Soothing The Edge Of Porcelain Tile After Snap Cutting - Tiling - Contractor Talk
Old 02-01-2019, 05:35 PM   #1
nickko's Avatar
Trade: remodeling-cabinet maker
Rewards Points: 849
Hi
I bought a 24" Montolit tile cutter and as nice as it cuts it still leaves a jagged edge on the tile. Is any one using a diamond pad on an angle grinder to smooth the edge of porcelain tile after snap cutting?
I don't need a smooth finished edge. I would like to just clean up some of the jagged edge. I was thinking maybe a 70 grit diamond pad on a angle grinder.
thanks...........nicko
"Quality work for those who know the difference"
nickko is offline
Old 02-01-2019, 06:32 PM   #2
MarkJames's Avatar
Rewards Points: 19,473
Re: Soothing The Edge Of Porcelain Tile After Snap Cutting
Keep your cuts out of the field, and use a rubbing stone when necessary:
https://www.homedepot.com/p/QEP-Tile...022Q/100037081
MarkJames is offline
TNTRenovate (02-02-2019)
Old 02-01-2019, 08:41 PM   #3
nickko's Avatar
Rewards Points: 849
Thanks MarkJames
I have one of those rub stones and there ok for ceramic or just a few tile here and there. I do keep my cuts out of the field but for out side corners against bull nose and for inside corners and there are times when I'm doing certain tile patterns on wall tile where you have to have cut tile in the field.
I was thinking about a diamond pad on a cordless grinder sitting at my tile cutter. I could make a cut and then if the need arises i could hit the edge with the diamond pad.
Thanks......nicko
nickko is offline
Old 02-01-2019, 08:52 PM   #4
tjbnwi's Avatar
Rewards Points: 4,734
https://www.rubi.com/us/tile-and-sto...shing-pads-f15
tjbnwi is offline
Frank Castle (02-01-2019)
Old 02-01-2019, 10:03 PM   #5
nickko's Avatar
Rewards Points: 849
Originally Posted by tjbnwi View Post
Thanks for the info.
nicko
nickko is offline
Old 02-01-2019, 10:18 PM   #6
tjbnwi's Avatar
nicko
Wear safety glasses.
tjbnwi is offline
Old 02-01-2019, 11:53 PM   #7
avenge's Avatar
Rewards Points: 302
I use my grinder with a diamond blade at an angle.
avenge is offline
Old 02-02-2019, 07:21 AM   #8
goneelkn's Avatar
Trade: home remodel/repair
Rewards Points: 52
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
goneelkn is offline
Old 02-02-2019, 02:08 PM   #9
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 1,852
Never could understand buying a snap cutter, then using an angle grinder with a diamond blade to fix it.
Why not just use a tile saw.
Old 02-02-2019, 03:58 PM   #10
diplomat
Golden view's Avatar
Rewards Points: 1,550
These hand polishing pads work amazingly well to just break an edge. Faster than you'd expect. I use them on all exposed edges, even when put through a wet saw with a high end blade.
https://www.amazon.com/KGS-Diamond-H...diamond+sponge
Golden view is offline
Old 02-02-2019, 04:13 PM   #11
Hair Splitter
TNTRenovate's Avatar
Trade: General
Rewards Points: 1,268
90% of your cuts can be made on a snapper. And even if you have to clean up a tile or two your grinder is already out and setup for other cuts a wet saw or snapper cannot make. So you take 30 seconds to clean up a tile. A lot faster than a wet saw all around, IMO.
Tried & True on Facebook
Tried & True Website
TNTRenovate is offline
The Following User Says Thank You to TNTRenovate For This Useful Post:
heavy_d (02-06-2019)
Old 02-02-2019, 04:19 PM   #12
Hair Splitter
Trade: General
To the OP, I would need to see what you mean by jagged. I have had some issues with snappers but it's usually been due to material or wrong cutting wheel for the material.
I have also had no issue with most porcelain and a dressing stone. If it's not cleaning up the bit that you need, then there is something else going on.
As for bullnose and profiles our cut side goes in and the factory side goes toward the bullnose or profile. You are more likely to see the cut if you but against the profile or bullnose. Inside corners get caulked and should be decent enough that caulk will cover any imperfections.
Lastly, there is something called the 6' rule. You shouldn't be standing 3' from the tile and point out imperfections. It should look good from 6' away. Nothing is prefect in this world so while I strive for perfection, you sometimes have to let it go.
I can't tell you how many jobs I have been back on, after leaving not 100% satisfied with every detail, and either can't find those imperfections or realize how dang good our jobs look because we worried about those details.
overanalyze (02-02-2019)
Old 02-02-2019, 04:52 PM   #13
avenge's Avatar
Rewards Points: 302
I had to cut all 4 corners off 18 x 18 tile to lay a 6 x 6 at the corners. Even though I cut the corners off with my wet saw I still had to take off the sharp edge.
avenge is offline
Old 02-03-2019, 09:37 AM   #14
nickko's Avatar
Rewards Points: 849
By jagged edge i mean the face of the tile is a nice clean cut but below the face there is still porcelain that is sticking out beyond the score line. It will cover when grouted in but i would just like to clean it up at times.
As far as the cutting wheel it is a Montolit tile cutter with there titanium coated wheel.
Thanks......nicko
nickko is offline
Old 02-03-2019, 10:31 AM   #15
avenge's Avatar
Rewards Points: 302
Thanks......nicko
Rather hard to know without pics but don't think I've had that issue with my snapper, don't know why you can't use a grinder with a diamond wheel or nippers, I wouldn't use polishing pads for areas that are getting covered.
avenge is offline
Old 02-03-2019, 10:40 AM   #16
tjbnwi's Avatar
Try a little less pressure on the cuter handle when you're scoring. Once you get it right, you'll know "that sound".
tjbnwi is offline
TNTRenovate (02-03-2019)
Dry Pack for laying porcelain tile on exterior patio Kyong Tiling 9 07-31-2019 11:37 AM
Hardwood to Tile transition 239STAIRS Flooring 5 07-08-2012 06:16 PM
Wall tiles in shower ? #1 Handyman Tiling 14 06-25-2012 09:45 PM
Porcelain Tile Porch jbtn9 Flooring 1 09-22-2009 03:45 PM
Cutting 24" porcelain tiles KellyD&B Flooring 5 08-19-2009 11:00 AM
