Tiling Shower Vapor Barrier Behind Hardi? - Tiling - Contractor Talk
Old 02-03-2012, 09:28 AM   #1
duburban's Avatar
Trade: building
Rewards Points: 1,754
When I tile a shower I hardibacker and liquid membrane the whole shower, two coats.
I'm working with a friend on one of his projects and our local tile supply told him to only liquid membrane the joints because the hardi and thin set both have a mold blocker added.
I think this is silly, liquid membrane is expensive but also a very high quality product.
If we don't membrane the whole shower does this mean we need a vapor barrier behind the hardi?
duburban is offline
Old 02-03-2012, 09:38 AM   #2
Tile Contractor
HS345's Avatar
Trade: Ceramic and Natural Stone Tile Contractor
Rewards Points: 886
Re: Tiling Shower Vapor Barrier Behind Hardi?
If you're not going to liquid membrane the whole shower, you might as well just put a moisture barrier behind the Hardi and be done with it.
Does the framing, insulation, sheathing, etc have a "mold blocker" as well?
I love when tile shops give out such well informed "advice".
It's always better to follow the manufacturer's instructions than to take any anecdotal advice from a tile shop.
Greg
HS345 is offline
Old 02-03-2012, 09:39 AM   #3
JohnFRWhipple's Avatar
Trade: Linear shower drain installations & waterproofing
Rewards Points: 2,000
Sadly code allows this type of installation.
Your technique is better in my opinion but I would double check you are getting the right coverage with two coats of liquid.
We use liquid all the time and getting a proper 22mil thickeness can be tough with 2 coats only.
When prepping for liquid membrane we wash all bond breakers and dust away. The first coat is burned into the backer by brush and we work it in all directions. It almost dries straight away so we then go back and hit it with the "Johnny Roller". That is coat one.
Second coat is a roll on coat.
When your done measure your container and determine if you have the proper amount of product left. If not a third and final coat will be needed. Expierment with different brushes and rollers until you find a pair that does the job.
If you wish - here in Vancouver you can just bang up Hardie, tape the seams and your good to go. This gets done all the time. There is no shortage of work in this industry because most people build showers to last maybe 3-10 years at most.
JohnFRWhipple is offline
Old 02-03-2012, 11:09 AM   #4
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
Did they happen to mention how to tie in the bottom of the vapor barrier to the PVC pan liner as well?
This method is nick named, water in-water out. That's because the substrate is allowing moisture through it. The vapor barrier is the last line of defense and directs this extra moisture down towards the pan. A vapor barrier that isn't tied properly into the pan liner, will just collect the moisture and deposit it to the lower part of the framing.
This also means the pan and liner need to be properly installed. But that's a whole other thread.
Now doesn't it just make so much more sense to <sarcasm> spend all that extra big cash </sarcasm> on a liquid and just keep moisture out of the substrate in the first place?
Angus
angus242 is offline
Old 02-03-2012, 03:48 PM   #5
duburban's Avatar
Trade: building
This is a cheapo shower with a swanstone base. I would agree its obviously worth membraning while you can. With this stuff we so often go by word, the word of fellow tradesman or the manufacturers. If you were all installing this way with 100% confidence I'd run with it, but no one is, as i suspected.
duburban is offline
Old 02-12-2012, 07:12 PM   #6
BuildersII's Avatar
Trade: General
Rewards Points: 250
Redgarding hardibacker with two coats? You're working too hard using products that are not installer friendly. Kerdi / Wedi make sheet membranes that are easier to install right over the hardibacker, or even just regular drywall for that matter. As I said in another thread, DensShield with a good sealant is the easiest method I've found.
BuildersII is offline
Old 02-12-2012, 07:15 PM   #7
duburban's Avatar
Trade: building
Thanks, I'll look into it. I'm really just going with the system that has the least learning curve. I think the roll on membranes and kerdi drains make for a pretty easy custom shower pan. I'll ask the tile supplier about the den shield next time.
duburban is offline
Old 02-12-2012, 07:48 PM   #8
BuildersII's Avatar
Trade: General
Rewards Points: 250
For shower pans, I highly, highly recommend the Wedi foam system. Super easy, super light, and has very good statistics where it's been used over time in Germany.
Old 02-12-2012, 08:54 PM   #9
Jdub2083's Avatar
Trade: General Contracting / Commercial Carpenter
Rewards Points: 282
I don't think its a bad idea to put a vapor barrier up anyway. It's not that expensive and its just another layer of protection.
Jdub2083 is offline
Old 02-12-2012, 10:12 PM   #10
BuildersII's Avatar
Trade: General
Rewards Points: 250
It can't hurt, you're right.
Still, I'd never rely on one and I'd certainly never use CBU without a membrane layer over it. I'm not a fan of the CBU products because they soak up water and eventually fall apart. I've pulled out hardibacker that's had exposure to water over time and it basically had the consistency of soggy cardboard. Tile falls right off of it after the first fibrous layer that the thinset is attached to goes. Even if the tile holds on, the plastic behind the board has holes in it where moisture can collect and start mold/rot on the studs, or worse, an actual dripping leak could form.
Edit: Oh yeah, and moisture in the studs is just inviting termites to set up a nest in your home. For those who don't know, termites need a water source near the wood they eat.
Old 02-12-2012, 10:24 PM   #11
skillman's Avatar
Rewards Points: 1,968
Why would you want to trap moisture in the walls if its not a steam shower with vapor barrier. Your going to screw it to wood anyway and theirs your holes in vapor barrier so theres goes your air seal.
Unto i joined this site i never heard anyone use wedi , kerdi around hear. Hardi , durock seal seams with thinset or mastic and tile. Liquid membrane thats funny.
skillman is offline
Old 02-13-2012, 07:52 PM   #12
CO762's Avatar
Trade: Organic Mold Farmer
Rewards Points: 4,534
The age old debate (that involves a lot of things other than slapping up board and tile).
CO762 is offline
Old 02-13-2012, 08:09 PM   #13
Jdub2083's Avatar
Rewards Points: 282
Whats funny is that you dismiss the idea of waterproofing a shower.
Jdub2083 is offline
Old 02-13-2012, 09:18 PM   #14
skillman's Avatar
Im not really dismiss it. In which we waterproof showers. That the idea that if we dont do it new school some how old school is stupied and wrong in which has been done for years and worked well. Many ways to skin a cat.
skillman is offline
Old 02-13-2012, 09:59 PM   #15
Hair Splitter
TNTRenovate's Avatar
Trade: General
Rewards Points: 1,244
I think you need to see Angus or Whipple about PERM ratings of your methods. While they may last in some circumstances, I think that more often than not, we open the wall to find: moisture, mold or wet materials.
Tried & True on Facebook
Tried & True Website
TNTRenovate is offline
The Following User Says Thank You to TNTRenovate For This Useful Post:
Jdub2083 (02-14-2012)
Old 02-13-2012, 10:03 PM   #16
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
I say let people build how they want to. Its job security for the rest of us.
ohiohomedoctor is offline
The Following 2 Users Say Thank You to ohiohomedoctor For This Useful Post:
Jdub2083 (02-14-2012), TNTRenovate (02-13-2012)
Old 02-13-2012, 10:04 PM   #17
Hair Splitter
Trade: General
Second time you have made me laugh today! Keep up the good work!
Old 02-13-2012, 10:05 PM   #18
Dont forget to hit the thanks button. :
The Following User Says Thank You to ohiohomedoctor For This Useful Post:
Old 02-13-2012, 10:07 PM   #19
Hair Splitter
Trade: General
Thought I had...oops! I am usually very good at that.
Old 02-13-2012, 10:07 PM   #20
Custom shower base - granite Charles_cz Tiling 16 01-08-2015 09:34 PM
Strange shower leak - need help JSMHDM Plumbing 13 12-06-2010 05:38 AM
tub spout to shower wand lshomesolutions Plumbing 1 06-08-2010 08:42 PM
tiling shower drain KMJR General Discussion 2 03-30-2010 04:12 PM
tiling shower and seat [email protected] Tiling 85 10-22-2008 06:15 PM
