Straight Onto The Subfloor. - Tiling - Contractor Talk
Old 09-21-2015, 05:27 PM   #1
Punching above his weight
Easy Gibson's Avatar
Trade: Gun for hire.
Rewards Points: 15,194
Doing a bathroom mini remodel. Does not include floors.
Pulled out the old vanity, the tile is thinset'd straight onto the subfloor. Would be an "it is what it is" situation, but three of the little bastards popped up. I stupidly poked around and popped three more from along the edge. That looks like the extent of the old water damage.
So look, you can see where this is going...
Customer is not doing the floor. Rest of it is fine.
What do I use to reset these half a dozen tiles back onto the plywood? Also, what if anything can I do to the plywood beside sand the age off it a bit?
Thank you oh wise ones.
Easy Gibson is online now
Old 09-21-2015, 05:30 PM   #2
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
Re: Straight Onto The Subfloor.
Maybe something like Eco prime grip if your worried about it bonding well.
www.bcconstructionllc.com
BCConstruction is offline
Old 09-21-2015, 05:38 PM   #3
I am.
I'm afraid the plywood will suck the moisture out of the thinset and they'll pop up again.
Old 09-21-2015, 09:07 PM   #4
MIKE ANTONETTI's Avatar
Trade: FLOORING CONTRACTOR
Rewards Points: 3,514
Where did the thinset end up sticking to?
I've contemplated and have done some grinding of thinset off back of tile, but risky if it cracks.
MIKE ANTONETTI is offline
Old 09-21-2015, 09:08 PM   #5
TaylorMadeAB's Avatar
Trade: Renovations
Rewards Points: 1,686
Can you wet the plywood beforehand?
TaylorMadeAB is offline
Old 09-21-2015, 09:23 PM   #6
tjbnwi's Avatar
Rewards Points: 1,062
Pam Tite hot glue gun.
tjbnwi is online now
Old 09-21-2015, 09:40 PM   #7
Paul
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Rewards Points: 1,004
Any good modified thinset will do the job. Thinset sticking to plywood is not an issue, deflection is. A slab will suck the moisture out of thinset quicker than plywood will...
Precision Floors
(772) 237-9900
PrecisionFloors is offline
The Following 7 Users Say Thank You to PrecisionFloors For This Useful Post:
aptpupil (09-22-2015), avenge (09-21-2015), Big Shoe (09-23-2015), Golden view (09-21-2015), Metro M & L (09-21-2015), TNTRenovate (09-26-2015)
Old 09-21-2015, 09:42 PM   #8
The tiles were cracked and cut out to fit the old vanity. They're basic white 8" square jobbers. Going to pick up some new ones tomorrow.
Thinset ended up either entirely stuck to the tile, or entirely stuck to the floor. There was a busted pipe in the sink years and years ago and the water damage pattern on the floor confirmed to me that the issue is long gone. Dry as a bone, but there was staining on the mortar.
Good times.
Old 09-21-2015, 10:43 PM   #9
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 560
This.
Golden view is online now
Old 09-22-2015, 09:02 AM   #10
Thanks, I feel much better now.
Love this forum.
Old 09-22-2015, 09:25 AM   #11
Trade: Renovations
Love this forum.
Why don't you marry it then?
The Following 2 Users Say Thank You to TaylorMadeAB For This Useful Post:
Easy Gibson (09-22-2015), robtrayus (09-26-2015)
Old 09-22-2015, 07:19 PM   #12
Paul
I mean, he's getting the milk for free....
Precision Floors
(772) 237-9900
The Following User Says Thank You to PrecisionFloors For This Useful Post:
SamM (09-22-2015)
Old 09-22-2015, 08:52 PM   #13
Hey, amusing wrinkle here.
It should also be noted, this has happened to me every single time I've ever tried to replace a piece of tile.
"Oh, you want that? Maybe 15 years ago. Good luck. Nobody makes that color, shape, thickness, or material tile anymore."
Cool, I guess I'll just burn the house down.
Old 09-22-2015, 09:55 PM   #14
Paul
Not sure how the current layout is, but you could pop out a few more and incorporate a border that wraps around the new vanity, essentially making it look like it was part of the original design. Of course that could take more time than just demoing the whole thing and straight laying something a little more modern...
Another idea. Are the salvaged tiles big enough to split and relay just so they cover the footprint of the vanity and not necessarily underneath it?
Precision Floors
(772) 237-9900
Old 09-22-2015, 10:09 PM   #15
Believe me I already went through this.
I'm short. There were none under the vanity.
Tomorrow I go see Fuda. They tell me they sell a white 8x8. I need a slightly off white 8x8, but I'll go check it out anyway.
Every time with this nonsense.
Old 09-22-2015, 10:45 PM   #16
hdavis's Avatar
Rewards Points: 1,546
Quit messing around with stuff, there isn't any upside.
Or keep messing with stuff, and spend you free time combing the country for exact matches.
Your choice.
hdavis is offline
Old 09-22-2015, 10:57 PM   #17
Trade: Renovations
That's the stuff that kills a contractor! All this piddly little garbage.
The Following 3 Users Say Thank You to TaylorMadeAB For This Useful Post:
aptpupil (09-23-2015), gym (09-23-2015)
Old 09-23-2015, 12:01 AM   #18
VinylHanger's Avatar
Rewards Points: 11,492
Yep. I despise the piddly stuff. Trying to match an old piece of trim, old door handles, a three inch piece of laminate, a latch for an old window, or even a new window. The little things kill you.
VinylHanger is offline
Old 09-23-2015, 06:45 AM   #19
Big Shoe's Avatar
Rewards Points: 2,066
School of Hard Knocks. ...........I thought you would have graduated by now.
Expect the Unexpected
Big Shoe is offline
Old 09-23-2015, 07:29 AM   #20
Going for my Masters of Punishment Gluttony.
I cleared one hurdle by finding a kid who can paint, actually shows up, and doesn't talk like a sailor in the brig.
He's going to paint two bathrooms while I do on a three hour tour chasing this piddling nonsense, which is indeed killing me.
The Following User Says Thank You to Easy Gibson For This Useful Post:
Subfloor with unstaggered joints: Laminate to be installed. asevereid Flooring 2 11-12-2012 07:34 AM
Uneven Concrete Meets Subfloor Handy Hero Flooring 6 09-30-2012 04:59 PM
Subfloor advise SeasideCA Flooring 9 01-11-2010 04:36 PM
High moisture in subfloor RJ Tile Flooring 8 06-19-2009 05:37 AM
Removing Porcelain Tile on Stapled and Glued Subfloor ParaDiddle777 Flooring 20 11-08-2008 09:48 PM
