Tile Blade Tip - Tiling - Contractor Talk
Tile Blade Tip
Old 04-13-2012, 02:31 AM   #1
Aaron Tritt's Avatar
Trade: Tile Installation
Rewards Points: 150
Tile Blade Tip
Hey all,
I learned a trick yesterday from a friend of mine that owns a rock quarry. He has lab tested this, and proven that it works.
When you are using your wet diamond blade saw, add a little bit of biodegradable soap to the water. The saw blade will last significantly longer.
The main benefit to this is lowering the surface tension of the water.
This allows the blade to stay cooler, cut smoother, and also for the sediment to fall out of the water sooner, and this is better for the pump too.
Aaron Tritt
Custom Expressions LLC
Insured, NTCA Member, BBB accredited
Aaron Tritt is offline
The Following 8 Users Say Thank You to Aaron Tritt For This Useful Post:
charimon (04-13-2012), dan_s (04-13-2012), goneelkn (04-15-2012), katoman (04-14-2012), larry228 (04-13-2012), PrecisionFloors (04-13-2012), Tech Dawg (04-13-2012), TimelessQuality (04-13-2012)
Old 04-13-2012, 05:39 AM   #2
GO Remodeling's Avatar
Rewards Points: 96
Re: Tile Blade Tip
Thanks, I'll give it try. A friend of mine that runs the Forestry Division at a village said that they mix a little liquid soap into the sprayers. It makes the chemicals seep into the soil faster according to him. Never thought about it for the wet saw.
GO Remodeling is offline
Old 04-13-2012, 05:47 AM   #3
CSinMa's Avatar
Trade: more Pro than Con
Rewards Points: 75
Re: Tile Blade Tip
I always just cut a red brick to clean my diamond blades, soap just gets dry and crusty, what a pain to clean later.
I've seen it done once from a distance !
CSinMa is offline
Old 04-13-2012, 06:15 AM   #4
Chief Reporter of Spam
Tech Dawg's Avatar
Trade: Kitchen and Bathroom Remodeling
Rewards Points: 1,282
Re: Tile Blade Tip
Good tip I'll give'r a try and see how it works!
Todd
Alone Eagle Remodeling, LLC
Tech Dawg is offline
Old 04-13-2012, 07:16 AM   #5
JohnFRWhipple's Avatar
Trade: Linear shower drain installations & waterproofing
Rewards Points: 2,000
Re: Tile Blade Tip
Originally Posted by Aaron Tritt View Post
Hey all,
Thanks Aaron.
JohnFRWhipple is offline
Old 04-13-2012, 07:52 AM   #6
Groutface
Groutface's Avatar
Trade: flooring installer
Rewards Points: 524
Re: Tile Blade Tip
Hmmmmm good tip
Groutface is offline
Old 04-13-2012, 12:53 PM   #7
Paul
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Rewards Points: 1,004
Re: Tile Blade Tip
Makes perfect sense if you have ever done any experiments with surface tension. Thanks!
Precision Floors
(772) 237-9900
PrecisionFloors is offline
Old 04-13-2012, 03:34 PM   #8
It's Not a Toomaa!!
HandyHails's Avatar
Trade: Remodels
Rewards Points: 1,000
Re: Tile Blade Tip
I'm wondering what a "little bit" really is. Couple of drops per five gallons? Teaspoon? Tbsp?
Josh
hhicontracting.com
HandyHails is offline
Old 04-13-2012, 06:32 PM   #9
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 76
Re: Tile Blade Tip
I never had the guts to dump a bottle of detergent into the fountain at the mall.
Tinstaafl is online now
Old 04-13-2012, 07:32 PM   #10
Wearer of Hats
Ethos's Avatar
Trade: Kitchen and Bath Remodel
Rewards Points: 294
Re: Tile Blade Tip
Yeah, I'd like to know too. It'd suck to try to cut through all the foam my water pump would generate
Ben - Ethos Kitchen and Bath
http://www.kcethos.com
Ethos is offline
Old 04-13-2012, 07:43 PM   #11
Hair Splitter
TNTRenovate's Avatar
Trade: General
Rewards Points: 1,244
Re: Tile Blade Tip
I think that the biodegradable would prevent any build up.
I would think a drop in the bucket!
Tried & True on Facebook
Tried & True Website
TNTRenovate is offline
Old 04-13-2012, 07:46 PM   #12
Splinter hands's Avatar
Re: Tile Blade Tip
Do it Tin and take pictures and post them here for us.
Splinter hands is offline
Old 04-13-2012, 08:38 PM   #13
Bathroom Remodeler
srwcontracting's Avatar
Trade: Bathroom Remodeling
Rewards Points: 560
Re: Tile Blade Tip
Thanks for the tip!
When will we get a thank you button for mobile devices?
srwcontracting is offline
Old 04-13-2012, 08:52 PM   #14
Groutface
Groutface's Avatar
Rewards Points: 524
Re: Tile Blade Tip
Originally Posted by srwcontracting
Thanks for the tip!
Go to menu then thank instead of quote.....yep
The Following User Says Thank You to Groutface For This Useful Post:
srwcontracting (04-13-2012)
Old 04-13-2012, 08:52 PM   #15
Tech Dawg's Avatar
Re: Tile Blade Tip
Thanks for the tip!
Do you have a touch phone?
Todd
Old 04-13-2012, 09:00 PM   #16
Bathroom Remodeler
Rewards Points: 560
Re: Tile Blade Tip
iPad.....am I missing something? Ha....didn't realize "like" meant thank you....
Old 04-13-2012, 09:24 PM   #17
astor's Avatar
Trade: FI
Rewards Points: 704
Re: Tile Blade Tip
pour just a bottle of COOL AID.,forget the soap
astor is offline
Old 04-14-2012, 02:36 PM   #18
Paul
Re: Tile Blade Tip
Just a few drops well affect the surface tension of several gallons of water, so I'd assume that would be a good start. You definitely don't want to add enough to make it foam up when pumped lol. I can thank posts on my Android by just touching and holding on the post which pulls up a menu to thank, reply, or quote.
Precision Floors
(772) 237-9900
The Following User Says Thank You to PrecisionFloors For This Useful Post:
HandyHails (04-14-2012)
Old 04-14-2012, 06:35 PM   #19
Groutface
Groutface's Avatar
Rewards Points: 524
Re: Tile Blade Tip
Same here there is a thread in general discussion that needs your Android backing
Bought a new Ridgid tile saw...any reviews here? IHI Tiling 45 11-24-2012 01:03 PM
Fein blade sharpening WilsonRMDL Tools & Equipment 34 08-05-2012 09:41 PM
Some install questions on $ 27. sq ft tile backsplash SKC Tiling 12 03-20-2011 08:44 AM
Drywall over ceramic tile kirkwahl Drywall 9 10-02-2009 09:11 AM
