Subfloor: Adding 1/8" Gap After Install - Tiling - Contractor Talk
Old 03-10-2019, 09:40 PM   #1
1900farmhouse's Avatar
Trade: Renovation
Rewards Points: 4
I've got a tile job where a 0.75" OSB subfloor was laid 3 years ago on top of 100 year old joists. Whoever did the job added new joists to help support the larger spans.
The subfloor was laid without 1/8" gapping between panels opposite the tongue and grove; nor does it appear any gap was left along the tongue and grove.
Given that the OSB has been nailed in and adjusted to the climate for 3 years, it is necessary -- or even helpful -- to cut in the 1/8" gap now? How about the T&G side: Is it better to destroy the T&G by cutting in a 1/8" gap?
In some places the seam is under the wall and may be hard to reach.
Thanks
Steve
1900farmhouse is offline
Old 03-10-2019, 10:11 PM   #2
finisher65's Avatar
Trade: Drywall/carpentry
Rewards Points: 44
Re: Subfloor: Adding 1/8" Gap After Install
For real? Cut out the tongue & grove? Have you ever had T&G subfloor fit together & looked at it from the end, the cross section?
finisher65 is offline
Old 03-10-2019, 10:46 PM   #3
avenge's Avatar
Rewards Points: 538
Are you a contractor?
avenge is online now
Old 03-11-2019, 02:19 AM   #4
hdavis's Avatar
Rewards Points: 7,360
Don't cut it up.
hdavis is online now
SmallTownGuy (03-11-2019)
Old 03-11-2019, 07:05 AM   #5
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 3,266
Cut it up.
Big Johnson is offline
The Following 4 Users Say Thank You to Big Johnson For This Useful Post:
Bull Trout (03-11-2019), finisher65 (03-11-2019), hdavis (03-11-2019), SmallTownGuy (03-15-2019)
Old 03-13-2019, 08:05 PM   #6
Trade: Renovation
Rewards Points: 4
The T&G is slammed together, the built in gap on the surfaces isn't there any longer.
I hear leave it, and I hear cut it up -- any justification?
thanks
Steve
Old 03-13-2019, 08:27 PM   #7
Texas Wax's Avatar
Rewards Points: 1,548
thanks
Steve
What's the problem? Been acclimated for 3 years, What's the issue you want to avoid or existing issue-problem effecting tile install. Beyond over thinking this.
How do you know it wasn't gapped 1/8" and just expanded swelled after?
...as the page loads, so go the days of our lives, at CT
Texas Wax is offline
Old 03-13-2019, 08:33 PM   #8
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 3,702
I'd go to a hardware store and ask for 100 linear feet of 1/8" gap.
Inner10 is offline
Navigatorgt (03-16-2019)
Old 03-14-2019, 09:20 PM   #9
Bull Trout's Avatar
Rewards Points: 430
thanks
Steve
If it is slammed together you should definitely cut it up
Bull Trout is online now
Old 03-16-2019, 09:48 AM   #10
cedarboarder's Avatar
Trade: Workaholic
Rewards Points: 1,760
over slammed t and g?
Sent from my SAMSUNG-SM-G891A using Tapatalk
cedarboarder is offline
Old 03-16-2019, 10:47 AM   #11
Inner10's Avatar
This should be thread of the year.
Read the manufacturer's instructions, most is made where the T&G is self spacing and it meant to be rammed together, the 1/8" gap is for the 4' side of the boards.
If it's been there for 3 years and looks fine do you really thing it's worth cutting it up?
Inner10 is offline
Old 03-16-2019, 12:51 PM   #12
Bull Trout's Avatar
Rewards Points: 430
Yep
Old 03-17-2019, 07:25 PM   #13
Put a straight edge on the gaps to check for swelling. If there’s any, rent a drum sander and go to town. Gap or not you can still get edge swell.
General Contractor looking for advice, Thank you Dukelewis8719 General Discussion 38 09-26-2015 12:00 PM
Paint walls than install trim? Birdland Bldrs Painting & Finish Work 60 09-08-2015 11:34 PM
Door install with thick exterior foam? iHandy Windows, Siding and Doors 16 09-22-2010 08:47 PM
Gutter Apron Install Advice Gladiatorx Roofing 2 08-13-2010 02:36 PM
