Self Leveling Compound - Tiling - Contractor Talk
Old 02-14-2017, 04:36 PM   #1
Farmhouse's Avatar
Trade: General
Rewards Points: 6
Hi. I'm pouring self leveling compound over a plywood floor. I've done this in the past over sub floors that were in fairly good shape. For those, I applied a primer, then steel lathe/mesh, then I poured the leveling compound. Has always worked great.
For this job, the floor is sturdy, but old and has tons of larger gaps. I'm considering putting down 15 lb roofing felt, then steel lathe/mesh. Will this be a problem if the leveling compound isn't bonding directly to the wood floor? When I've done demo I've seen plenty of times where there was lathe was on top of roofing felt, and the leveling compound was more of a mortar and pretty thick. For this floor I do plan on leveling from feather to about 3/4".
Thanks!
Farmhouse is offline
Old 02-14-2017, 04:47 PM   #2
Farmhouse's Avatar
Trade: General
Rewards Points: 6
Re: Self Leveling Compound
I should add, I'm tiling on top of the floor once leveled.
Old 02-14-2017, 05:11 PM   #3
The Remodeler
Splinter's Avatar
Trade: Home Remodeler
Rewards Points: 240
Caulk the gaps in between sheets of ply. No roofing felt under SLC.
Splinter is offline
The Following 3 Users Say Thank You to Splinter For This Useful Post:
Farmhouse (02-14-2017), Philament (02-14-2017), Westward (02-14-2017)
Old 02-14-2017, 06:47 PM   #4
Windycity's Avatar
Trade: Masonry
Rewards Points: 8,430
I could be wrong but i think the felt is a bad idea....there would be no bond and it would chip and break easily where it is thin. Caulk the gaps to keep it from running through
Windycity is online now
The Following User Says Thank You to Windycity For This Useful Post:
Old 02-14-2017, 07:03 PM   #5
Jay hole's Avatar
Trade: General contractor
Rewards Points: 1,717
Isn't it wrong to have a concrete product directly on wood?
Jay hole is offline
Old 02-14-2017, 08:24 PM   #6
Farmhouse's Avatar
Trade: General
Rewards Points: 6
I think it's fine to use concrete on wood, but the wood must be primed first. If not, you do run the risk of poor bonding or the wood absorbing too much moisture and lifting or separating if plywood.
Old 02-14-2017, 09:57 PM   #7
Westward's Avatar
Trade: Home Builder
Rewards Points: 314
As above, you need to use the correct primer first, to both seal the subfloor and create a good bond to the SLC.
Westward is offline
Old 03-04-2017, 09:04 AM   #8
Manager
Guild Tile's Avatar
Trade: Tile & Marble Installation Company
Always best to follow manufacturer's instructions regarding this. I agree that caulking gaps in plywood is key - if they're small enough. If not, then an additional layer of underlayment might be considered. Also, we sometimes run blue tape around the perimeter of the room to avoid the SLP flowing into areas we don't want it to.
Guild Tile is offline
Joint Compound w/ Dust Control & Tape Machine lifestooshort81 Drywall 4 06-11-2013 07:51 AM
Leveling wall for tile. DKnafo Tiling 32 06-04-2013 10:56 PM
Leveling with roofing felt and leveling compound DIA-jp Flooring 29 01-22-2013 09:19 PM
Leveling compound over mixed subfloor. EthanB Flooring 6 07-09-2012 09:33 PM
Leveling Compound yonexwood Carpentry 5 11-02-2006 05:50 PM
