Pricing Tile Based On Size. - Tiling - Contractor Talk
Old 05-06-2015, 06:58 PM   #1
TaylorMadeAB's Avatar
Trade: Renovations
Rewards Points: 1,686
So I'm creating a spreadsheet for myself to do tile floor estimates on the spot. It has a count for registers, doorways, profiles, cut edges, etc. I also want to have the common sizes of tile have a "multiplying" factor assigned to them. For example, I use 12x12 tile as a base number, I assign it as 1. 12x24 tile is more complicated to lay, so it gets a 1.2.
My question is; if you had to rank the common sizes of tile by difficulty to lay, what would your list be?
Mine in order of easiest to hardest; 12x12, 16x16, 12x24, 24x24, 6x6, 4x12, and long plank being the most difficult.
TaylorMadeAB is offline
Old 05-06-2015, 10:05 PM   #2
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
Re: Pricing Tile Based On Size.
Not sure if it's really the size that makes a tile more or less difficult to install. More times than not, it's the type of tile that will elevate difficulty.
A big box store tile with rectified edges and a smooth finish might be very hard to install because of inconsistent sizing and the rectified with smooth tend to be more tedious.
I know a la carte pricing is ideal but I can't do it. There are always too many variables that can make or break you making money.
Sorry I'm no help but I don't quote a price until I know what I'm installing, regardless of size.
Angus
angus242 is offline
The Following 3 Users Say Thank You to angus242 For This Useful Post:
BlueRidgeGreen (05-07-2015), TaylorMadeAB (05-06-2015), TNTRenovate (05-07-2015)
Old 05-06-2015, 10:40 PM   #3
Trade: Renovations
I follow you, and I totally agree. But I'm looking to streamline my estimating. If it turns out that the tile is crap, I'll charge more for it. But I'd like to be able to pump out accurate numbers on the spot.
Old 05-06-2015, 11:29 PM   #4
avenge's Avatar
Rewards Points: 304
If we start estimating based on tile size we're screwed.
avenge is offline
Old 05-07-2015, 12:04 AM   #5
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
I suggest considering a per day pricing structure:
1 day for demo
.5 for underlayment
2 days for tile install
1 day for grout & clean up
At that point you can adjust the daily pricing for more difficult situations, say if your cutting station is far away, if you are doing stone instead of ceramic, site or time restrictions, etc.
Maybe you are in a location where typical tiling rates are competitive and rather low. You could adjust pricing per day based on the task. Maybe demo pricing is lower. Example numbers
Day 1: Demo = $250
Day 2: Underlayment = $150
Day 3: Tile install = $300
Day 4: Tile install = $300
Day 5: Grout = $200
Add materials, overhead and profit
If you have something more difficult, just adjust the single price. Say you need to do some subfloor repairs.
Day 2: Underlayment = $300
No need to ultra-break down the numbers, just make sure you are estimating your days correctly. You have more wiggle room with a per-day matrix than a per sq ft or per tile size.
Angus
angus242 is offline
The Following 2 Users Say Thank You to angus242 For This Useful Post:
TaylorMadeAB (05-07-2015)
Old 05-07-2015, 05:41 AM   #6
If my PO asks,I set tile
Evan1968's Avatar
Trade: Commercial Tile Installs
Rewards Points: 1,160
Taylor,
Whats the advantage of pumping out a estimate on the spot?
A la carte pricing sorta works but just figuring how long it will take and how much you want to make per day is more of the way I do it. That gets me in the ballpark and then I fine tune it from there for a final $$$.
Craig
Tile Installations Unlimited
"If you can't wow them with knowledge,baffle them with bullcrap."
Evan1968 is offline
Old 05-07-2015, 06:42 AM   #7
Hair Splitter
TNTRenovate's Avatar
Trade: General
Rewards Points: 1,268
So installing 4x4 versus 12x12 isn't a factor for you. Sure is for me. When I have to set 4 times the tile my price goes up. Same for larger format. More time consuming on the prep.
Tried & True on Facebook
Tried & True Website
TNTRenovate is offline
The Following 2 Users Say Thank You to TNTRenovate For This Useful Post:
Old 05-07-2015, 06:44 AM   #8
Hair Splitter
Trade: General
Craig has fixed tile pricing.
But I'm with Angus. I base on number of days to install.
Old 05-07-2015, 07:49 AM   #9
Evan1968's Avatar
Uh sort of. For my commercial work i do have fixed prices. The fixed price i set has been generated based on all the factors that have been discussed previously as in kind of tile,substrate,complexity of the layout, repetition(# of stores we have done before)...etc.
With my resi work i go by the Angus method.
So i guess mine is a hybrid system.
Craig
Evan1968 is offline
Old 05-07-2015, 07:57 AM   #10
Hair Splitter
Trade: General
I was referring to Charimon
Old 05-07-2015, 08:07 AM   #11
GO Remodeling's Avatar
Rewards Points: 96
12 x 12 is my base for tiling. How many pieces of subway tile make up a 12 x 12 ? Eight pieces. That's 8x I'm picking up a tile to set.More labor.
how many steps to the kitchen or bath makes a big difference to me incase my wet saw needs to be used.
GO Remodeling is offline
The Following User Says Thank You to GO Remodeling For This Useful Post:
Old 05-07-2015, 08:46 AM   #12
Trade: Renovations
Taylor,
What I'm trying to do is cut down the amount of time I sit in my office doing estimates. There are a few types of jobs that people have a very skewed perspective of cost on, and tile is one of them. I want to be able to give them a reasonably accurate number on the spot. If they like that number I will go home and do my own estimate. I agree with most of you guys on estimating based on time, and that is how I do mine.
I'm just tired of writing detailed estimates for people who are out to lunch on what things cost.
Old 05-07-2015, 10:47 AM   #13
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
I have always said this from day one about per sq ft pricing.
The reality is it's pretty rare to install tiles that small these days. I get the occasional subway shower but I hardly ever even do 12x12's anymore. (back splashes aside).
That's when I went to per day pricing. You can adjust a lot more within an entire day than a per tile structure. Of course the tile size makes a difference. But so do many other factors. Take everything into account and just put a single number on it & that makes for a pretty easy way to estimate.
He has some of the coolest tools so Charimon is an anomaly
There are times, especially with a GC that you need a la carte pricing. But for occasional residential tile work, per day works.
Angus
angus242 is offline
Old 05-07-2015, 11:19 AM   #14
avenge's Avatar
Rewards Points: 304
I meant based on tile size alone, I would hate to see a day I have to compete when tile estimates are given on tile sizes with no other variables factored into an estimate. To me that's like estimating based on square footage which I never do on any project not just tile.
I don't have a set price based on tile size that's just not gonna work for me. I rarely know at the time of the estimate what exactly I'm laying, I may be given an idea but that's likely to change as will my estimate.
avenge is offline
The Following User Says Thank You to avenge For This Useful Post:
Frozen tile saw platinumLLC Flooring 40 12-15-2014 07:57 AM
Tile shower pricing Stevarino General Discussion 59 10-26-2013 09:15 PM
Leveling wall for tile. DKnafo Tiling 32 06-04-2013 10:56 PM
