Roof Gun For Tile Underlayment? - Tiling - Contractor Talk
Old 07-19-2010, 07:02 PM   #1
Grand Rapids Remodeling
Paulie's Avatar
Rewards Points: 2,052
Ran across this ad on CL:
In very good condition.
Used only for installing underlayment for ceramic tile.
Includes partial box of nails.
Paid $249.00 new.
Call (616) 765-****.
It's a PC coil roofing gun. I've never seen one used for underlayment. Does anyone else?
Paulie is offline
Old 07-19-2010, 07:04 PM   #2
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
Re: Roof Gun For Tile Underlayment?
Yes, roofing nails are regularly used and completely accepted by CBU manufacturers (at least the ones I'm aware of).
Angus
angus242 is offline
Old 07-19-2010, 07:14 PM   #3
Paulie's Avatar
Interesting. Thanks Angus, never seen it done or for that matter torn one up that had roofer's in it. Hmmm.
Paulie is offline
Old 07-19-2010, 07:20 PM   #4
KemoSabe
loneframer's Avatar
Rewards Points: 12,218
Pretty common practice with 1/4" Hardi backer in these parts. Laid in a bed of flex bond.
loneframer is offline
Old 07-19-2010, 07:24 PM   #5
Atlanta Remodeling
bdoles's Avatar
Trade: Home Repairs and Remodeling
Rewards Points: 154
Same here. I haven't used anything but in the last few years.
bdoles is offline
Old 07-19-2010, 07:31 PM   #6
Paulie's Avatar
Dang, shows ya how much I know. Just had a small bathroom floor, I laid the hardi over the flex bond and used those funny green screws just like I always have.
Guess I got to get with the times!
Thanks Paul.
Paulie is offline
Old 07-19-2010, 08:40 PM   #7
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
That said, I would only use screws. If you understand the theory behind CBU, nails just don't seem right.
Angus
angus242 is offline
Old 07-19-2010, 08:50 PM   #8
Paul
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Rewards Points: 1,004
For you guys using Flexbond. You're wasting your money, not to mention bonding the cbu to the substrate (not the purpose of thinset under cbu). It is there to fill the voids, nothing more. Dryset under cbu.
Precision Floors
(772) 237-9900
PrecisionFloors is offline
Old 07-19-2010, 08:52 PM   #9
Tile Pro - Consulting
JazMan's Avatar
Trade: Tile Contractor-Manufacturers rep. Tile & Marble
Rewards Points: 352
I would still do it by hand for small jobs. Roofing nails work just fine for all CBU's 1/4" - 5/16" - 3/8" - 1/2". It's much faster and so you're likely to shoot more nails than you would screws too. Nails have been proven to work just fine since the mid '70's.
I decided to get a gun & compressor many years ago when I had 650 ft. to install. Of course the last 8-10 years I've used Ditra most of the time.
Jaz
TILE GUY - retired- TROY, MI - Method & Product suitability consulting.
MARBLE from ITALY & GREECE - PERLATO SICILIA - PERLATINO - BOTTICINO - THASSOS - SIVEC - VOLAKAS - NAXOS - others, Slabs - Tiles - Custom - [email protected]
JazMan is offline
Old 07-19-2010, 10:02 PM   #10
taylorconst's Avatar
Trade: remodeling, siding, windows, decks
Rewards Points: 75
Jaz
You can still use your nail gun on the ditra Just nail every other square, checkerboard pattern. Looks real cool.
taylorconst is offline
Old 07-20-2010, 09:50 AM   #11
JazMan's Avatar
Rewards Points: 352
Let me think about that for a nano second, meanwhile you stick to siding and windows.
Jaz
JazMan is offline
Old 07-20-2010, 03:59 PM   #12
opiethetileman's Avatar
Trade: DIYer apparently
Rewards Points: 1,000
yeah I use a duofast with a coil on it. 1 7/8 ring shanks and countersink them. Also use laticrete 252 under the cbo then nail it down. Its only there to fill the holes and such nothing more nothing less. And I usually use a 1/4 notch trowel and mix it a little wet. nail it down and back skim the entire floor after that
opiethetileman is offline
Torch down(flat roof) leaks BAD...can you give advice ASAP? Detail Guy Roofing 22 01-05-2013 06:42 PM
Flat roof, torch roof question enforcer Roofing 7 01-05-2013 01:08 PM
flatroof to pitched. Insulating above old roof Red Adobe Insulation 2 07-14-2009 10:30 AM
power vents and roof vents 232323 Roofing 4 03-19-2009 05:31 PM
rubber roof over rolled asphalt ? ? btownpa Roofing 2 03-06-2009 03:03 PM
