Plastic Niche - Tiling - Contractor Talk
Plastic Niche
Old 05-09-2015, 12:27 PM   #1
Nick1001's Avatar
Rewards Points: 201
Plastic Niche
Has anyone worked with one of these plastic niches? Do you have to use a certain type of thinset with it? I have time to change it if it's a pain to use. The customer picked it up. [
ATTACH]178706[/ATTACH]
Nick1001 is offline
Old 05-09-2015, 12:39 PM   #2
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
Re: Plastic Niche
Yes, I've used them Duk Liner specifically. Nothing special. I used liquid membrane to wrap from CBU into liner. Modified thinset to adhere tiles.
Angus
angus242 is offline
The Following User Says Thank You to angus242 For This Useful Post:
Nick1001 (05-09-2015)
Old 05-09-2015, 01:35 PM   #3
TaylorMadeAB's Avatar
Trade: Renovations
Rewards Points: 1,686
Re: Plastic Niche
That's the first premade niche I've seen that is more than 12" tall, which is great for Costco sized shampoo
TaylorMadeAB is offline
Old 05-09-2015, 01:59 PM   #4
Tile Contractor
HS345's Avatar
Trade: Ceramic and Natural Stone Tile Contractor
Rewards Points: 886
Re: Plastic Niche
Got a brand name? I think there is one prefab plastic niche out there that requires epoxy thinset to adhere to. If that is one of those, get a Noble Niche.
http://noblecompany.com/products/noble-niches
Greg
HS345 is offline
Old 05-09-2015, 02:16 PM   #5
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Re: Plastic Niche
Duk Liner
http://www.barwalt.com/products/accessories/duk-liners/
Angus
angus242 is offline
Old 05-09-2015, 02:26 PM   #6
Tile Contractor
HS345's Avatar
Rewards Points: 886
Re: Plastic Niche
Originally Posted by angus242 View Post
That looks different than the one in the OP.
"All you have to do is add nailing blocks, overlay the moisture barrier, install mortar/backerboard and apply anti-fracture waterporrfing membrane and it's ready to tile!"
That's all you have to do? Lol. Might as well build your own.
Greg
HS345 is offline
The Following User Says Thank You to HS345 For This Useful Post:
overanalyze (05-09-2015)
Old 05-09-2015, 02:41 PM   #7
MarkJames's Avatar
Rewards Points: 19,191
Re: Plastic Niche
If that's one from "the tile shop", they bite because the back can deform, warp and bow out...after you start working with it. I had a bad experience and will never use a hard plastic one again. (I think it is one from them, too...different sizes have different colors over there...at least they did)
MarkJames is offline
Old 05-09-2015, 03:26 PM   #8
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Re: Plastic Niche
For $55, yeah building your own is the way to go
http://www.tileshop.com/product/pro+...e=&from=Search
Looks identical to the Duk Liner. Pre-drilled holes aren't as prominent.
Angus
angus242 is offline
Old 05-09-2015, 04:10 PM   #9
Nick1001's Avatar
Rewards Points: 201
Re: Plastic Niche
I'll ask the customer. I didn't see anything on it. I normally frame my own. This looks simple enough. My biggest worry was bonding issues.
Nick1001 is offline
Old 05-09-2015, 04:12 PM   #10
Nick1001's Avatar
Rewards Points: 201
Re: Plastic Niche
I'm pretty sure that's where it's from.
Nick1001 is offline
Old 05-09-2015, 04:17 PM   #11
Nick1001's Avatar
Rewards Points: 201
Re: Plastic Niche
She wants it in an exterior wall. My guess is that's going to be a big issue if it's warping in a normal install.
Nick1001 is offline
Old 05-09-2015, 04:25 PM   #12
Keeyter's Avatar
Trade: Home Remodels
Rewards Points: 851
Re: Plastic Niche
The tile shop ones they guys will tell you have to lay a sheet of CBU on the back of it
Keeyter is offline
Old 05-09-2015, 04:26 PM   #13
Keeyter's Avatar
Rewards Points: 851
Re: Plastic Niche
2x6 Wall - No problem insulate behind it
2x4 Wall - IMO should never have a recessed niche on it
Keeyter is offline
Old 05-09-2015, 04:57 PM   #14
Tile Contractor
HS345's Avatar
Rewards Points: 886
Re: Plastic Niche
The point is, with the amount of prep required for the duk liner, what time are you really saving? With Noble and/or Kerdi niche, you pop it in and go. What's the point of a prefab niche if you still have to install blocking, CBU, and waterproof it?
Greg
HS345 is offline
Old 05-09-2015, 05:38 PM   #15
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
Re: Plastic Niche
There isn't one.
Inner10 is offline
Old 05-09-2015, 06:32 PM   #16
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Re: Plastic Niche
Well I can't speak for the Tile Shop stuff but the Duk Liner instructions are similar but I think you misunderstood some.
You install the plastic niche directly to studs. You might have to add blocking to align properly but it's not necessary if you fit between 2 regular 16"OC studs. The CBU overlaps the plastic. Just cut CBU to fit the opening. And finally, you don't waterproof the entire niche, just the seam between the plastic and CBU.
But I still won't use them anymore. I also did one (actually 3 in same bath) that the HO bought.
Angus
angus242 is offline
Old 05-09-2015, 09:17 PM   #17
Tile Contractor
HS345's Avatar
Rewards Points: 886
Re: Plastic Niche
Originally Posted by Inner10 View Post
There isn't one.
There isn't one what?
Greg
HS345 is offline
Old 05-09-2015, 09:18 PM   #18
Inner10's Avatar
Re: Plastic Niche
Point.
Inner10 is offline
HS345 (05-10-2015)
Old 05-09-2015, 09:28 PM   #19
MarkJames's Avatar
Re: Plastic Niche
If the thing seems more dimensionally stable, sure, go for it. But the tile shop one will give you problems. It would be about as enjoyable as buying a pair of pliers from a dollar store and dealing with the headache.
Also, I recall that the tileshop one has a thick flange so you can't overlap the CBU without messing around with the studs.
Old 05-09-2015, 09:53 PM   #20
Keeyter's Avatar
Rewards Points: 851
Re: Plastic Niche
Its setup to split the standard stud bay - half on the stud the other half of the stud is there for CBU so the face of the niche sits flush with the CBU and you can tape, seam, waterproof.
That said I build all mine - I don't like being stuck to one size and adjust mine based on tile dimensions and layout.
Keeyter is offline
The Following 3 Users Say Thank You to Keeyter For This Useful Post:
HS345 (05-10-2015), MarkJames (05-09-2015), Nick1001 (05-09-2015)
WOOD Or Plastic Denny Rossi Decks & Fencing 27 10-31-2012 06:21 PM
plastic under slab... woodworkbykirk Carpentry 22 03-11-2011 09:07 PM
Recessed soap/shampoo niche jarvis design Tiling 37 07-06-2009 12:24 AM
soda blasting plastic bumpers ausisoda Sandblasting 3 05-29-2009 10:23 AM
Metal vs Plastic bullnose lpp Drywall 4 01-27-2009 11:44 PM
