Modified Or Unmodified Over RedGuard - Tiling - Contractor Talk
Old 10-21-2016, 02:45 PM   #1
cheeks's Avatar
Rewards Points: 20
Good day,
I will be picking up my ceramic wall and floor tiles today to begin my shower. I have installed Denshild board with two coats of redguard as waterproofing. My question is what thinset is required for installing tile over top of Redguard?
I have heard both modified and unmodified.
many thanks!
cheeks is offline
The Following User Says Thank You to cheeks For This Useful Post:
Dave Mac (10-25-2016)
Old 10-21-2016, 02:48 PM   #2
cheeks's Avatar
Rewards Points: 20
Re: Modified Or Unmodified Over RedGuard
Good day,
many thanks!
cheeks is offline
Old 10-21-2016, 03:02 PM   #3
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 516
Threads merged. Please do not start multiple threads with the same subject.
Tinstaafl is offline
Old 10-21-2016, 11:41 PM   #4
Hair Splitter
TNTRenovate's Avatar
Trade: General
Rewards Points: 1,268
Why did you redgard denshield?
You use modified mortar over a topical membrane.
I would suggest hiring a tile setter, tiling isn't easy and most people cannot do it the correct way.
Tried & True on Facebook
Tried & True Website
TNTRenovate is offline
The Following 5 Users Say Thank You to TNTRenovate For This Useful Post:
avenge (10-23-2016), Big Shoe (10-23-2016), charimon (10-22-2016), Dave Mac (10-25-2016), PrecisionFloors (10-28-2016)
Old 10-22-2016, 09:17 AM   #5
cheeks's Avatar
Rewards Points: 20
I chose to use denssheild and red guard in replacement of the Schulter-Kerdi Board system. The red guard was applied as an extra layer of water proofing protection.
As for setting the tiles, I proficient experience in hardwood flooring, finishing carpentry and light masonry work.
As there was no direction on the red guard pale as to what thin set use, I figured I would inquire.
Thank you
cheeks is offline
Old 10-22-2016, 10:21 AM   #6
If my PO asks,I set tile
Evan1968's Avatar
Trade: Commercial Tile Installs
Rewards Points: 1,160
Alrighty then, carry on! Sounds like a winning trifecta to me.
Craig
Tile Installations Unlimited
"If you can't wow them with knowledge,baffle them with bullcrap."
Evan1968 is offline
The Following 3 Users Say Thank You to Evan1968 For This Useful Post:
Dave Mac (10-25-2016), Krok (10-22-2016), TNTRenovate (10-23-2016)
Old 10-22-2016, 05:02 PM   #7
Remodeler
mike d.'s Avatar
Trade: Professional Remodeler
Rewards Points: 306
Originally Posted by cheeks View Post
Good day,
many thanks!
Modified,,,,if you can do all the things you said, you should have no trouble. Get tech, info from the manufacturer. Good luck....
mike d. is offline
The Following User Says Thank You to mike d. For This Useful Post:
Old 10-22-2016, 11:08 PM   #8
Krok's Avatar
Trade: Mold Generator
Rewards Points: 844
I hope you put tar paper behind the denshield
Krok is offline
The Following User Says Thank You to Krok For This Useful Post:
Old 10-23-2016, 12:15 AM   #9
Tile-guy's Avatar
Trade: Tile installations
Rewards Points: 116
Modified thin set.
Tile-guy is offline
The Following User Says Thank You to Tile-guy For This Useful Post:
Old 10-23-2016, 10:12 AM   #10
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,162
Epoxy.
overanalyze is offline
The Following 2 Users Say Thank You to overanalyze For This Useful Post:
Dave Mac (10-25-2016), TNTRenovate (10-23-2016)
Old 10-23-2016, 02:19 PM   #11
Krok's Avatar
Rewards Points: 844
Originally Posted by overanalyze View Post
Epoxy.
That would be minimum code.
Krok is offline
Old 10-23-2016, 02:48 PM   #12
Hair Splitter
Trade: General
How would any of those things he listed mean he should have "no trouble" setting tile. He doesn't even know what thinset to use over his waterproofing. I wish I had known that before finding a few mentors to help me, studying the TNCA Handbook, NTCA Reference manual and attending training from manufacturers and vendors.
Here's what I can tell you. Setting tile properly isn't easy and no carpentry or light masonry work will help you in the details and specifics. It may help a bit in layout and some general skills, but by no means does it mean you will have no trouble.
What's recommended coverage for thinset in a wet area? What direction should he trowel? Do you recommend back buttering? Do recommend wiping the kiln release agent from the tiles before setting? How big are the tiles? Do you know what qualifies a tile as large format? Do you just install large format tiles with modified, not a LFT thinset? Do you recommend mixing the thinset per the manufacturers directions? If so, does that mean you know what slaking is and why it's so important?
The Following 4 Users Say Thank You to TNTRenovate For This Useful Post:
avenge (10-23-2016), Dave Mac (10-25-2016), Evan1968 (10-23-2016), PrecisionFloors (10-28-2016)
Old 10-23-2016, 02:56 PM   #13
Hair Splitter
Trade: General
Thank you
"Tile and Stone Installation
Install*tile*or*stone*with*a*Custom®*Building*Prod ucts*polymermodified
mortar that meets ANSI A118.4 or A118.15 standards."
The Following User Says Thank You to TNTRenovate For This Useful Post:
Old 10-23-2016, 07:29 PM   #14
Wormdrive Operator
heavy_d's Avatar
Trade: Contractor
Rewards Points: 6,886
Fiesty!
Aztec Decks
Oshawa deck builder
heavy_d is offline
The Following 2 Users Say Thank You to heavy_d For This Useful Post:
Dave Mac (10-25-2016), Tweed11 (10-25-2016)
Old 10-23-2016, 07:39 PM   #15
Evan1968's Avatar
How, by any stretch of the imagination ,do his qualifications even possibly come close to make him proficient at setting tile??
I guess all those trips to Laticrete in Bethany I made was for the free food.
I replaced a toilet once,that must mean I'm a plumber. Think I want to pipe a house.
Craig
Evan1968 is offline
Dave Mac (10-25-2016), PrecisionFloors (10-28-2016), TNTRenovate (10-23-2016)
Old 10-23-2016, 07:43 PM   #16
cheeks's Avatar
Rewards Points: 20
TNT,
I cannot begin to explain my appreciation for how helpful you have been on this topic. Without your criticizing remarks and years of knowledge passed down through your responses, I would have almost tried to attempt tiling my very own shower.
This is Contractor Talk. I am a carpenter by trade, but am now a commercial site supervisor. I am not looking for advice to go about stealing work from you, or ripping off a client. I am asking a simple question on a professional forum regarding product specifications.
I do hope you have more to live for than setting tile and casting your judgement on complete strangers over an Internet forum.
I will now call a tile guy from the phone book instead of attempting a new skill. I surely want to leave it to the pro's, and not attempt to try anything inside of my own home.
Enjoy your evening and keep up the positive posts.
cheeks is offline
The Following 2 Users Say Thank You to cheeks For This Useful Post:
Dave Mac (10-25-2016), Wile E Coyote (10-26-2016)
Old 10-23-2016, 07:54 PM   #17
Evan1968's Avatar
Why do people leave out the good stuff about a project in the original post??
Craig
Evan1968 is offline
Old 10-23-2016, 08:03 PM   #18
cheeks's Avatar
Rewards Points: 20
Evan,
You're right. I should have clarified this in the original post. This is for my own shower. As you'll be able to tell in my post count, I am very inactive on this forum and should have broken down the project previously,
Thanks again for the help.
cheeks is offline
Old 10-23-2016, 08:10 PM   #19
Hair Splitter
Trade: General
TNT,
I would suggest dropping the skirt and purse first.
Trust me, I am not afraid of you stealing anything from me. Even if you were in my town, you wouldn't even come close to being able to touch the clientele I have.
I take my craft seriously, if that is a crime or some kind of insult in your world, no wonder you became a supervisor. Some can hack it and some are just hacks.
I will add, aren't you just making an judgement about me over an Internet forum? See how that works. I am not allowed to have an opinion or make a judgement about someone by what they post but you can about me. Now that's funny.
You don't attempt a new skill, you spend time and money acquiring it over many years, not by asking questions on the internet or watching YouTube videos.
Don't care to be positive when someone is hacking it up, whether it's their own shower or not. This is an public forum. That means anyone can find these threads.
They have DIY forums for working on your own home.
Old 10-23-2016, 08:18 PM   #20
cheeks's Avatar
Rewards Points: 20
You got me.
Feelings hurt, profession insulted.
Enjoy your forum.
cheeks is offline
Dave Mac (10-25-2016), Jspence (10-24-2016)
Marble tile over Ditra or Blanke or Durabase w/ modified thinset? ND2 Tiling 13 01-09-2013 03:45 PM
Modified vs EPDM $ question. seeyou Roofing 3 10-13-2011 12:14 PM
Kerdi = unmodified, Ditra = modified - why? bob_cntrctr Tiling 3 07-14-2010 07:12 AM
Ditra and unmodified primetimeon Flooring 8 05-28-2010 11:25 PM
redguard on densGuard trap moisture? wopachop Tiling 14 11-20-2008 02:09 PM
