Some Install Questions On $ 27. Sq Ft Tile Backsplash - Tiling - Contractor Talk
Old 03-19-2011, 10:27 AM   #1
SKC's Avatar
Trade: Carpenter and General contracting
Rewards Points: 25
Question
I am a carpenter not tile guy and have installed tiles before, but have no experience with this small tile, glass, and foil back.
I have a 30 sq ft tile job to do as Kitchen counter backsplash.
Tile is 1/2" X 1/2" on 12 " sq sheet with foil back, mixed glass and tumbled marble. cost $ 27. sq ft, client supplied.
Does foil remain on back? which size trowel if yes and which if no ?
Store is supplying Tec double duty adhesive, is this right for the job?
And if not whats your recomendation and why?
With tiles that small I should be able to make layout work, Should ?
Is a wet saw usable on tiles this small and glass ? and should I have it on site in case ?
There are 4 outlets to cut around, Nippers ok on this small glass and marble? is carbide needed? I'm listening for cutting advice.
This tile sits on 4" stone backsplash, caulk or grout at bottom?
I know there are some good and experienced tile guys here, so I thank you in advance for your help.
Thanks; SKC
SKC is offline
Old 03-19-2011, 10:37 AM   #2
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
Re: Some Install Questions On $ 27. Sq Ft Tile Backsplash
This is when being an actual tile guy would be very helpful.
I'm going to give you the best advice possible.....call the tile manufacturer and ask for their specifications for installing the tile. Don't let the HO tell you want to use. By all means, don't let the tile store tell you what to use. This can become a very expensive eff-up if you're not careful.
Whether a wet or dry saw/grinder is used to cut, the blade should be specific for cutting glass. I doubt nippers will work. You need to score/snap if anything.
You're on your own for the layout.
ALWAYS caulk change of plane locations and between dissimilar materials.
Angus
angus242 is offline
Old 03-19-2011, 10:39 AM   #3
Project Manager
CookeCarpentry's Avatar
Trade: Project Manager
Rewards Points: 2,016
No offense to you, but this isn't really the best tile job to cut your teeth on.
CookeCarpentry is offline
Old 03-19-2011, 11:45 AM   #4
opiethetileman's Avatar
Trade: DIYer apparently
Rewards Points: 1,000
sounds like a good job for the new LATICRETE thinset designed for glass tile. I have to agree maybe having a tile guy come in and do the splash would save you time and a headache.
But I am not perfect myself. Although I do know alot and have a GC lic. I know when its time to get a better brain on the scene.
a picture of the tile purchased would help alot as well
opiethetileman is offline
Old 03-19-2011, 12:32 PM   #5
Paul
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Rewards Points: 1,004
This.
Precision Floors
(772) 237-9900
PrecisionFloors is offline
Old 03-19-2011, 12:49 PM   #6
Project Manager
Originally Posted by PrecisionFloors View Post
This.
What?
Old 03-19-2011, 02:16 PM   #7
Paul
What?
I'm agreeing with you. $27/ft tile is no where to start learning.
Precision Floors
(772) 237-9900
The Following User Says Thank You to PrecisionFloors For This Useful Post:
CookeCarpentry (03-19-2011)
Old 03-19-2011, 02:29 PM   #8
Anderson's Avatar
Trade: Home improvement contractor
Rewards Points: 1,196
Like Angus said speak with manufactures, some of the mesh glue is soluble in water so first cut with the wet saw and you have a Mosaic to put back together.
Anderson is offline
Old 03-19-2011, 02:41 PM   #9
Hmrepairs's Avatar
Trade: Remodeling contractor
Rewards Points: 250
Learned that the hard way once.
Hmrepairs is offline
Old 03-19-2011, 03:13 PM   #10
Anderson's Avatar
me too, ya never forget the expensive lessons
Anderson is offline
Old 03-19-2011, 11:27 PM   #11
Groutface
Groutface's Avatar
Trade: flooring installer
Rewards Points: 524
Yep!
Groutface is offline
Old 03-20-2011, 12:25 AM   #12
Tiling & Bath Contractor
TileLady's Avatar
Trade: Tiling & Bathroom Remodeling
Rewards Points: 250
No offense. But if you're asking all of these questions, it really means you shouldn't be doing this job.
From a financial point of view. Lets say you manage to wing your way through the job and the customer is not happy with how it comes out. At $27 a square foot, that's at least $825 (with tax) that you're going to have to cough up, not to mention all the lost time. Cost for tear out etc.
It would make more fiscal sense to maybe sub it out to a professional tiler or even refer it to a tiler and take a referral fee or something.
If you decide to do it, then best of luck and I'll keep my fingers crossed for you.
TileLady is offline
Old 03-20-2011, 08:44 AM   #13
JohnFRWhipple's Avatar
Trade: Linear shower drain installations & waterproofing
Rewards Points: 2,000
I would back out of this install and if the client wants you to go all in I suggest you set three square feet and grout it for her as a sample.
Don't prep the sample in your shop set it in place with another backer board tacked on in front of the permanent backsplash.
These tiny tiles are hard to set well and hard to get the air bubbles and such perfect.
JW
JohnFRWhipple is offline
Tearing Up Tile for My Folks (TILE GUYS PLEASE HELP!)- Opinions Please tuffplay General Discussion 36 03-13-2012 12:11 PM
Ripping Carpet to install ceramic tile Reseman Tiling 3 10-10-2009 11:22 PM
Carpet Tile Questions M&GConstruction Flooring 0 03-27-2009 10:35 PM
How long to install a tile floor??? fathersonfab Remodeling 5 11-01-2007 10:57 AM
Backsplash Tile Question Robie Remodeling 5 02-13-2006 09:32 AM
