Setting Foam Shower Seat - Thinset? - Page 2 - Tiling - Contractor Talk
Old 05-23-2015, 08:42 PM   #21
daxsmith's Avatar
Rewards Points: 124
Re: Setting Foam Shower Seat - Thinset?
Originally Posted by CO762 View Post
That's a lot of silicone. If it's good enough for silicone there, why not just run that same 1 inch bead of silicone around the top of your "floor" instead of an air space?
That's the plan. I mentioned the "gap" but I guess I didn't elaborate that it would get filled with silicone. When I started the discussion I didn't plan for filling in all the little details about what I was building...I was just asking a question verifying that thinset would work and that the dude who said it wouldn't was wrong. But lots of curious people on here! Which is good because the forum would be boring without all the discussion. I appreciate everyone who contributes their thoughts and ideas.
By the way, I'm using Laticrete 317 since I'm also using the kerdi membrane. When I tile and move beyond the kerdi to the rest of the walls in the bathroom then I'll switch to a modified thinset. The 317 will only be used in the shower area wherever there is kerdi.
daxsmith is offline
Old 05-23-2015, 08:43 PM   #22
CO762's Avatar
Trade: Organic Mold Farmer
Rewards Points: 4,534
Originally Posted by tjbnwi View Post
A solid waterproof surface and then the bench makes for a pretty bomb proof installation.
I've seen some pix of those. I....just....can't.....do......ffff...ffffff.....f fffoam. lol.
I saw where a vendor or someone used wedi for a corner bench over existing tile and pan.
NY Times...."Prison Population Growing Although Crime Rate Drops..."
CO762 is offline
Old 05-23-2015, 08:49 PM   #23
daxsmith's Avatar
Rewards Points: 124
The wedi would work fine like that.
What would you use?
daxsmith is offline
Old 05-23-2015, 08:57 PM   #24
CO762's Avatar
You're killing me.
Specifically, I left a 1" gap between the floor and the bottom of the durock so that the durock doesn't wick up water.
A 1" x 1/2" deep trough is a lot of silicone. I figure one bead would work, especially since it's on a vertical surface. Was this air gap the part you thought you damaged so now want to do a flood test?
dax, part of my asking questions is to find out what your plan is and I'll admit I'm struggling to figure it out. If you did a liner, there's no reason for 'kerdi' on the top of your curb. Just one of many examples.
Seeing as you've been doing this shower for weeks, I assume it's your personal shower?
CO762 is offline
Old 05-23-2015, 09:15 PM   #25
daxsmith's Avatar
Rewards Points: 124
You're killing me.
I'm sorry you're struggling to understand. You've made some incorrect assumptions but hopefully you'll forgive me if I don't address all your questions. I'd have to lay everything out and I don't want to write that much.
daxsmith is offline
Old 05-23-2015, 09:16 PM   #26
CO762's Avatar
What would you use?
Nothing. I'd have to think of some scenario where I'd do something like that and off the top of my head, can't come up with one. Maybe a sick relative, but if that's the case I'd just have them demo it, I'd give them a new one and expense it.
Sometimes people put tile on tile, but not a fan of that either. Or tile on vinyl. Know that people put tile right on plywood and seems to work for them. Sometimes just strange things out there but doesn't mean I'll partake.
CO762 is offline
Old 05-23-2015, 10:23 PM   #27
JackP23's Avatar
Rewards Points: 614
Hi Mike,
I think you may have missed something. Maybe a photo will help.
The seat gets put into the corner with thinset on the verticals on the back sides of the seat. Since the floor slopes at a 1/4" per foot the front bottom of the seat would have a gap due to the floor dropping off. So you set it in some thinset and trowel it off flush so nothing sticks out past the base of the seat. All it does is provide some support to the bottom of the seat much like if you set a tub in a mud bed.
Your floor tile goes up to the bottom base of the seat. Then you tile the vertical on the seat and it will cover the joint where the floor tile butts up to the seat. Then tile the top of the seat, covering the vertical edges of the tile on the verticals.
Does that help?
The alternative to setting the seat in mud is to grind the bottom to match the angle of the shower floor. But the seat looks to have a waterproofing that I don't want to disturb.
Yes, I know the top of the seat will need to slope into the shower for water drainage.
I like where my bench meets the shower floor to be straight. On a 4' bench there would be a pretty good slope at the bottom of the bench is that right?
Do you account for the bench when you center your drain?
Thanks
__________
Mike
JackP23 is offline
Old 05-23-2015, 10:51 PM   #28
daxsmith's Avatar
Rewards Points: 124
Hi Mike,
I would call mine a corner seat rather than a bench.
The drain position in relation to the seat was considered. The shower is 62 inches long. The seat is 16 inches.
daxsmith is offline
Old 05-29-2015, 10:13 AM   #29
ee3's Avatar
Trade: membranes and shower products
Rewards Points: 192
I quit reading about half way into this ..Your doing it right..Thinset it in place,back and bottom..(to waterproof walll and mud floor)
ee3 is offline
Custom shower base - granite Charles_cz Tiling 16 01-08-2015 09:34 PM
Leaking shower drain plunk Plumbing 11 07-05-2014 01:05 PM
Wall tiles in shower ? #1 Handyman Tiling 14 06-25-2012 09:45 PM
Setting large granite slabs mant Masonry 18 05-08-2012 05:12 PM
Shower Seat rockingjwolf Plumbing 1 09-17-2009 07:59 AM
