Tiling Walls On A Tub - Tiling - Contractor Talk
Old 12-31-2010, 06:37 PM   #1
Chief Reporter of Spam
Tech Dawg's Avatar
Trade: Kitchen and Bathroom Remodeling
Rewards Points: 1,290
Angus,
What's your protocall on tubs, I only use Swanstone - Veritk tubs and they specifically state that wall board has to sit on top of the lip for swan or tile installs which leaves about 1" to the tub tub lip. This is because of the self drainage feature and if a seal ever breaks the water will work its way to the cutaways on the skirt.
I'm working on an estimate and was figuring on just that, using cbu on walls with hydroban... any issues with a 1" space at the bottom of wall or I was thinking I could run it down further and use the kerdi fix...?
Todd
Alone Eagle Remodeling, LLC
Tech Dawg is offline
Old 12-31-2010, 09:12 PM   #2
Tech Dawg's Avatar
Re: Tiling Walls On A Tub
Or, maybe someone can give me a tip or two on this
Todd
Old 01-04-2011, 06:55 PM   #3
opiethetileman's Avatar
Trade: DIYer apparently
Rewards Points: 1,000
did ya get any tips yet???
opiethetileman is offline
Old 01-04-2011, 07:03 PM   #4
Tech Dawg's Avatar
No I guess stupid q. Idk, I figured i'll leave a little space for that style tub cuz they need to free float a little...was just wondering what others do.
Todd
Old 01-04-2011, 07:06 PM   #5
well i have been known the shove cotton there and tile off that. the cotton soaks up the water and allows it to drain.but regardless ya need to put spacers there of some kind and tile. i fill the tub half with water and then caulk it
Old 01-04-2011, 07:16 PM   #6
Tech Dawg's Avatar
Cotton between wall board and tub lip?
Todd
Old 01-04-2011, 07:30 PM   #7
Tech Dawg's Avatar
Ahh, I think I just walked past a good idea, I got a leftover kerdi curb in garage. Maybe I can rip some strips off on table saw to fill that gap some n make even to wall board...u think?
Todd
Old 01-04-2011, 07:39 PM   #8
It's Not a Toomaa!!
HandyHails's Avatar
Trade: Remodels
I've actually been using a cup grinder and hitting the back of the cbu enough to allow it to hang over the lip. Then I do like Opie and fill the tub and caulk after tile. Works well for me. Takes a little practice w/ the grinder.
Josh
hhicontracting.com
HandyHails is offline
Old 01-04-2011, 07:42 PM   #9
well we all have our methods of mad skill..I have put cotton in walls of showers with travertine in them and laced them back to the drain before. it is a everyday practice in brick mason. old school tile had cotton in them as well.
or foam and then the cbu
Old 01-04-2011, 08:25 PM   #10
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
Hard to say because each situation is different. I have done with Dan said about trimming the back of the backerboard. I've dropped Kerdi over the flange and used Kerdi-Fix.
You kind of have to think on the fly. I'd say the most used method (by me) is to trim the backerboard to fit over the flange.
Angus
angus242 is offline
Old 01-04-2011, 08:31 PM   #11
It's Not a Toomaa!!
HandyHails's Avatar
Trade: Remodels
Angus, You use a grinder or have you found a neater way?
Josh
hhicontracting.com
Old 01-04-2011, 08:41 PM   #12
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Depends what material you're using. Mostly, I use DensArmor so I just use a razor to trim.
Angus
angus242 is offline
The Following User Says Thank You to angus242 For This Useful Post:
HandyHails (01-04-2011)
Old 01-04-2011, 09:04 PM   #13
well haha I have used a router bosh colt to be exact to biscut notch the back lip for a tub. just notch out the board and install it
The Following User Says Thank You to opiethetileman For This Useful Post:
Old 01-04-2011, 10:12 PM   #14
It's Not a Toomaa!!
HandyHails's Avatar
Trade: Remodels
I got one of those colts too. I'll give that a try next time. Thanks Dan.
Josh
hhicontracting.com
Old 01-05-2011, 09:11 AM   #15
only if you are using densarmor...not durock
Old 01-05-2011, 05:53 PM   #16
Paul
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Rewards Points: 1,004
Ripping down some foam and Kerdi-Fixing it in place sounds like the best idea to me.
Precision Floors
(772) 237-9900
PrecisionFloors is offline
Old 01-05-2011, 06:48 PM   #17
Tile Contractor
HS345's Avatar
Trade: Ceramic and Natural Stone Tile Contractor
Rewards Points: 886
Originally Posted by Tech Dawg View Post
Angus,
Can you post a link, or a diagram of the installation instructions. I can't seem to find one on the web. I hate that. Reputable companies should have easy access to spec sheets and installation instructions.
On tubs with a lip, I normally bring the board (drywall in my case) to the top of the lip, and just fill the gap with thinset. I then Kerdi down to the tub and seal the Kerdi to the tub with Kerdi Fix.
I know you're planning on using Hydroban, but I would like to see a diagram of the tub in question for future reference.
Greg
HS345 is offline
Old 01-05-2011, 07:49 PM   #18
charlesmd's Avatar
Trade: Baths, basements, carpentry, int.remodeling
Rewards Points: 150
If im understanding this correctly, I have to chime in. Tubs move, sink, swell all according to the weight of water, the occupants, and the floor structure. No way should there be anything other than a flexible connection between the walls and tub...Dont even think about adhering tile to the tub lip, it will pop....
charlesmd is offline
Old 01-05-2011, 07:58 PM   #19
Tech Dawg's Avatar
It should be somewhere on www.swancorp.com but they don't have very good pictures in the manual
I mix up a full bag of thinset and spread on the floor before I set it, on a swan wall I use green board on top of the lip, but one thing u have to do is notch the dw around the clips so it doesn't push the wall board out... I have no issues with the swan walls cuz the wall is one sheet the whole way across. Typically I will add some globs of silicone along the skirt for some support but you cannot trap the clips with silicone because that is part of the process for the little bit of flex with heat...
Todd
Old 01-05-2011, 08:13 PM   #20
Tech Dawg's Avatar
The pics are bad and turned out blurry, the wall prep photo was taken pretty much before I notched the greenboard around the clips and dropped it down to the top of tub lip
tiling walls on a tub-day-job-pics-004.jpg   tiling walls on a tub-day-job-pics-003.jpg   tiling walls on a tub-day-job-pics-001.jpg
Bathroom Walls weeping... HELP hbl164 Painting & Finish Work 19 09-08-2016 11:40 AM
Vapor Barrier with concrete block walls? pzeiler Insulation 0 04-21-2010 11:40 PM
Dimensions for circular walls and their openings UpNorth Framing 10 04-14-2010 09:01 PM
lifting walls with a forklift [email protected]#e Framing 26 03-22-2010 09:55 PM
Bridging for above grade Concrete Walls ETHICS05 Construction 1 11-21-2005 12:43 PM
