Quartz Subway Tile - Tiling - Contractor Talk
Quartz Subway Tile
Old 07-10-2015, 11:44 AM   #1
BlueRidgeGreen's Avatar
Trade: Craftsman
Rewards Points: 526
Quartz Subway Tile
I'm going to be starting a couple showers in a week or so that will both be done in a white Quartz subway tile.
I've never played around with Quartz.....other than watching countertops being installed.
I really like the look of these tiles, and the idea of a low-maintenance, yet aesthetically attractive tile.
Question is....
How is Quartz to work with?
I assume it will cut just fine with the Razor....
But will I be able to customize my design by slicing and dicing their stock sizes?
More specifically......
Will I be able to use my slow speed grinder and diamond abrasive wheels to chamfer or polish it like I would natural stone?
Any other advice?
Thanks in advance,
Jonathan
BlueRidgeGreen is offline
Old 07-11-2015, 07:08 AM   #2
MIKE ANTONETTI's Avatar
Trade: FLOORING CONTRACTOR
Rewards Points: 3,514
Re: Quartz Subway Tile
I've done silestone countertop on a guest house previous residence. Not sure exactly what you have. I assume most techniques will be similar to granite. When you say natural stone, there's wide variety of hardness.
What slow speed grinder you have? Also diamonds are improving vastly in past few years. Hybrids/ceramic filled/dry etc.
So the Quartz is probably a mixture of synthetics (resins) the pads may burn surface when polishing, do you have wet polisher?
Also, I left some slabs outside in the sun for months, it was brown and it faded drastically, not sure if that issue was corrected.
MIKE ANTONETTI is offline
The Following User Says Thank You to MIKE ANTONETTI For This Useful Post:
BlueRidgeGreen (07-11-2015)
Old 07-11-2015, 04:53 PM   #3
mikeswoods's Avatar
Trade: interior remodeling
Rewards Points: 2,664
I've had trouble with the resins gumming up the diamond blades---have a dressing stone handy or an old brick to clean up the blade---
mikeswoods is offline
The Following User Says Thank You to mikeswoods For This Useful Post:
Old 07-11-2015, 10:43 PM   #4
Trade: Craftsman
Rewards Points: 526
Looks like I may not get to try them out.
(late design change)
I was looking forward to it.
Thanks though.
Old 07-12-2015, 06:16 AM   #5
If you can get a piece, try it out for future use to know going in how to work with it.
BlueRidgeGreen (07-12-2015)
Old 07-14-2015, 06:02 PM   #6
GO Remodeling's Avatar
Rewards Points: 96
I had a lot of the cuts chipping with quartz. Thin cuts broke apart. The product came from Vietnam.
GO Remodeling is offline
The Following User Says Thank You to GO Remodeling For This Useful Post:
BlueRidgeGreen (07-14-2015)
Old 07-24-2015, 05:54 AM   #7
ronkeddy11's Avatar
Trade: Tiles
Rewards Points: 28
In my last project we have worked with quartz subway for kitchen backsplash and it looks lovely.
ronkeddy11 is offline
Ceramic tile ZackyBundles Flooring 26 03-05-2013 10:09 AM
Tile over Tile fireguy Flooring 5 09-16-2012 05:25 AM
Tile over Tile using Eco Prim Grip Snobnd Tiling 22 05-02-2012 06:45 PM
Subway tile Shower remodel MattCoops Tiling 20 01-05-2008 07:52 PM
