My First Tile Job. - Tiling - Contractor Talk
My First Tile Job.
Old 07-18-2010, 02:28 AM   #1
taylorconst's Avatar
Trade: remodeling, siding, windows, decks
Rewards Points: 75
My First Tile Job.
Just installed this last week.
Not sure why the pic is so small, sorry.
taylorconst is offline
Old 07-18-2010, 07:46 AM   #2
Dan
ApgarNJ's Avatar
Rewards Points: 2,000
Re: My First Tile Job.
Try uploading the picture to photobucket or flikr site and then use the IMG link and they will come up full size.
ApgarNJ is offline
Old 07-18-2010, 08:34 AM   #3
Finish Carpenter
TBFGhost's Avatar
Trade: Finish Carpentry, Reno
Rewards Points: 2,760
Looks like you just started in a corner and worked your way out...while that works, it looks better if you center up a tile or grout line on the door and make sure the layout prevents that little 2" tile you have near the tub. You would have ended up with 7" tiles near the door and near the tub.
TBFGhost is offline
Old 07-18-2010, 12:42 PM   #4
Doing what I do.
fastg60's Avatar
Trade: Remodeling contractor/US Army
Rewards Points: 79
Around The House
Remodeling and painting.
fastg60 is offline
Old 07-18-2010, 01:27 PM   #5
Dan
ApgarNJ's Avatar
you should center that tile. both ways. It doesn't look good to end at the tub/shower with those smaller pieces. You have to find the center of the floor in each direction. then sometimes you center the tile on that line(while making a second line for the edge of the tile), and sometimes you run the tile along the center line and it lays out better. All depends on the size of the room.
if it's in an area that doesn't get seen much, and it's the only way of doing it, then a small rip can be used, like behind a toilet area that is hard to see, it's still not ideal.
did you start at the doorway and work to the tub?
ApgarNJ is offline
Old 07-18-2010, 01:57 PM   #6
MAULEMALL's Avatar
Trade: GENERAL CONSTRUCTION
Rewards Points: 98
Originally Posted by fastg60 View Post
I see the toilet in the tub but I don't see where you cut out for it
MAULEMALL is offline
Old 07-18-2010, 01:58 PM   #7
Dan
ApgarNJ's Avatar
you can just barely see the white(pvc?) of the toilet flange, it's next to the vanity cab.
ApgarNJ is offline
Old 07-18-2010, 06:53 PM   #8
MAULEMALL's Avatar
Rewards Points: 98
Now I see it..
Old 07-18-2010, 06:57 PM   #9
Project Manager
CookeCarpentry's Avatar
Trade: Project Manager
Rewards Points: 2,016
It doesn't look bad.
As others have said, layout is key.
Hard to tell from the photos about lippage. Did you just wipe the floor, because the grout looks blotchy...?
Think about using an epoxy or urethane grout.
Also, how do you plan on transitioning from the wood to tile?
CookeCarpentry is offline
Old 07-18-2010, 08:31 PM   #10
Paul
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Rewards Points: 1,004
Not bad for a first job. I would have broken the colors up a bit more. It looks like there is a stripe or two in the floor because you have multiple dark and light tiles bunched together or in a row. I probably would have scribed the first row to fit against the tub out of full or nearly full tiles but layout is subjective....the customer is the one you have to make happy, not a bunch of nit pickin fellow contractors
edit: Looks like that toilet flange is buried....what did this go over
Precision Floors
(772) 237-9900
PrecisionFloors is offline
Old 07-18-2010, 08:35 PM   #11
opiethetileman's Avatar
Trade: DIYer apparently
Rewards Points: 1,000
i like the layout left a full at the door and a good size chuck at the tub to scribe with. And the best part he is putting base on top of the tile. Make sure you caulk that joint at the tile and base. great install.
opiethetileman is offline
Old 07-18-2010, 11:18 PM   #12
Rewards Points: 75
This is how the man paying for it wanted it. I talked to him about cutting tiles at the door so they would be the same at both ends. The room was perfect for width so four tiles across no cutting. As far as the pattern that was also the home owner. He had each tile numbered and an arrow that had to point to the south. He even had it all drawn up on a peice of paper. There is a cut out for the toilet you just can't see it, it's behind the vanity. When I took the picture I had just got done wiping down the floor, that's why the grout looks blotchy. It dried up to a nice uniform color.
Where I come from baseboard always goes on top of the floor, not the floor up to it.
There is no lipage. We just recently bought a house that has a remodeled bathroom, there is enough lipage on that tile floor that I could just about add tiles on top of the low ones to even it out. As far as the transition he wanted 1/4 round that matched the new baseboard I installed.
Old 07-19-2010, 05:24 AM   #13
Money Changer
bert0168's Avatar
Trade: Residential Remodeling
Not sure I follow the math here. If he centered the tile, how do you divide 2" then end up with 7" on both ends?
I think it looks fine. Sometimes with smaller rooms, it's tough to get a piece of tile large enough to look good on the border. If I can't get at least a 1/3 piece of tile on both ends, I'll go as you did and start full on one end.
Bottom line, if the customer got exactly what they wanted, job well done
bert0168 is offline
Old 07-19-2010, 01:09 PM   #14
Paul
When it comes to layout and pattern - That's all that matters. I don't have to like it, I ain't gotta live there
Precision Floors
(772) 237-9900
Old 07-23-2010, 03:34 PM   #15
Pro Grade Flooring LLC
Ed4x4's Avatar
Trade: Flooring: Carpet, Wood, Laminate
Rewards Points: 77
I cant really tell from the pictures, but to me it doesnt look like the tile is far enough into the doorway to cover the transition under the door. Looks like the hallway flooring would be viewable in the bathroom. I could be wrong.
Other then that, and the small tiles at the tub, looks good to me. Bathrooms are no fun.
Carpet, Wood, Laminate, Tile
Ed4x4 is offline
Bought a new Ridgid tile saw...any reviews here? IHI Tiling 45 11-24-2012 01:03 PM
Tile over Tile fireguy Flooring 5 09-16-2012 05:25 AM
Tearing Up Tile for My Folks (TILE GUYS PLEASE HELP!)- Opinions Please tuffplay General Discussion 36 03-13-2012 12:11 PM
Tub tile backing KennMacMoragh Kitchens & Baths 10 05-12-2010 01:28 PM
information on fixing a bad tile job bford General Discussion 4 09-30-2008 06:44 AM
