Marble Wall / Floor Grout Maintenance ? - Tiling - Contractor Talk
Old 08-14-2012, 09:08 AM   #1
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
Rewards Points: 2,414
Have a customer that has a custom marble shower installed about 10 yrs ago that needs maintenance.
Its in good shape other than the lower course or two (12 x 12 marble) - the grout is loose / falling out in a few places. The wall / floor joint is just beginning to show a crack a bit. The customer does remember the Hydroban - blue being installed - so its a good install.
There is only grout in all joints now. No caulk in the corners or floor / wall seam.
I've done a lot of maint to ceramic tile, regrout and silicone the seams.
What about on this marble that is white with a black seam ? I intend to remove what grout is loose with my Fein MM and regrout the wall joints with modified grout.
What about the wall / floor joint ? Same maint with my MM and regrout only where needed. Should I caulk the floor / wall joint with silicone too even though there is none there now or just leave it grout ?
We Fix Houses is offline
Old 08-14-2012, 09:24 AM   #2
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
Re: Marble Wall / Floor Grout Maintenance ?
Caulk change of plane seams with 100% silicone.
Clean the entire shower and reseal:
http://www2.dupont.com/Stone_Tech_Pr...e_cleaner.html
http://www2.dupont.com/Stone_Tech_Pr...ty_sealer.html
Angus
angus242 is offline
Old 08-14-2012, 09:55 AM   #3
Appreciate it Angus. I think I can sell some addl apps in the bath too with the tech info you provided. I just worry about marble ? I think the DuPont stuff covers it.
Just to clarify - the wall corners and especially the floor / wall corner - clean out and silicone only or repack with the 1/8 - 3/16 grout joint like the original install then silicone ?
Old 08-14-2012, 11:48 AM   #4
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Use a good silicone in corners like ColorSil or Latisil. They can closely match the grout color.
Angus
angus242 is offline
Old 08-14-2012, 12:00 PM   #5
Thanks. I'm going by the tile dist later today. They have what you mentioned.
Gutter Hangers in Stucco Wall go_hercules Construction 8 05-23-2012 12:37 AM
Retaining Wall Rebuild Dovetailed Landscaping 22 03-31-2012 08:02 PM
New furred 2 x 6 wall infront of concrete block wall. huntch3 Construction 11 03-27-2012 06:39 AM
Shoring Exterior Load Bearing Wall for Beam insertion larch General Discussion 4 01-27-2012 07:47 PM
What is the pros and cons of applying AGT or Marble Stone as exterior wall finishes? kwanht Masonry 1 03-31-2010 01:00 AM
