-22-2010 09:55 PM
Bridging for above grade Concrete Walls ETHICS05 Construction 1 11-21-2005 12:43 PM
